3rd Generation Maxima (1989-1994)Learn more about the 3rd Generation Maxima here.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Seems my max is overdue for a spring tuneup and she is not running so nicely these days. Very rich, smelly exhaust, lumpy and sputtering idle plus hesitation on acceleration when cold. Obviously its time to do some things To rule out some issues I'm going to repair whats necessary and replace some suspect parts along the way one at a time to see what my issue was. The list is as follows:
1. Engine Temp sensor
2. cap and rotor
3. spark plugs
4. fuel lines
5. vacuum lines
6. intake and ISC motor cleaning
7. resistance readings on injectors
8. New y-pipe and cat
9. Check timing (do I need to?)
So if it still runs crappy then I really have issues because I have no idea what to look at next! So any suggestions on plugs, cap and rotor?
FYI: The tranny is fine, the coils seem to be ok visually and the plug wires are new.
__________________
Mostly stock 1993 GXE, 72K original miles as of 10/09
Added: Sony Head Unit, 2001 17" SE Wheels With Hankook Tires, Fog lights, K&N
Maintenance: New struts, brembo front rotors and pads, rear shoes, steering boot, timing belt and tensioner, water pump, all coolant hoses, thermostat, O2 sensor, cap and rotor, NGK platinums and plug wires, front axles, alternator and because its a Maxima, 3 (make that 4) window regulators and a fuel injector.
Coming Soon: Warpspeed Y-pipe and Cat!
Well, no. Those are random facts for the people who might try to diagnose my issues as the few items I have already ruled out. I find if you post about an issue you have to answer all questions ahead of time so you dont waste bandwidth telling people you already checked that part. So I'm telling people ahead of time that my transmission is not responsible for the driveability problems and neither are old wires or a faulty coil pack
__________________
for the extra bit of $$ (maybe $6 per plug instead of $4/plug), I always splurge and put in NGK Platinum. They also last longer. I noticed a big difference, but I was also overdue for a tune up.
On cap & rotor, I think I went with run-of-the-mill brand carried by the parts store, German name like Niehoff (??). I didn't see a big change from swapping out my rotor & cap, although they both looked worn.
I didn't see air filter on that tune up list!! I'd do that too.
yes, I'd check timing. mine was off by a degree or two and I set it back to the mark, but the manual says +/- 1 or 2 degrees (IIRC).
Ok good advice on the plugs, thanks. I was thinking of a bosch cap and rotor but if it makes no difference than I wont bother. I just put in a K&N filter BTW, but youre right, thats a first step on a tune up.
__________________
Changed items 1,2 and 3 and it runs much smoother but I think I still have issues. I wound up with NGK BKR6EGP plugs. Steps 5,6,7 and 9 come next I really hope the mileage picked up, the plug gaps were way open, ranging from .48 to .52!!
2. cap and rotor
3. spark plugs
4. fuel lines
5. vacuum lines
__________________
if it's still running funny why don't you pull codes?
ibetyouro2sensorisdeadsinceyourrunningrich
__________________
CAI, EGR removed, FSTB, DZ springs, SS brake lines, Cross Drilled Rotors, ES Poly bushings, 9007 upgrade, Front lip and repaint, fogs, 2x alpine type s 10's, pioneer HU Alpine Amp,
Code is a 55, surprise surprise And the O2 sensor is new, forgot that on my sig.....oops!
__________________
get rid of that K&N filter. If improperly oiled it will damage your maf and cause incorrect readings. Stick to a plain paper air filter unless you are running a true CAI.
96 Green A/T gone
94 Pathfinder POS GONE! | 79 Camaro sold
98 I30t Silver on black A/T gone | 96 Granite Pearl (AKA Purple) A/T gone
92 grey VE A/T gone | 96 I30 Black gone
92 maroon VE A/T gone | 92 white VE M/T gone
92 grey VE A/T gone | 6/84 L24E last of the RWD Maxima gone
I've never heard of the oil in K&N air filters screwing up MAF readings???
my brother used K&N air filters on his s13 forever.
__________________
sorry, not convinced. heard of it too many times and I for one would not be willing to risk it especially since the increase in airflow off of a K&N versus stock is minimal (stock replacement K&N VS. Stock Air filer).
96 Green A/T gone
ok, good for you.
__________________
I heard of this as well from a nissan mechanic. He told me to get rid of my K&N air filter b/c it would damage my maf. Well I didn't believe him and now a year later my maf is now done.
__________________
Go Maxima or Go home!
K&N Air Filter - Racing Shifter and Petals
As well as the usual: Dimmed clock, broken antennae, worn e-brake, cracked winshield etc...
been running a k&n stock replacement for over a year and a half, no problem.
you're probably doing it wrong.
Over-oiling is the main cause for MAF failure, not just on 3rd gens. If you oil the filter correctly, very very lightly, and let it set before use, you will minimize the risk of killing your maf.
The MAF is a heated wire that measure the temperature difference based on the heated wire. Heated wire + oil = No good.
As for the plugs, I've always used NGK V power in all of my Nissan and Mazdas. Works the best and only $2.00 each.
Here is a fabulouse link for Plug wires. http://www.kingsbornewires.com/
Very good quality, and very good prices. I bought my first set of Kingsborne wires over 8 years ago. I don't have the car any more, but I would bet money they are still running strong, and looking great.
__________________
Bill, 1992 Maxima SE, White, black leather seats, ATX with factory VLSD, completly stock.
2003 Altima SE 3.5, Black, black leather seats, HID head and driving lights, Dual Halos, Active tunning grill, Nismo CAI, Nismo STS, OBX Headers, Magnaflow Exhaust, Koni Adjustable shocks, Eibach springs, Maxima LSD, 20" wheels.
word. ngk plugs all day.
__________________
