3rd Generation Maxima (1989-1994)Learn more about the 3rd Generation Maxima here.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Max was driving great and I went to pass someone. I hit 85mph and was at about 4100 rpm all of a sudden when it started hesitating real bad. Doesn't feel like a single cylinder miss. Kept driving and it smoothed out. Then after it sat for about 30 min I drove it and it was missing like crazy for about a minute then cleared up with just an occasional hiccup. So far it seems that it gets bad after sitting then sorta clears up. What could of triggered this just from passing someone. I check MAF and FI connections and they didn't make any difference
can't think what would cause that miss just because of the engine being under a higher load
did you check those items yet? my car kept hiccuping and it turned out to be a bad TPS hardswitch. reason being, it never gave me problems at idle (when the switch was supposed to have a closed circuit) but would give me problems any time i was off-idle.
__________________ PieceOut.FallToPeacesNew to the forum? CLICK HERE!!!! 1985 Nissan 300zx 2-seater: VG30E | 5spd Swap | Bilstein | 5-lug conversion | Polyurethane everything | Resurrection-in-progress! 2004 Honda Civic EX Coupe: 1.7L VTEC | 5spd | CAI soon | LED tails and Projectors soon | ES Poly Motormounts soon | 'bad weather' car/backup for teh Z 1990 Nissan Maxima GXE: VG30E | VLSD-5 swap | Exedy | NWP | a33b(F)/z31(R) BBK | ES poly | SE susp swap | 2k2SE 17s | retired Aug 28th '09 2005 Nissan Maxima SE: VQ35DE | 6spd | Carolina Panthers front lisence plate | Brother's car, not mine | <-- Therefore still 100% stock
Quote:
Originally Posted by JasonOksa
Horsepower, torque and speed are all known by The State of California to cause cancer, birth defects, and reproductive disorders.
Quote:
Originally Posted by bigleman
how much would it cost to resleeve?
how does an aluminum motor form rust on the cylinder walls???
DO NOT PM ME ABOUT PROBLEMS WITH YOUR CAR UNLESS I TELL YOU TO. THAT'S WHAT THE FORUM IS FOR
yea i think someone here had the tip of the screw break leaving the other half in the cam. so it would run like how your decribing or would start at all.
__________________
1992 maxima SE auto 159k (r.i.p)
1992 maxima SXE 174k
1991 infiniti Q45 158k
1997 maxima SE 115K
odd I went to go look at the cap and rotor. I noticed there was what looked like dirty water spots everywhere. Looks like the engine was getting wet everywhere. I checked and haven't lost any coolant.......odd
I had the screw holding my rotor in place come loose and the car wouldn't start. This was like 2 years ago though..
__________________ SHIFT_I cant it's Automatic!!
1993 Maxima GXE Super White, Ebay FSTB, 97-99 SE Rims, KYB GR2s, BlehmCo Lower Tiebar, BlehmCo parallel link kit, RSTB, BlehmCo swaybar links,Rear Addco swaybar, z31 rear disc upgrade, Assurance TripleTreds.
1995 Maxima GXE-5 Dark Blue Pearl , 00-01 SE RIMs, I30 leather w/rear headrests, No rubber- all ES Poly in front end suspension, Pioneer InDash Navi, Kzoosho LED tails and FX35 HID retrofit
look at the connector ends of the spark plug wires. Do any of them look pinched in? if so you can use a flathead screwdriver to expand them out so they make good full conact with the disty, receptacles and the one to the coil as well.
I got a problem with my maxima.... Rmps at idle is at 700 once i put it in drive it drops o 600 rmps... and when i press the window buttons to send down the 2 front windows the rmp's drop to 500 and engine feels like crap.... can someone help me with this problem? thank you
try cleaning your iacv. if it's not able to properly adjust the airflow to compensate for extra loads (putting car in gear, turning the wheel, electrical loads, a/c) that would cause the RPM to drop the more stuff you use.
I agree with the throttle position sensor idea. That SOB can wreak havoc on your idle, shifting issues for the transmission, and most likely a cause for erectile dysfunction.
It can be adjusted. A little turn can make a BIG difference. Turn, drive, turn, drive, etc. till if feels right.
will most def take out my throttle body clean it up and see if its dirty it makes perfect sense. frist time running this engine sense it came from teh junk yard and drove 300 miles on it so far. and dont worry i change the oil, spark plugs, wires new disturbutor cap, and fuel filter. and thermostat too and all the belts. also did a proflush. added lucas heavy oil stabilzer. and drained it after 75 miles cause it didnt do any thing. then another oil change with engine restore AMAZING!!!. and now after 300 miles on it im gonna do a Dura Lube additive in the engine cause pops said so eh. lol cant question the old g's in mechaincs lol
so i cleand the ivac and then the throttle body and advance the timing a little by turning the distubutor. the car when starts up cold idles at 1300rmps then goes down to 1000 rpms and once it warms up to 900rpms... i turned on the heat full blast the head lights and step on the brake and put it into drive and it idles at 500 and feels like its about to stall.... can somone help with this problem..
DO NOT USE DURA LUBE!!! stick with the engine restore. leave it in there for the full 3000 miles. that stuff worked miracles when i had my honda and acura.
if you have the gxe model you can adjust the idle on the ecu and the iacv itself.
my maxima idle's at 400rpms...thats with out anything on. dont feel any vibrations, or does'nt feel like she's about to stall either.
__________________
1997 maxima SE 115K
How do i adjust the idle by using the ecu cause when its at 500 rmps it feels rough and feels like it going to break down. this is a big problem....
gradually loosen the idle adjust screw on the iacv (underneath a black rubber cap... well assuming you have a VG) until your idle is satisfactory. there's a more complicated way to do it but try that first.
