3rd Generation Maxima (1989-1994)Learn more about the 3rd Generation Maxima here.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
So for those of you who dont know, i had my pipes changed starting from the cat to the muffler, and i also changed my front y pipe to a WSP. I had hissing while driving even before that. I had thought it was the stock y pipe, being as old as it is, it needed changing anyways. Even after changing it to the WSP, i still have hissing but even louder. Today i took my car back to the Exhaust shop, the only thing i could think of that is making that hissing sound is the cat, i thought it was a leak. Turns out it was the exhaust manifold, needs a new gasket. If you guys have that same problem, this is what the problem is. i wonder how much its gonna cost hmm.
__________________ Maxima FTW------>
->Kyb gr2 shocks ->Eibach pro springs ->Stillen lip kit ->G35 Sedan dual tip exhaust ->2.25 inch Custom Piping Upgrade->Warpspeed Y pipe ->Power acoustik sound system ->Clarion MAX675VD touch screen head unit->Painted grill ->Intake air filter w/ adapter ->Front Strut bar ->Clear corners ->Promax Hid kit ->Mb motoring Rev rims w/ Kumho exsta AST tires.<-
__________________
1992 GXE l 414,000km on original tranny and original VG30E l Pioneer Premier 12" 3500w subwoofer l 600w amp l JVC H/U l aftermarket fog lights l 2.5" Magnaflow catback exhaust l Momo summer rims l Stock winter rims l Sparco Sprint driver/passenger seat w/drivers 6 point harness l Sparco Volanti steering wheel l Castrol Syntec oil/premium Vpower gas
Future mods- 5spd swap, Z31 turbo w/intercooler
This winters mods- Z31 hood scoop, digital cluster swap, lowering springs
There are two flares where it joints the engine. For me, I remembered they didn't sent me very good gaskets so I ended up using some o2 safe gasket maker instead and it sealed it. The hiss and smoke went away ever since. Check to see if there are a leak somewhere. If you see smoke coming out, it's probably due to poor gasket contact.
Make a solution of washing up liquid and water. When the car is cold, paint the liquid over the exhaust connections and fire up the engine for a bit. If bubbles start appearing, Bingo, you have found the scource of your whistling.
actually, the front manifold was bad too, 3 bolts broke in back manifold and 3 broke in the front manifold so they had to drill out the broken bolts and install new ones, as well as installing the new gaskets. no more hissing. they said 550, but i only gave em 520.
finally sounds like it should, eh?
__________________ PieceOut.FallToPeacesNew to the forum? CLICK HERE!!!! 1985 Nissan 300zx 2-seater: VG30E | 5spd Swap | Bilstein | 5-lug conversion | Polyurethane everything | Resurrection-in-progress! 2004 Honda Civic EX Coupe: 1.7L VTEC | 5spd | CAI soon | LED tails and Projectors soon | ES Poly Motormounts soon | 'bad weather' car/backup for teh Z 1990 Nissan Maxima GXE: VG30E | VLSD-5 swap | Exedy | NWP | a33b(F)/z31(R) BBK | ES poly | SE susp swap | 2k2SE 17s | retired Aug 28th '09 2005 Nissan Maxima SE: VQ35DE | 6spd | Carolina Panthers front lisence plate | Brother's car, not mine | <-- Therefore still 100% stock
Quote:
Originally Posted by JasonOksa
Horsepower, torque and speed are all known by The State of California to cause cancer, birth defects, and reproductive disorders.
Quote:
Originally Posted by bigleman
how much would it cost to resleeve?
how does an aluminum motor form rust on the cylinder walls???
DO NOT PM ME ABOUT PROBLEMS WITH YOUR CAR UNLESS I TELL YOU TO. THAT'S WHAT THE FORUM IS FOR
