Go Back   Maxima Forums > Maxima Discussions > 3rd Generation Maxima (1989-1994)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 10-11-2009, 09:24 AM   #1
Injector readings
Anyone know what the readings should be for the injectors? Searched and couldn't find.
Think mine are a bit shot. Im getting 12ohm on two, 100-150 on another two and around 40-50 on the last two
Shouldn't they all be around 12-13 ohm?
W00dface is offline   Reply With Quote
Old 10-11-2009, 09:48 AM   #2
Call me Wookiee Goldberg
CapedCadaver's Avatar
yea yours are fawked. unless the pins are dirty and your multimeter isn't making a good connection when you were testing them
__________________
PieceOut.FallToPeaces New to the forum? CLICK HERE!!!!
1985 Nissan 300zx 2-seater: VG30E | 5spd Swap | Bilstein | 5-lug conversion | Polyurethane everything | Resurrection-in-progress!
2004 Honda Civic EX Coupe: 1.7L VTEC | 5spd | CAI soon | LED tails and Projectors soon | ES Poly Motormounts soon | 'bad weather' car/backup for teh Z
1990 Nissan Maxima GXE: VG30E | VLSD-5 swap | Exedy | NWP | a33b(F)/z31(R) BBK | ES poly | SE susp swap | 2k2SE 17s | retired Aug 28th '09
2005 Nissan Maxima SE: VQ35DE | 6spd | Carolina Panthers front lisence plate | Brother's car, not mine | <-- Therefore still 100% stock
Quote:
Originally Posted by JasonOksa View Post
Horsepower, torque and speed are all known by The State of California to cause cancer, birth defects, and reproductive disorders.
Quote:
Originally Posted by bigleman View Post
how much would it cost to resleeve?
how does an aluminum motor form rust on the cylinder walls???
DO NOT PM ME ABOUT PROBLEMS WITH YOUR CAR UNLESS I TELL YOU TO. THAT'S WHAT THE FORUM IS FOR
CapedCadaver is offline   Reply With Quote
Old 10-11-2009, 10:03 AM   #3
I cleaned them all off before testing and the conections seemed good.
Off to the brakers I go tomorrow then. At least I might solve the problem of it running a little rough now.
Old 10-14-2009, 06:29 AM   #4
OK now im a little confused....
I have the VG30E in my UK SE. The injectors have black dots.
According to some websites I have been on (an I think i read it somewhere here in the forum) I should be using yellow dotted injectors.
Also anyone know if my injectors were used in any other nissan as I have trouble getting parts over here.
Old 10-16-2009, 06:32 PM   #5
should be 10 to 14 cold lower numbers hot higher numbers se dohc takes the red injectors and I believe the sohc takes the yellow or brown color injectors as far as I know,I just had this problem with bad injectors one read 73.2 and one read 24.5 I relaced them both and my car runs great with plenty of power even with 200,000 on the clock and I still have to replace 2 coils that have 2 cracks each
jona571 is offline   Reply With Quote
Old 10-19-2009, 09:15 PM   #6
Send a message via AIM to wcpierson
Ive been trying to research this also..I cant seem to find a write up on testing the injectors and what the normals should be. I have a 1993 GXE SOHC and I have some low rpm hesitation issues. Also the car always smells like gas. Im trying to figure out what is wrong with my car and I was told the injectors were a common problem in these cars and I need to figure out how to test them. Can someone post any advice or links for me to read up on. Please
wcpierson is offline   Reply With Quote
Old 10-20-2009, 07:24 AM   #7
buy a car from him?
internetautomar's Avatar
Send a message via AIM to internetautomar
if the car smells like gas you need to pull the intake manifold and replace ALL your rubber lines in the engine compartment.
__________________
Maxima parts catalog< Website for sale
96 Green A/T gone
94 Pathfinder POS GONE! | 79 Camaro sold
98 I30t Silver on black A/T gone | 96 Granite Pearl (AKA Purple) A/T gone
92 grey VE A/T gone | 96 I30 Black gone
92 maroon VE A/T gone | 92 white VE M/T gone
92 grey VE A/T gone | 6/84 L24E last of the RWD Maxima gone
internetautomar is offline   Reply With Quote
Old 10-21-2009, 06:57 PM   #8
crack coils>need imput also
I have 2 coils with 2 cracks each, is this arcing in the plug area cos my car seems to run fine even with the cracked coils,so do I need to replace these anyway??
Old 10-22-2009, 07:16 AM   #9
buy a car from him?
Quote:
at the very least you should fill the crack with silicone and wrap the coils in electrical tape.
__________________
96 Green A/T gone
Old 10-23-2009, 05:37 PM   #10
ok thanks so the cracked coils are not working 100%
Old 10-24-2009, 09:51 PM   #11
buy a car from him?
correct
__________________
96 Green A/T gone
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
