Go Back   Maxima Forums > Maxima Discussions > 3rd Generation Maxima (1989-1994)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 10-06-2009, 04:10 PM   #1
Send a message via AIM to -ReLLiK- Send a message via Yahoo to -ReLLiK-
When Purchasing a High Mileage VE...
What should be some important things to look for/ask about? Ive been searching high and low for a lower mileage VE 5sp, but the best i could come by was 169k.
Also, are the VE engines any more reliable than the VG? After finding my VG with 126k miles and only replacing the alternator since, I dont know if purchasing a higher mileage maxima would be a good idea or not...
-ReLLiK- is offline   Reply With Quote
Old 10-06-2009, 04:37 PM   #2
2 VE's are better than one!
The VTCs is what everybody throws out, but I think aside from the embarrassment you might experience if you don't ground them, it's really not an issue. I think the general consensus 10 years ago was that it was considered to be a major reliability problem with the VE, but I think nowadays the thinking on that is different. It's mostly just a nuisance, and I think the track-record of grounding them proves that it's not really a reliability issue.
(However, there HAVE been a few exploding VTCs that took out the timing chains/covers, but those seem to be isolated cases of letting clattering VTCs go far too long with no attention.)
Personally, one of my VE's has just under 200k now and I haven't had one problem with it mechanically ever. Aside from things like water pump, etc. I've never had to touch the engine. The engine even has super low compression in one cylinder (was like that when I got it) and still put down 180 whp a few years ago, gets good gas mileage, runs great, etc. VTC's have been grounded for 6 years now. I run synthetic in it and the valvetrain looks brand new
My "new" VE has 160k and runs like it's brand new. Judging by the valvetrain, it doesn't even look like the previous owner took very good care of it. I recently replaced a rear injector and the knock sensor, and it's incredibly smooth and quiet, plus has no VTC tick, etc.
I think Matt got well over 220k out of his original VE even while flogging it constantly at genuine track events, etc.
I really personally feel the VE is a reliable engine. I think the VG gets that reputation simply from volume (and deservingly so), but I think reports that the VE is a finicky one-off type engine are highly exaggerated.
Really, when purchasing a "high mileage" VE it's probably not any different than purchasing a high mileage car of any type. It's all up to how the previous owner maintained it. Other than that, and aside from the VTCs, the front coil packs are known to crack/cause a misfire, knock sensors go bad, and the VE seems to have a little more trouble passing emissions. VE injectors seem to be more a bit more reliable than VG injectors. When VE's get misfires, it seems some people have trouble correcting it, but it's not clear if it's an issue with the VE or an issue with people not properly going about fixing it (personally I tend to believe it's usually the latter). There's probably a bunch more but that's all I can think of at the moment
Heck, you might want to pick up that VE 5. You may not find another
__________________
Desperately looking for a 5 speed axle carrier bracket. Either VG or VE will work. PM me if you have one!
Good working door lock timers $20 shipped. PM me if interested
James92SE is offline   Reply With Quote
Old 10-06-2009, 05:55 PM   #3
Dam bro thanks for that info, that really helped. Is it true that when grounding VTCs, you have to run premium fuel? And yea im from Ohio (i currently go to school at Lincoln Tech in indianapolis) and neither place requires emissions tests.
heres link to the posting. theres a couple probs here and there, but it doesnt seem too bad to me. http://columbus.craigslist.org/cto/1401868161.html
Old 10-06-2009, 06:03 PM   #4
No, you have to run premium fuel when you advance the timing but not when you ground the VTC's. When grounding the VTC's you literally just ground them and forget about them
I tried to view the link but it's been removed. Hopefully it's not sold out from under you?
__________________
Old 10-06-2009, 06:09 PM   #5
Oh ok. wow lol. Well what causes the VTCs to tick in the first place?
And its still there when I clicked. here ill try again. http://columbus.craigslist.org/cto/1401868161.html
Old 10-06-2009, 06:18 PM   #6
Call me Wookiee Goldberg
CapedCadaver's Avatar
i thought on a VE it was essentially required to run premium all the time
__________________
PieceOut.FallToPeaces New to the forum? CLICK HERE!!!!
1985 Nissan 300zx 2-seater: VG30E | 5spd Swap | Bilstein | 5-lug conversion | Polyurethane everything | Resurrection-in-progress!
2004 Honda Civic EX Coupe: 1.7L VTEC | 5spd | CAI soon | LED tails and Projectors soon | ES Poly Motormounts soon | 'bad weather' car/backup for teh Z
1990 Nissan Maxima GXE: VG30E | VLSD-5 swap | Exedy | NWP | a33b(F)/z31(R) BBK | ES poly | SE susp swap | 2k2SE 17s | retired Aug 28th '09
2005 Nissan Maxima SE: VQ35DE | 6spd | Carolina Panthers front lisence plate | Brother's car, not mine | <-- Therefore still 100% stock
Quote:
Originally Posted by JasonOksa View Post
Horsepower, torque and speed are all known by The State of California to cause cancer, birth defects, and reproductive disorders.
Quote:
Originally Posted by bigleman View Post
how much would it cost to resleeve?
how does an aluminum motor form rust on the cylinder walls???
