Go Back   Maxima Forums > Maxima Discussions > 3rd Generation Maxima (1989-1994)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 10-16-2009, 08:58 AM   #1
Coolant Temp Sensor Ohms
Anyone know how Ohms the Coolant Temp sensor (to ECU) should read. trying to work out if mine is shot at the mo.
W00dface is offline   Reply With Quote
Old 10-16-2009, 12:43 PM   #2
jbbons25 is offline   Reply With Quote
Old 10-16-2009, 01:53 PM   #3
Big thank you. Mine seems to read ok which is strange as I could have sworn it was shot.
Back to the drawing board to find out why my rad fans wont kick in
Old 10-16-2009, 06:48 PM   #4
Well if youve gone that deep into checking then im sure youve already checked your fuses fan plugs..I also think i have a malfunctioning coolent temp sensor because my car will get hot when im at a stand still or sometimes it will spike spuratically...my fans work but usually when they come on they stay on.....so my temp sensor shoudl read 2.1-2.9 ohms??
__________________
( VG30E 5-speed, InTraX Springs, Koni Red Adjustable Shocks, Stillen LipKit, WarpSpeed Y-Pipe + Cat Back, N1 muffler, UnOrthodox Underdrive Pulley, Blemco Groundwires, 18" Akuma Black w/ Chrome lip, Custom Short Ram Intake, 35% Tint, 12" Kicker L5 w/ 1200w Sony Amp,
1991- pb 15.724 87 mph
1991Maxima1991 is offline   Reply With Quote
Old 10-17-2009, 12:55 AM   #5
A good way to tell if you coolant temp is bad is 1:
Radiator fans come on at the wrong time- example- My fans came on when I just started the car for the day, and it was cold outside. The fans would come on just while driving and make the car seem like its running hot, when its really not. Another sign is when sitting at idle for a while like in traffic, the temp guage starts to go up more and more almost to the hot mark, and guess what? No Fans are on or comming on either! I know this because I replaced my temp sensor with one out the junk yard, and it worked for a week or so. Nothing was wrong with the one that was originally in the car, I just swapped it out just to do it, then the car started acting crazy. To make a long story short, both sensors went out eventually and I went to autozone and got one for like $15 and that solved the probelm
maxinout93 is offline   Reply With Quote
Old 10-17-2009, 01:20 AM   #6
Quote:
Don't forget to add the kilo prefix when measuring it.
Maybe the contacts on the harness is bad? Should try cleaning it. I replaced the temp sensor on my car recently because the fans wouldn't kick in when they started to overheat. But I also noticed that the contacts on the temp sensor had corrosion on it too.
Old 10-17-2009, 01:23 AM   #7
Fans work ok. They kick in if I disconnect the CTS. The needle on the temp guage never goes over half way even when I know the car has overheated, so I have a fault there too.
It's not too easy for me to get parts for this car as they are rare in the UK. I called Nissan parts to be told my car does not exist the other day !!!!
Old 10-17-2009, 01:25 AM   #8
Did you measure the temp sensor when the car is running warm? Because the bad one I had the resistance would stay in the range where the fans would not kick in at all when it's warm.
Old 10-17-2009, 08:04 PM   #9
Way out West
Cliff Clavin's Avatar
Send a message via AIM to Cliff Clavin
Quote:
Did you check to see if there were codes on your ECU?
When my CTS was bad, it actually had a code stored in there for it. No check engine light, though.
You might get someone to buy one for you and have it shipped. They are only about $20 US and they are small so shipping would only be a few dollars. That would be about 14 British pounds with shipping.
__________________
Cliff Clavin is offline   Reply With Quote
Old 10-17-2009, 11:48 PM   #10
yah my ecu threw a code when the coolant temp sensor went bad, I think it was a code 13 or something.
Old 10-18-2009, 03:51 AM   #11
Fans Def work OK because when I pull the harness off the CTS, the fans kick in. I ran the CTS under hot water and the readings seemed OK.
No codes on the ECU
Maybe I'll just replace it anyhow. Will make a trip to the junk yard during the week and see if I can find another Nissan CTS that will fit.
Old 10-18-2009, 04:27 AM   #12
LvR
................... and you know its "overheated" how?
LvR is offline   Reply With Quote
Old 10-18-2009, 07:45 AM   #13
Quote:
Beacuse when I have popped the bonnet it's all much hotter than it should be
Old 10-18-2009, 07:59 AM   #14
LvR
how much "hotter" was it then and how did you determine that? ................. lost-some-skin-off-your-face-by-simply-looking-at-it "hotter" ? ................. or some other degree measured how?
Old 10-18-2009, 08:23 AM   #15
Simply to touch. Sometimes after a 5 min drive the plenum is warm. Other times it has been so hot you can not touch it. Yet the guage reads the same. Also the bonnet can become very hot.
Old 10-18-2009, 09:34 AM   #16
LvR
IMO you are wasting your time chasing a non-existent problem.
Unless you can somehow confirm overheating with eg a infrared thermometer (thermostat housing runs around 85C on a normal 3rd gen in my experience) I don't see any need to spend money on any spares yet and your tests till now basically confirms that too,
FWIW my intake can get as high as 75C on really hot days with town driving near the TB and the actual bits after the TB gets to around 80C+ .................. and its all pretty normal and as expected ......... and my bonnet get to around 50C whn moving - quite a bit higher soon after you stopped and heatsoak starts working
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
