Go Back   Maxima Forums > Maxima Discussions > 3rd Generation Maxima (1989-1994)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 10-02-2009, 01:36 AM   #1
Timing Belt: Square Teeth to Round
I am wondering if it's possible to convert the the square teeth version of the timing belt to the round version? The three sprockets seem to be removable and a different spring for the tensioner needs to be used. Will it be worth to convert it?
jbbons25 is offline   Reply With Quote
Old 10-02-2009, 07:31 AM   #2
Call me Wookiee Goldberg
CapedCadaver's Avatar
i didn't anything about a different tensioner spring, but you're right about that. other than that all you gotta do is swap the sprockets. the round tooth belt is 100k rather than 60k, so if you really think there's a chance of you putting another 100k on your Max then yes. Otherwise it's just added expense. Says he who is converting to a round-tooth belt on his z31 .
__________________
PieceOut.FallToPeaces New to the forum? CLICK HERE!!!!
1985 Nissan 300zx 2-seater: VG30E | 5spd Swap | Bilstein | 5-lug conversion | Polyurethane everything | Resurrection-in-progress!
2004 Honda Civic EX Coupe: 1.7L VTEC | 5spd | CAI soon | LED tails and Projectors soon | ES Poly Motormounts soon | 'bad weather' car/backup for teh Z
1990 Nissan Maxima GXE: VG30E | VLSD-5 swap | Exedy | NWP | a33b(F)/z31(R) BBK | ES poly | SE susp swap | 2k2SE 17s | retired Aug 28th '09
2005 Nissan Maxima SE: VQ35DE | 6spd | Carolina Panthers front lisence plate | Brother's car, not mine | <-- Therefore still 100% stock
Quote:
Originally Posted by JasonOksa View Post
Horsepower, torque and speed are all known by The State of California to cause cancer, birth defects, and reproductive disorders.
Quote:
Originally Posted by bigleman View Post
how much would it cost to resleeve?
how does an aluminum motor form rust on the cylinder walls???
DO NOT PM ME ABOUT PROBLEMS WITH YOUR CAR UNLESS I TELL YOU TO. THAT'S WHAT THE FORUM IS FOR
CapedCadaver is offline   Reply With Quote
Old 10-02-2009, 09:25 AM   #3
Send a message via AIM to kringle03
Ah... so that is the main reason that conversion happened?.... That's good to know... The motor I just dropped in was from a 94 Max with the round tooth... THX for the info!
__________________
kringle03 is offline   Reply With Quote
Old 10-02-2009, 09:49 AM   #4
Quote:
yea basically. i know the vg33 pathy had a round toothed belt also. that's actually the belt i'm using on my z. good thing he pointed out the spring difference; i got the one for the square belt so now i gotta order the right spring! but i had a bunch of other stuff to order from Courtesy anyways so i'll just get it with those items.
__________________
Old 10-02-2009, 12:52 PM   #5
1993-VG30E-GXE's Avatar
Quote:
Hey buddy -
I don't think it's worth it. I came to the same question, but unless you can find those sprockets easily (3) and you already are dong the timing belt on yours, it's not worth the work.
Basically, your going to have to go to the yard and get those sprockets off (unless you buy them new - courtesy?), and fiddle through that hole in the wheel well to get the timing belt cover off, or you could hack it off some how - just rip it apart, that's what I would do but it's still a pain and not worth it in my opinon. The harmonic balancer will also have to come off in the yard too.
1993-VG30E-GXE is offline   Reply With Quote
Old 10-02-2009, 07:59 PM   #6
Quote:
Originally Posted by 1993-VG30E-GXE View Post
Hey buddy -
I'm gonna change the timing belt when it hits 290K miles and right now it barely hit 279K so I got some time. Most likely I will look for the top two sprockets at the junk yard and order the bottom one from Courtesy. Worse comes to worst Nissan doesn't carry it anymore and have to look for it at the yard too.
Tomorrow and Sunday there is a half off sale at my local junk yard so I should take advantage of it.
Old 10-02-2009, 09:39 PM   #7
No turbo, no care!
Maxpwer's Avatar
Send a message via AIM to Maxpwer
When it comes to the crank sprocket, its often has to be destroyed to get it off because its rusted to the crank. If this is the case then and you must order a new one, you might as well get the round tooth one since thats half the cost of the conversion right there. I was able to find someone who had already pulled the round tooth cam sprockets off a pathfinder and picked them up for around $30.
If you would rather get them from a junkyard to save a little money, getting the top cover off the timing belt is the easy part, the bottom is a lot more difficult. I personally think that its worth the time and money regardless if you keep your car for another 100k or not. If you sell the car as a whole or just the engine sometime later, its a great selling point since changing a timing belt is very time consuming and doesnt allow for any mistakes.
One thing to make sure of during this conversion is that the correct cam gear (left and right) are on the appropriate cam. If you mix them up, your distributor will not match up with the FSM's listed position for TDC.
__________________
OH ****E - does this mean I have to REPLACE the radiator, if I move to the 0.50MM oversize, because the OEM radiator might not be able to handle the added heat?
Maxpwer is offline   Reply With Quote
Old 10-02-2009, 10:26 PM   #8
Also, if your ordering from Courtesy and are going through with it, may as well replace those cheap little plates:
Crankshaft Sprocket Plate (1)
Harmonic Balancer Plate (1)
Old 10-02-2009, 11:32 PM   #9
well if you mix them up you might have more problems than a mistimed distributor
o and nice sig
__________________
Old 10-03-2009, 09:18 PM   #10
Are those the two plates that surround the crank sprocket?
Well I was at the junkyard today and it was full due to the 50% off sale (line was long that it took an hour for me to get to the cashier). There was only one 94 VG there but I didn't have the tools to take out the timing belt cover... So the only think I took from it was the cluster cause I'm gonna replace the trip meter on mine and do some other experiments on it. I will see if I can try again tomorrow.
Old 10-03-2009, 11:28 PM   #11
Yes those are the plates. Mine were rotten and warped a bit - probably from the last mechanics prying them.
It may be faster or easier to just cut the timing cover off, check it out (although there aren't that many bolts I recall)- if it's the pick yards are like around here, with thousands of cars, it can be your own feeding frenzy and makes removal fast and easy.
Old 10-10-2009, 03:46 PM   #12
Truck Shifting de Turbo
Chris Gregg's Avatar
From someone who has done this conversion, it is very simple. Already a lot of good feedback regarding components and issues to be mindful of, so no need to repeat it again.
__________________
http://www.cardomain.com/ride/329804
*Work in Progress!
Chris Gregg is offline   Reply With Quote
Old 10-23-2009, 09:50 PM   #13
I'm new to the Maxima. But, I was told that it has a timing chain, not a belt. What's up?
Kiron Kid
Kiron Kid is offline   Reply With Quote
Old 10-23-2009, 10:09 PM   #14
Quote:
Kiron Kid
1981-1991 all models (L24E I6, SOHC VG30E V6) had timing belts.
1992-1994 GXE models (SOHC VG30E V6) also had timing belts.
1992-1994 SE models (DOHC VE30DE V6) have timing chains.
all 1995-present (VQ30DE(-K) and VQ35DE V6) have timing chains.
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
