Go Back   Maxima Forums > Maxima Discussions > 3rd Generation Maxima (1989-1994)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 10-05-2009, 02:30 PM   #1
Send a message via AIM to kringle03
TPS malfunction or Transmission?
Well much has happened to my max in the past few months (I'll update my threads on that later) but I'm having an issue with a shudder or shake at certain speeds and RPMs. 45mph and 65~85mph. Letting off or stepping on the gas will make it go away... though if it was just at 45mph I wouldn't care since I'm not going that slow to often.
Note: I just replace engine and transmission. My max had this issue prior to the swaps BUT it was ONLY at the 45mph mark.
I've done some searching and looking around; most point to the TPS being the culprit. Though there's a remote possibility that the tranny could be at fault too.
Regardless, these are my TPS readings:
Closed = .817KOhms
2/3 Open = 3.86KOhms
WOT = 6.34KOhms
It seems a little lower than what should be expected for the TPS, but is it significant enough to be considered a failure? I'd like to spend less money on this fix than having the shop pull the tranny for R&D.
Thanks!
Also Note I have cleaned out the TPS (Wikings instructions of flooding the compartment with electronics cleaner and resealing).
__________________
kringle03 is offline   Reply With Quote
Old 10-06-2009, 12:53 AM   #2
1993-VG30E-GXE's Avatar
Yikes, that's a big buzz kill - you did the tranny AND the engine and it's still breaking? Your giving me ideas in my head.
I take it your like me and you've replaced almost every single part by now.
1993-VG30E-GXE is offline   Reply With Quote
Old 10-06-2009, 06:34 AM   #3
Close to it... this is just a major annoyance... and I'm heading up to Dallas soon for training and I want this out of the way before I head up there...
So any suggestions folks?
The adjustment screws on the TPS allow you to slide the box forward and back correct? That should be how you achieve the different voltages if it needs adjustment?
__________________
Old 10-07-2009, 04:50 AM   #4
i think it can be adjusted with ecu mode ?1 or 2 "switches on and off mode"
the check engine light comes on when it senses you move the gas pedal
if its adjusted right
__________________
91 se"magic stick",92 se"relaxima
maximagician is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
