Go Back   Maxima Forums > Maxima Discussions > 3rd Generation Maxima (1989-1994)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 10-06-2009, 01:02 AM   #1
1993-VG30E-GXE's Avatar
Hot Sauce on Your Harness Connectors
Am I wrong or did some guy on here last yr say that Frank Red Hott dissolves corrosion great on those brass or copper contacts in the harness connectors?
Or was it cola or something?
1993-VG30E-GXE is offline   Reply With Quote
Old 10-06-2009, 02:26 AM   #2
Oh! I remember seeing this on Mythbusters. They put like salsa on jailhouse bars to try and dissolve them and it worked I guess, but they had to electrically charge the salsa and all that.
__________________
1997 Nissan Maxima GLE
Leo_Koneval is offline   Reply With Quote
Old 10-06-2009, 06:35 AM   #3
Send a message via AIM to kringle03
Sprite does pretty good on copper...
__________________
kringle03 is offline   Reply With Quote
Old 10-06-2009, 10:34 AM   #4
Send a message via AIM to tresboi Send a message via Yahoo to tresboi
Anything containing a relatively high pH citric acid works well on copper. I use a mixture of salt and lemon juice to clean the copper bottoms on my cookware at home. Ounce for ounce, you come out about the same using electrical contact cleaners, whether they be in a spray can or a pen. Might as well use the solvent created for that purpose as opposed to trying out home remedies.
__________________
Aztec Red 92 SE 5spd - 'JDM' VE swap/ASP UDP/NWP Phenolic Spacers/8 awg engine grounds/WarpSpeed Y & B/CAI/SuspensionTech 1.5" drop/KYB GR-2's/Exedy clutch kit/FSTB/BlehmCo RSTB & Stage 1 LTB/GXE power seats/4th Gen SE wheels on Kuhmo Ecsta 225/50R16’s
tresboi is offline   Reply With Quote
Old 10-06-2009, 01:26 PM   #5
RMAX54's Avatar
Send a message via Yahoo to RMAX54
Quote:
The 'Real Deal' is a product called Deoxit. Comes in a 100% strength solution called D100L, and a 5% aerosol. I'm using the full strength D100L on my injector connectors now - cleans all the crud off down to bare metal - shiny copper. Do a Google seach on Deoxit, and you'll find lots of places selling it.
__________________
'90 SE 5sp, Intake=WSP midpipe +JWT Pop; Exhaust=WSP Y-Pipe+ WSP B-pipe+Rative Tip; FTSB, Bridgestone Potenza RE950s.
RMAX54 is offline   Reply With Quote
Old 10-06-2009, 01:55 PM   #6
the corrosion is basic so a acid will get rid of it, i would imagine diluting some vinegar in water will do the same thing as hot sauce
Pop is acidic also so it would work, but wouldnt it be sticky after?
__________________
1992 GXE l 414,000km on original tranny and original VG30E l Pioneer Premier 12" 3500w subwoofer l 600w amp l JVC H/U l aftermarket fog lights l 2.5" Magnaflow catback exhaust l Momo summer rims l Stock winter rims l Sparco Sprint driver/passenger seat w/drivers 6 point harness l Sparco Volanti steering wheel l Castrol Syntec oil/premium Vpower gas
Future mods- 5spd swap, Z31 turbo w/intercooler
This winters mods- Z31 hood scoop, digital cluster swap, lowering springs
chrome91 is offline   Reply With Quote
Old 10-06-2009, 02:39 PM   #7
i always use WD40 then ad connector grease. seem to work fine
__________________
1991 GXE Resurrected from the dead
1989 SE gutted for parts and 5 speed.
300zmax is offline   Reply With Quote
Old 10-06-2009, 03:42 PM   #8
RMAX54's Avatar
Ever thought about what acid might do to the plastic on the injector? The injector plug? Wire Insulation? Anything else you might spill it on while leaning over your engine? The results will vary with what type of acid you use.
I've bought my '90 SE 5 SPeed new - and I've fought the injector connector corrosion problem well over a decade. Tried everything; WD40, ChemTool, vinegar, baking soda soln, various electrical contact cleaner products along with dental picks, emory boards, you name it. Some worked just well enough to give either give intermittent operation of the injector -or- lasted only a few short months before I had to do it again.
Nothing gave a clean lasting metal electrical contact without harming other parts except DeoxIT. I follow that up with Coppershield on both sides of the contacts to prevent further corrosion.
__________________
Old 10-06-2009, 08:57 PM   #9
I think that may have been me who got the idea for, and tried the hot sauce'd injector connectors.
Sorry to report, that it didn't work too well. I used brake parts cleaner before hand to clean off the old dielectric grease and other contiminants. Then I did the hot sauce treatment. I followed up after the hot sauce with baking soda and water, but all that didn't get the job done. I noticed there was a "crust" that needed to be scraped off mechanically to restore the fresh metal terminals. And I noticed some "green" growth inside some of the really bad ones... like what you might see around battery terminals that are corroded. Bad stuff!
I ended up disconnecting the injector terminals from the plastic connectors (that part is actually quite tough... you can't just force them out! got to release the tab "just right") and then mechanically scraped the surfaces with a precision screwdriver. That is the only thing that has worked for me. And I bent the connectors so they would give a really good "pinch" to the injector terminals.
I was all set to cut the connectors off completely and solder on new connectors I sourced from the dealer, but ended up being satisfied enough with my manually restored, old connectors that I am just running those for now. No misfires yet... engine is running great.
jakeru is offline   Reply With Quote
Old 10-06-2009, 10:13 PM   #10
Send a message via AIM to Stwodahorty
put some tapitio on that ishhh jp
__________________
Maxima FTW------>
->Kyb gr2 shocks ->Eibach pro springs ->Stillen lip kit ->G35 Sedan dual tip exhaust ->2.25 inch Custom Piping Upgrade->Warpspeed Y pipe ->Power acoustik sound system
->Clarion MAX675VD touch screen head unit->Painted grill ->Intake air filter w/ adapter ->Front Strut bar ->Clear corners ->Promax Hid kit ->Mb motoring Rev rims w/ Kumho exsta AST tires.<-
Stwodahorty is offline   Reply With Quote
Old 10-07-2009, 04:37 AM   #11
you dont want food smells,they attract rodents
__________________
91 se"magic stick",92 se"relaxima
maximagician is offline   Reply With Quote
Old 10-07-2009, 06:25 AM   #12
Ad·min·is·tra·tor
DanNY's Avatar
Quote:
kinda looks like ATF
DanNY is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
