Go Back   Maxima Forums > Maxima Discussions > 3rd Generation Maxima (1989-1994)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 10-05-2009, 11:26 AM   #1
1993-VG30E-GXE's Avatar
Has Anyone Successfully Coverted VG30E Exhaust Ports to M10 Studs?
Taking my cylinder head to another machine shop today. A EZ-Out is broken inside the stud and it's too hard for me to do it by hand, i've already enlarged the hole sightly at near the surface. 2 Shops had it and they wouldn't do it, but I found a guy who says they can do it.
He said they usually move the holes one size up, instead of an insert, so I'm wondering if anyone has done all the holes to M10 and everything fit fine.
1993-VG30E-GXE is offline   Reply With Quote
Old 10-05-2009, 12:52 PM   #2
STFU n00b!
Might look at the twin turbo studs- I'm not sure if they're M10 or not. I'd be wary of going much bigger than stock though. It's not far from the water jacket on some cylinders.
Find a shop that can do an EDM on it. it won't be cheap, but they can get it out without FUBARing the head. search for machine shops and EDM in your area. should be able to find one somewhere.
__________________
04 G35 Sedan 6MT- The DD
96 240SX 5 speed- The track toy
93 Maxima SE 5 speed- retired 1-5-09
Check out the toys I make on my website!
Matt93SE is offline   Reply With Quote
Old 10-05-2009, 03:07 PM   #3
I just talked to the shop - even more unexpected cost now. The exhaust manifolds need to be decked on some belt type machine. When we put them on the bare metal they were rocking from left to right - the center flange on both seems to be raised higher then the outside ones. Thank god we put them on there just to check the stud - could you image if I put it back together after using the straight edge on the head but didn't think of using it on manifolds. The sound would STILL be there - put put put put.
Old 10-05-2009, 05:35 PM   #4
STFU n00b!
Yup. it's pretty common for the manifolds to warp over time when you keep driving on broken studs. it shouldn't cost you more than $50 to have it surfaced.
__________________
Old 10-07-2009, 04:10 PM   #5
2 of my exhaust manifold studs broke flush so i took it to the shop today and their going to take the studs out and put new gaskets and new studs all for $200
nyc_ink is offline   Reply With Quote
Old 10-07-2009, 04:15 PM   #6
STFU n00b!
damn that's a good deal... price on just the parts is $150 or so if you get it all from the dealer.
__________________
Old 10-07-2009, 04:23 PM   #7
yea the guy is real cheap and he has big shop. im getting my mufflers installed there too, im a get two mufflers one on each side.
Old 10-07-2009, 05:15 PM   #8
Really? That must be a big shop - he has the machine shop AND they do mufflers too? Most of the machine shops i've visited are just pure machining - I'm going to try and post some photos. Any photos of the huge shop?
Old 10-07-2009, 05:58 PM   #9
ill take some tomorrow when i pick up the max
Old 10-07-2009, 06:10 PM   #10
off topic real quick, can some one please answer my question in the noobie sticky thread. the post is #4271
Old 10-07-2009, 06:48 PM   #11
Beleive it or not, for yrs, the only thing holding my exhaust manifolds on were 3 hex nuts PER side. New there are 6 per side. So basically I had leaks on pretty much each port. No wonder the manifolds warped. I'll try to take a photo of the black buildup on the ports, looks like it tries to escape out the side.
Old 10-07-2009, 06:51 PM   #12
i had to get mine fixed asap cuz it leaked exhaust and it smelled real strong and it made an ugly a$$ sound when i accelerated
Old 10-08-2009, 10:30 PM   #13
just picked up the max from the shop and the broken studs were taken out and everything got replaced.
pics of the shop for 1993-VG30E-GXE
left side of the shop
right side of the shop
Old 10-10-2009, 12:29 AM   #14
Thought I saw some OBX headers over on the right side wall!!!
__________________
CMax03 is offline   Reply With Quote
Old 10-10-2009, 02:11 AM   #15
Send a message via MSN to burhan92SE
Quote:
u have 1990 NISSAN MAXIMA GXE with VG Engine....and that digital cluster and sonar adjustable suspension are VERY RARE in Maximas u dont find them everyday....u probably have BOSE sound system, auto climate control and leather seats as well....ur Max is fully loaded with everything ever came in 3RD GEN Maxima except high output VE Motor which arrived in 92 to 94 only...
__________________
WANT MAXIMA ON FACEBOOK? click here http://www.facebook.com/home.php#/gr...id=40968904022
Selling my VG --->http://forums.maxima.org/canadian-cl...m-edition.html
burhan92SE is offline   Reply With Quote
Old 10-10-2009, 09:48 AM   #16
Quote:
yea i have all that u mentioned, i want to get an engine swap but dont know which one to get.
the sonar adjustable suspension, i know nothing about it please tell me about it if you know. cause if i change my shocks how would i get them to work in the adjustable way.
Old 10-10-2009, 07:21 PM   #17
No turbo, no care!
Maxpwer's Avatar
Send a message via AIM to Maxpwer
Sorry to get back on topic....... but the VG33 engines all had M10 exhaust manifold studs so it shouldn't be an issue to convert the VG30 studs from M8 to M10. However, as Matt93se stated the bolts are very close to the coolant ports so be SURE not to drill any deeper than the stock holes.
__________________
Quote:
Originally Posted by 1993-VG30E-GXE View Post
OH ****E - does this mean I have to REPLACE the radiator, if I move to the 0.50MM oversize, because the OEM radiator might not be able to handle the added heat?
Maxpwer is offline   Reply With Quote
Old 10-10-2009, 07:36 PM   #18
I picked up my exhaust manifolds and the guy did a pretty good job - less than .005" flatness. It came out to more than expected though, total cash deal came out to $150.00, decking both manifolds and removing the broken stud + easy out inside it. I even asked him to throw the cylinder head in the cleaning booth and he did it for free.
It appears the M10 studs can work, but I'm not sure if one could use a torque wrench to finally attach them. If doing by hand though it would likely fit, or maybe with a crowfoot. He said just to leave the remaining ones as M8, as the cost would have been much higher for him to enlarge all the holes. He said the center flange was way off on each one, like 2mm off from the warping.
(The setup was preset to not go deeper than the original depth)
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
