Ignition Upgrade for VG
Old 08-13-2009, 09:16 PM
CMax03's Avatar
Got the oil filled coil and Mallory Ignition control box today ...trying to get all the brackets fabbed up for the coil and the ignition box... Got pics of the coil so far! That puny epoxy crap... is a gonner, Im trying to burn whatever is in there....without that intermittent behavior before the coil goes out! These Oem coils will test fine but bog and misfire when they reach near the end of thier service...
CMax03 is offline
Old 08-13-2009, 09:38 PM
maximo018's Avatar
Thats nice man. I'm ordering things now. I got my block back today and my ported out exhaust manifolds from Aaron. I'll post comparison picks of my stock vs his on my home page. Major Difference! Will order more suspension stuff now.
maximo018 is offline
Old 08-14-2009, 07:59 AM
infinitiblast's Avatar
This thread makes me wonder if its my Coil pack that is causing all my misfire issues. Since my injectors all test out a-ok.
infinitiblast is offline
Old 08-14-2009, 09:42 AM
maxitech's Avatar
You don't have coil packs. You have a distributor and an ignition coil. Replace the distributor cap and rotor, plugs, and wires and report back.
maxitech is offline
Old 08-14-2009, 10:06 AM
Doh! Thats what I meant to say, but yeah anyways. Already replaced all those items still the same issues. But I dont wanna Hijack this thread.
Looks good let us know how it runs!
Old 08-14-2009, 10:47 AM
CMax03's Avatar
The epoxy coils normally miss in under load conditions like during part throttle acceleration...
CMax03 is offline
Old 08-14-2009, 11:01 AM
Call me Wookiee Goldberg
CapedCadaver's Avatar
my car has always had a little bit of a stumble at like <5% throttle. less noticeable with the automatic tho. now with the manual it's hard to feather the throttle with it sort of gently stumbling and bucking a little bit. not nearly as bad as a dead-injector misfire tho.
CapedCadaver is offline
Old 08-14-2009, 05:19 PM
CMax03's Avatar
You can fix that with one of those $26-$40 Msd/ Accel/pertronix traditional oil filled coils! I did this to my 86.5 D21 Hardbody 6-7 years ago and it's never had any more coil problems! It's like about whenI was a kid I never saw my dad or uncle change an oil filled canister coil because it started misfiring. I saw them change one cause it was leaking oil and the rest were for higher perf coil (hotter spark) setups, and this was on big block Mopar V-8's.
CMax03 is offline
Old 08-14-2009, 06:16 PM
well maybe not on the Max but i will keep that in mind for my ZedX
Old 08-15-2009, 05:58 PM
maxinout93's Avatar
About how much does that coil cost, and where can you order one from? Is the setup easy?
maxinout93 is offline
Old 08-16-2009, 12:41 AM
CMax03's Avatar
I've been looking at Mallory's ignition control box for years, cause of it's price and being a digitally based control unit! So to keep every think in perspective I chose to use the Mallory 29440 oil filled coil! It's not the least expensive coil but it's really durable and robust! It's about a $89 coil, but it's can be done with any oil filled or epoxy canister coil from Pep Boys, O'Rielly, Advanced Auto, ect for about $30...Or the boneyard for about $5....
Yesterday I fabbed my control box bracket and Intake system heat shield Saturday and wow! I'm really happy how it came out. I wanted to place the ignition box in close proximity to the distributor and coil but, the instructions stated to mount the box as far as possible from the distributor! So since I've been relocating the battery to the trunk and there was going to be plenty of air moving around the air filter I choose that location! So my heat shield is double dutied, protecting my control box and aiding in lowering my intake temp! I will shoot some pics when my camera is returned from my niece!
CMax03 is offline
Old 08-16-2009, 08:44 PM
CMax03's Avatar
Here's my heatshield and ignition control box...
CMax03 is offline
Old 08-18-2009, 04:35 AM
fattamax's Avatar
looks great...any thoughts of fabing that heat shield for org members?
fattamax is offline
Old 08-18-2009, 10:28 AM
CMax03's Avatar
You would have to relocate your battery to the trunk
CMax03 is offline
jmlee44
10-02-2022 02:13 PM
AaronL
08-08-2020 10:31 AM
Fbana41
08-29-2016 12:18 PM
Kyle Lee Cleveland
09-28-2015 09:03 AM
Quick Reply: Ignition Upgrade for VG
