Go Back   Maxima Forums > Maxima Discussions > 3rd Generation Maxima (1989-1994)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 10-07-2009, 07:47 AM   #1
dash motor problem....?
i have a 93 VE and recently the needles haven't been working on the dash. Now on a different maxima i've changed the odometer motor, but in this max the odometer doesn't work, the tachometer doesn't work, the speedometer DOES, the gas DOES, and i'm not sure if the temp does or doesn't. (i start up the car every couple weeks for about 15-20 minutes. I haven't driven it anywhere recently so i don't know if the temp needle does or doesn't work). So my question is, are some of these needles all powered by the same motor or are they all bad due to something different?
Its looking like i'll need to buy a dash....
jruss1601 is offline   Reply With Quote
Old 10-07-2009, 10:15 AM   #2
I had to replace the motor in my RPM gauge. They all run on different motors. There is one for each gauge. They are easy to change.
__________________
120,000 Miles And Still Going Strong
Mods
CAI, Spoiler, BMW Headlights, Angel Eyes, New Paint Job, Rebuilt Transmission, 1,800 Watt Speaker System,
projectviper255 is offline   Reply With Quote
Old 10-13-2009, 10:18 AM   #3
Quote:
So i found out my needles all do work except the tac. I heard its probably a loose wire due to moving while starting the car, but doesn't move while car is running. Would it still be the motor?
Old 10-13-2009, 10:55 AM   #4
your issue is almost as similar to mines because all my gauges work except my damn Temp gauge which works when it wants to...it usually jumps back to working if i thump the cluster right at the center of the temp gauge lever but only for a short while tho lol...any ideas from .org gurus?
__________________
89 Maxima Aged and Experienced With 310k On The Dash Has Been Reborn!
Thanks CapedCadaver With My Motor Swap....We Both Went Thru Hell to Make It Run Again lol!
VG30E...2.5" Custom Catback to 3" Muffler...18" S-Tech Black on Chrome Wrapped in Pirelli P-Zero 215/35R18...2-10"JL Audio Powered by a Soundstorm 3600/1...5 x1/4's and 6x9's Powered by JVC 400/4 with Jensen 7 1/2 Flip-Out Touch Screen
MaximaFan4140 is offline   Reply With Quote
Old 10-13-2009, 02:08 PM   #5
Could be bad contacts with the motor screws/harness on the printed circuit so check on that.
You can also try changing the sensitivity on the tach. There is a knob on each of the circuit board of the motor where the tach sensitivity can be changed. But remember the reading that your old tach gave out because I really don't know how you can get an accurate RPM reading to adjust it (...well on a VG). If someone knows, maybe I can be sure that I set it up correctly.
When I changed from my 89 GXE gauges to 94 GXE the first time the tach wouldn't work. I messed with the knob and it started working. Took me some time to adjust it to the closest reading that matched on my last gauge. I did that about two weeks ago and since then it has only happened to me twice where the tach would suddenly stop working and start working again for the first week. Knock on wood that it won't happen again.
jbbons25 is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
