Go Back   Maxima Forums > Maxima Discussions > 3rd Generation Maxima (1989-1994)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Timeslips Members Parts Guide Search Today's Posts Mark Forums Read ExperienceUsed CarsGarageVendor Directory
Search
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 08-17-2009, 11:43 PM   #1
Points: 9,253, Level: 64
Points: 9,253, Level: 64 Points: 9,253, Level: 64 Points: 9,253, Level: 64
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
HOW CAN YOU TELL IF YOUR INNER TIE ROD IS BAD??
I am wondering if My driverside inner tie rod end is bad. Ive replaced both outer tie rod ends on the car, but I still get this slight vibration at speeds of over 65mph and above it seems to get worse at 80 and above. The vibration will go and then come and go again. Dont know if this is normal. Ive had all wheels balanced, replaced the front struts, so im am puzzled.
maxinout93 is offline   Reply With Quote
Old 08-18-2009, 01:15 AM   #2
ColombianMax's Avatar
Points: 12,263, Level: 72
Points: 12,263, Level: 72 Points: 12,263, Level: 72 Points: 12,263, Level: 72
Activity: 0%
Send a message via AIM to ColombianMax
Just like you troubleshoot most other suspension components, which I'm assuming you did to determine the outers were bad. Jack your car back up and try to jiggle the wheel for play, sides as well as top to bottom. You could've probably asked this in the inner tierod replacement thread I bumped instead of what you posted there or along withit...
__________________
SHIFT_I cant it's Automatic!!
1993 Maxima GXE Super White, Ebay FSTB, 97-99 SE Rims, KYB GR2s, BlehmCo Lower Tiebar, BlehmCo Parallel Link Kit, BlehmCo RSTB, BlehmCo Swaybar Links, Addco RSB, z31 rear disc upgrade, Assurance TripleTreds.
1995 Maxima GXE-5 Dark Blue Pearl, 03 SE TE RIMs, I30 leather w/rear headrests, KYB GR2 on Progress springs, Progress RSB, ES Poly in front end suspension,WarpSpeed YPipe, Pioneer InDash Navi, Kzoosho LED tails and FX35 HID retrofit
2002 Maxima SE 6spd Sterling Mist, Tokico Illuminas on Tein H-Techs, Progress Rear Sway Bar
ColombianMax is offline   Reply With Quote
Old 08-18-2009, 01:10 PM   #3
Points: 11,987, Level: 71
Points: 11,987, Level: 71 Points: 11,987, Level: 71 Points: 11,987, Level: 71
Activity: 7.8%
Activity: 7.8% Activity: 7.8% Activity: 7.8%
Quote:
Try to eliminate tire problems first by swapping rear/front wheels. If the vibration doesn't move back as a result then it is front suspension problem . Assuming you checked the obvious things for play and found nothing my next step would be control arm bushings. I'm currently in the process of replacing them on my own car as they started to make noise over bumps. I also had persistent front wheels vibration like you describe. We'll see if new bushings will take care of that as the rest of components seem to be tight in my case.
__________________
2k3 GLE
Max_5gen is offline   Reply With Quote
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
Search Engine Optimization by vBSEO 3.5.2