DO NOT PM ME ABOUT PROBLEMS WITH YOUR CAR UNLESS I TELL YOU TO. THAT'S WHAT THE FORUM IS FOR
CapedCadaver is offline   Reply With Quote
Old 10-06-2009, 06:18 PM   #7
There's basically a spring inside that fatigues over time and the ticking/clacking noise is actually caused by the spring.
When I click on your link it says it's been deleted by the author, but if I go straight to Columbus Craigslist I can find it that way. He said in the ad he'll basically remove it when it's sold so I wonder if it's just sold and he's in the process of deleting it (since it takes longer to be removed from the main section)
edit - I figured out what he did. He deleted his old post and just now posted a new one so it'd be at the top of the listings
__________________
Old 10-06-2009, 06:22 PM   #8
Quote:
Nah, it's just preferred
I've been running 87 octane in my original VE for about a year now. Only difference I've noticed is it gets slightly worse gas mileage, but not bad enough that it financially makes it worth while to run premium.
__________________
Old 10-06-2009, 06:28 PM   #9
i'd like to see what the dyno charts would say about 87 vs 93.
__________________
Old 10-06-2009, 06:39 PM   #10
Yea because I called the guy like a half hour ago or so and he told me he was actually about to lower the price . But what do you think? is it worth it??
Me too. In my gas engines class, my teacher said that premium fuel is more required for engines with higher compressions, like V8s or on forced induction applications. So whats the compression ratio on the VEs?
Old 10-06-2009, 06:51 PM   #11
Sure sounds like it to me for $900 unless it has some unlisted catastrophic problem. $900 is a more than good deal. Since he was about to lower it anyway, offer him $800 and see what he says. Either way, $900 is a great deal.
Heck, even if the engine didn't run or something crazy, for a few hundred less you'd still have a fair price. I recently paid $1400 for my "new" VE 5 with ~160k.
Keep in mind though, I'm one of the biggest pro-VE/pro-keeping old cars guys on here. Some other people on here would probably tell you that $900 for a near 20 year old car that is gonna need maintenance blahh blah blah blah isn't worth it. But it's all relative. Plus, I'm right.
But either way, I don't think anybody would disagree that $900 is a great deal barring some catastrophic problem. Even if it needs a fair amount of work, it's still a fair deal
I'm sure you'd see a difference. I was running 93 when I dyno'd.
Keep in mind, there's many parts of the country that can't even get 93 octane, so there's an abundance of VE's going around that have been running 87 octane all their lives. Heck, there's parts of the country that have 85 octane even. So there's probably a good many VE's/3rd gens going around with 85 octane
I ran 93 exclusively until about a year ago when I just got sick of paying sometimes near 4 bucks for it. It's less expensive now but still near 3 bucks for 93 vs a bit under $2.50 for 87
__________________
Old 10-06-2009, 06:56 PM   #12
v8 doesn't automatically mean you need premium... the compression ratio, air/fuel ratio, and ignition timing have alot to do with the engine's tendency to ping/knock, so you remedy that with higher octane. so does climate (more likely to ping when it's hot out than when it's cool out)
VG is 9:1, VE is 10:1 btw
__________________
Old 10-06-2009, 06:58 PM   #13
^^^you said one of your cylinder's has low compression? you still have the car?
__________________
1992 maxima SE auto 159k (r.i.p)
1992 maxima SXE 174k
1991 infiniti Q45 158k
1997 maxima SE 115K
1992maximase30 is offline   Reply With Quote
Old 10-06-2009, 07:08 PM   #14
Quote:
Yes, my original black VE that I bought from flyry on here 7 (?) years ago has low compression in one cylinder and I still have it and drive it. About a year after I got it we did a compression test on it just for fun and discovered it. Driving it you'd never know the difference. It's the one that put down 180whp, has just under 200k, and that I now run 87 octane in.
__________________
Old 10-06-2009, 07:12 PM   #15
my old ve had 50 psi in cylinder 5. once i replaced injectors. did knock sensor bypass replaced the motor mount you could hardly feel the miss.
and it seemed that cylinder "worked" fully, above 1500rpms.
__________________
1997 maxima SE 115K
Old 10-06-2009, 07:24 PM   #16
VEs come stock with 190hp, correct?
Old 10-06-2009, 07:33 PM   #17
yep
__________________
1997 maxima SE 115K
Old 10-07-2009, 12:06 AM   #18
heck If you ever need a transmission for a VE Auto, they are not hard to find, and are plentiful. Its finding a VG transmission thats a challenge. Wish I would have gotten a VE!
maxinout93 is offline   Reply With Quote
Old 10-08-2009, 04:12 PM   #19
Ok so here's a curveball for you guys... Which is better to turbo: VG? Or VE?
Old 10-08-2009, 04:30 PM   #20
VG can take more boost since it's got lower compression, plus the z31 turbo manifolds bolt up to the engine. With a VE, everything is custom.
__________________
Old 10-14-2009, 10:39 PM   #21
2961cc
VEvolution's Avatar
Send a message via AIM to VEvolution
Im pretty sure the FSM requires 91, but since theres no 91 around here, 93 is the obvious choice.
__________________
FS: My black 92' VE 5spd
http://forums.maxima.org/maximas-sal...2-ve-5spd.html
VEvolution is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
