3rd Generation Maxima (1989-1994)Learn more about the 3rd Generation Maxima here.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
i have a couple of questions about the warpspeed y pipe, i could probably get the answers from their ebay listings, but i wanted to read it directly from those who are currently using it. Your input would be appreciated. Was recently considering picking it up.
questions:
what are the pros? cons? (if any) of the y pipe.
is it legal is CA?
With the Y pipe on, would i pass a smog check?
Could i get it cheaper than 200? if so where?
With it on would it be louder than the stock pipes?
thats all i could think of right now, if i have any more questions ill add on to it haha. You can also tell me your experience with the pipe, how great it is compared to the stock or if theres anything you didnt like about the WSP, any input would be great. Thanks.
__________________ Maxima FTW------>
->Kyb gr2 shocks ->Eibach pro springs ->Stillen lip kit ->G35 Sedan dual tip exhaust ->2.25 inch Custom Piping Upgrade->Warpspeed Y pipe ->Power acoustik sound system ->Clarion MAX675VD touch screen head unit->Painted grill ->Intake air filter w/ adapter ->Front Strut bar ->Clear corners ->Promax Hid kit ->Mb motoring Rev rims w/ Kumho exsta AST tires.<-
questions:
is it legal is CA?
more power and perhaps better MPG
dunno
dunno
i have one for sale. might be hard to find a box that shape tho. but if i can find a box then we'll talk.
louder? no. just make sure you don't get rid of your resonator so it still sounds good.
__________________ PieceOut.FallToPeacesNew to the forum? CLICK HERE!!!! 1985 Nissan 300zx 2-seater: VG30E | 5spd Swap | Bilstein | 5-lug conversion | Polyurethane everything | Resurrection-in-progress! 2004 Honda Civic EX Coupe: 1.7L VTEC | 5spd | CAI soon | LED tails and Projectors soon | ES Poly Motormounts soon | 'bad weather' car/backup for teh Z 1990 Nissan Maxima GXE: VG30E | VLSD-5 swap | Exedy | NWP | a33b(F)/z31(R) BBK | ES poly | SE susp swap | 2k2SE 17s | retired Aug 28th '09 2005 Nissan Maxima SE: VQ35DE | 6spd | Carolina Panthers front lisence plate | Brother's car, not mine | <-- Therefore still 100% stock
Quote:
Originally Posted by JasonOksa
Horsepower, torque and speed are all known by The State of California to cause cancer, birth defects, and reproductive disorders.
Quote:
Originally Posted by bigleman
how much would it cost to resleeve?
how does an aluminum motor form rust on the cylinder walls???
DO NOT PM ME ABOUT PROBLEMS WITH YOUR CAR UNLESS I TELL YOU TO. THAT'S WHAT THE FORUM IS FOR
o really, why you sellin bro?
you think if you just bring it to UPS or fedex thell find a box for you?
Just let me know man, im interested.
i got a 300zx, so i'm parting the maxima(s).
the max is no longer safe to drive due to suspension issues ($200+), and it also has fluid leaks ($??), wrong size injectors causing horrible mileage ($700), and needs a new windshield ($??) so rather than spending $1000+ on car i don't drive, i would rather make money from the good-condition parts that it has.
less than a year. it originally came from goon9. and there wasn't really much snow here this past winter.. i only drove in snow maybe 8 days total since i have had it. here is a pic from the day it went on my car:
Do you still have the gaskets? you think you can do 150 shipped? >.< ill buy* it man.
the gaskets are just those metal ring thingies... one-time use, tho you CAN tap then back out to reuse them like we did if you want to. i think we can do that tho. once i get it off the car i'll see what sort of shipping arrangements i have to work with.
no, 2 ring type, then 1 traditional flange gasket where it attaches to the catconv. the catconv gasket is new well, put in in March, but as with most gaskets they are one-time use.
Bring pipe to an exhaust shop or a local parts suppler to mach the crush rings that goto the pipe from manifold. As for the pipe to cat... i used Nissan OEM METAL gasket on mine. I think it`s the same one used for B15 sentra
__________________
My max is in rebuilding !?!?!....5-speed swap,Eibach springs,Tokico blues,Jeff92se brackets,99 Cobra rotors,Infiniti J30 calipers,Z31 rear rotors,WSP pipe,05 Altima SE-R muffler. ST bars.Urethane control arm bushings. OBX throttle spacer. Need paint,Stillen kit
questions:
is it legal is CA?
YES IT IS SMOG LEGAL IN CA. it does NOT effect emissions. As far as exhaust tone.. it does change it slightly. I noticed mine did. Pros: i noticed smoother RPM from idle to 6000 and noticed a MPG gain. Bout 2-3 MPG. CONS:..NONE ......
__________________
Wait, so are you parting the car?
__________________
Desperately looking for a 5 speed axle carrier bracket. Either VG or VE will work. PM me if you have one!
Good working door lock timers $20 shipped. PM me if interested
yes. and no i haven't forgotten about your tranny case.... off-call again on friday, lots of people want parts, will try and do it all in one shot as long as everyone pays me at the same time.
Are you parting the car fully or just mods? No rush on the tranny case but if you are fully parting the car I DO desperately need a 5 speed axle carrier bracket
__________________
whole car. but i've got a spare bracket that's already loose (came from the 89se when i yanked the motor for my z)
hope youre having better weather than me -_- its effin hot , 95 degrees
well i didn't get to pull it but i moved the car into a position to pull it. hopefully i can pull it tomorrow. i spent some time getting other stuff off the car for other ppl but of course moving the car around the yard and letting it run to recharge the battery meant that it was too hot to touch before i lost daylight. so all i gotta do tomorrow is roll the car up on ramps and remove the pipe.
sounds good man. hows the weather over there?
make sure you put delivery confirmation on it in case ups or w.e shipping company loses it or something.
kk. i was over at my grandparents' house packing the thing (you're gonna be like lolwtf when you see the box) so that's why you didn't hear back from me sooner. Bout to head over to UPS in a bit.
hahaha yea? well as long as nothings damaged were good dude, im not too picky. thanks for the effort. im pretty excited. i sent the money to you earlier this morning.
