Go Back   Maxima Forums > Maxima Discussions > 3rd Generation Maxima (1989-1994)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 09-23-2009, 06:21 PM   #41
what about 1/2 does it do the same?
__________________
1992 maxima SE auto 159k (r.i.p)
1992 maxima SXE 174k
1991 infiniti Q45 158k
1997 maxima SE 115K
1992maximase30 is offline   Reply With Quote
Old 09-23-2009, 07:14 PM   #42
Quote:
Originally Posted by CapedCadaver View Post
alright so at the very very end it looked like it finally went into 2nd, right? was that due to you lifting off the throttle? did you lift off at any other time during the video?
No that was str8 through, I didn't lift off the throttle at all, it just kinda jerked into second gear
biggz2332 is offline   Reply With Quote
Old 09-25-2009, 06:48 AM   #43
I'm back I did the tranny flush, and that damm sure didn't help still doing what it was doing before, I think it's mechanically on it's way out
Old 09-25-2009, 08:38 PM   #44
is the P (power light on the switch) blinking?
__________________
1997 maxima SE 115K
Old 09-28-2009, 07:26 AM   #45
Quote:
No it is not blinking, wat does it mean when it blinks
Old 09-28-2009, 03:04 PM   #46
when it blinks it means the transmission control unit has a code meaning one of the sensor's or solenoids is malfunctioned etc.
__________________
1997 maxima SE 115K
Old 09-29-2009, 08:07 AM   #47
yea no P blinking, but I know it's mechanically going because reverse is beginning to fail
Old 09-29-2009, 08:06 PM   #48
aww man. yea they say thats one of the signs. that sucks
__________________
1997 maxima SE 115K
Old 09-29-2009, 09:05 PM   #49
4real time 2 hit up da junk yard
Old 09-29-2009, 09:13 PM   #50
Call me Wookiee Goldberg
CapedCadaver's Avatar
Quote:
good luck finding a VE to get a tranny from. often times there are none at the JY near me, tho you're lucky it's a/t and not m/t, cuz i've only ever seen 1 VE5 at the JY near me. but i guess it's cheaper than getting it rebuilt. WORST CASE scenario you can use a 4th gen tranny and just swap the bellhousing from your VE tranny and use a non-LSD driverside axle (may be the same as a 4th gen axle, but not 100% sure). If you do that you might need to get the diff bearing preload adjusted by a tranny shop, but that's still cheaper than a full rebuild. [Aaron92se is running a VE auto tranny on a VQ engine so it will work in the reverse as well as long as you swap the bellhousing.]
__________________
PieceOut.FallToPeaces New to the forum? CLICK HERE!!!!
1985 Nissan 300zx 2-seater: VG30E | 5spd Swap | Bilstein | 5-lug conversion | Polyurethane everything | Resurrection-in-progress!
2004 Honda Civic EX Coupe: 1.7L VTEC | 5spd | CAI soon | LED tails and Projectors soon | ES Poly Motormounts soon | 'bad weather' car/backup for teh Z
1990 Nissan Maxima GXE: VG30E | VLSD-5 swap | Exedy | NWP | a33b(F)/z31(R) BBK | ES poly | SE susp swap | 2k2SE 17s | retired Aug 28th '09
2005 Nissan Maxima SE: VQ35DE | 6spd | Carolina Panthers front lisence plate | Brother's car, not mine | <-- Therefore still 100% stock
Quote:
Originally Posted by JasonOksa View Post
Horsepower, torque and speed are all known by The State of California to cause cancer, birth defects, and reproductive disorders.
Quote:
Originally Posted by bigleman View Post
how much would it cost to resleeve?
how does an aluminum motor form rust on the cylinder walls???
DO NOT PM ME ABOUT PROBLEMS WITH YOUR CAR UNLESS I TELL YOU TO. THAT'S WHAT THE FORUM IS FOR
CapedCadaver is offline   Reply With Quote
Old 09-30-2009, 08:26 PM   #51
I've come across engines, so I hope trannies show up to
Old 10-11-2009, 07:58 AM   #52
Back with ma update Well I filled up this supposingly 18.1 gallon tank although I only got 15 gallons in their and it was above the "F", anyhow after I damm near empty out my gask tank it was reading 260 miles my calculation 260/15= 17.3 miles per gallon and I know thats not efficient at all, but I also notice that when I'm crusing at 70 the RPM is at about 3200, and that I believe is the problem(transmission failing)
Old 10-11-2009, 08:06 AM   #53
yea 70mph in OD should be more like... 2800
__________________
Old 10-11-2009, 09:37 AM   #54
Oh yea guess that the problem...damm
Old 10-11-2009, 09:50 AM   #55
i guess, cuz even if you had the wrong tire size, the relatioship between your tach and speedometer would remain the same. not that i know if you have a non-stock tire size anyhow.
__________________
Old 10-11-2009, 10:00 AM   #56
well I do have 17" wheels on ma car I was gunna put the stocks back on soon and see what happens
Old 10-11-2009, 11:48 PM   #57
That doesn't sound right to me. My max is within 75 MPH when I reach 2500 RPM and near or on 85 MPH when it's at 3000 RPM.
But I do get around 12-15 MPG most likely due to an exhaust leak and a bad O2 sensor (which I will fix next week). Don't know if running the car with a bad exhaust system would make a big difference.
EDIT: Just noticed that biggz has a VE engine while I have a VG. So my info won't be that helpful
jbbons25 is offline   Reply With Quote
Old 10-12-2009, 07:53 AM   #58
hmm i guess a/t does rev lower doesn't it? I was thinking about 5th gear on my car. I remember that 45mph locked up in OD was 1600rpm on my automatic. VE might have a shorter final drive tho (on manual it's 3.65 VG and 3.83 VE, i think)
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
