Go Back   Maxima Forums > Maxima Discussions > 3rd Generation Maxima (1989-1994)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 10-13-2009, 12:54 PM   #1
keyless entry problem
i have keyless entry installed on my power door locks.. but now only the lock function works.. if i pull the door lock up manually then it works. any help would be really appreciated thanks
1994 maxima (fully loaded)
sams is offline   Reply With Quote
Old 10-13-2009, 02:42 PM   #2
Send a message via AIM to Mysticcal
Door Lock Actuator or Timer.
Do the factory lock / unlock still work?
Could be a wire not making connection as well.
Mysticcal is offline   Reply With Quote
Old 10-13-2009, 10:11 PM   #3
same story with factory locks (unlock dosent work when pressed but lock works.. also if i use the key or manually pull up on the lock it works..
any suggestions how i go about fixing?
Old 10-13-2009, 10:48 PM   #4
Its the timer circuit, its gets broken solder points. Its the small box next to the factory alarm, under the dash to the right of the steering wheel. You can pull it apart and heat all the solder points.
__________________
FS: VE TB for auto
FS: VE lower intake manifold
eric93SE is offline   Reply With Quote
Old 10-23-2009, 08:57 AM   #5
1991 maxima
How do I get combination for door entry
Manny Zaragosa is offline   Reply With Quote
Old 10-23-2009, 01:33 PM   #6
buy a car from him?
internetautomar's Avatar
Send a message via AIM to internetautomar
you don't you need to read the stickies for instructions on how to reprogram it.
__________________
Maxima parts catalog< Website for sale
96 Green A/T gone
94 Pathfinder POS GONE! | 79 Camaro sold
98 I30t Silver on black A/T gone | 96 Granite Pearl (AKA Purple) A/T gone
92 grey VE A/T gone | 96 I30 Black gone
92 maroon VE A/T gone | 92 white VE M/T gone
92 grey VE A/T gone | 6/84 L24E last of the RWD Maxima gone
internetautomar is offline   Reply With Quote
Old 10-31-2009, 10:39 PM   #7
I have the factory keyless entry & the passenger side lock command doesn't work. I have owned a lot of Fords & thought it was wierd that the Nissan even had a passenger side keypad...
Cravacor is offline   Reply With Quote
Old 11-02-2009, 12:26 PM   #8
buy a car from him?
if the only thing not working is the lock command, then you probably need a new keypad
__________________
96 Green A/T gone
Old 11-04-2009, 08:04 PM   #9
1993-VG30E-GXE's Avatar
Is there a way to completely turn off the keyless system alltogether? When it gets cold out my key pad doesn't work (on the driver side), and I have to use the keypad on the passenger side to get in the driver door. And when I put the key in the driver side door, something is preventing me from turning the key to open it the old fashioned manual way.
Want to convert it to the old fashioned manual way.
1993-VG30E-GXE is offline   Reply With Quote
Old 11-07-2009, 07:00 PM   #10
buy a car from him?
fix your door lock and it works normal whether there is a keypad or not
__________________
96 Green A/T gone
Old 11-08-2009, 12:22 AM   #11
How do you take the door lock timer mechanism from its mounting place under the dash, is there a certain wrench or screwdriver to use?? Also what does the keyless entry controll thing do thats located near the passenger side glove box?
maxinout93 is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
