Go Back   Maxima Forums > Maxima Discussions > 3rd Generation Maxima (1989-1994)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 10-12-2009, 10:58 PM   #1
hi
Send a message via AIM to bvtran
door lock timer
I re-soldered my door lock timer today but the problem still persists. When I press the lock/unlock switch, it makes clicking sounds so this tells me the relay inside the door lock timer is working fine and there are current coming from the switch. What could possibly went wrong then, any suggestion? Oh yeah, when I looked inside the door lock timer, it looked fine. There were no burn components, all the data bus were well connected but I resoldered them anyway. It didn't really make any difference. My power lock is still not working.
bvtran is offline   Reply With Quote
Old 10-13-2009, 08:51 AM   #2
Send a message via AIM to Mysticcal
Main Control on Drivers Side can also go bad.
also test if you press in the white plug at a different angle or pressing it harder if it works. bad contacts is also possible. clean with alcohol / use di-electric grease.
I'm working with the same problem and I picked up a driver's control recently so I'll test my findings.
Mysticcal is offline   Reply With Quote
Old 10-13-2009, 10:23 AM   #3
2 VE's are better than one!
Yeah, 90% of the time the problem is the door lock timer itself. I picked up about 10 door lock timers over the years at junkyards trying to fix my door lock issue, and not one of them worked.
Then finally I figured out that the problem was actually my main driver door switch, and once I swapped that out I tested all of those door lock timers I had collected and 5-6 of them were actually good!
__________________
Desperately looking for a 5 speed axle carrier bracket. Either VG or VE will work. PM me if you have one!
Good working door lock timers $20 shipped. PM me if interested
James92SE is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
