Go Back   Maxima Forums > Maxima Discussions > 3rd Generation Maxima (1989-1994)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 07-28-2009, 10:26 PM   #1
Send a message via AIM to Infam0usMax Send a message via MSN to Infam0usMax Send a message via Yahoo to Infam0usMax
STILLEN BODY KIT "how to?"...
I have searched for this but people are saying this or that about it... I just picked up my stillen body kit today the WHOLE kit for only $150.00 I know some people are like dang... anyways heres the question. Whats the best way and most easy way to put it on so that i wont have to worry about it coming off and 'molding it to the body is a no in my case'**Please feel free to post pictures of what ur talking about it would help out alot.**
*IF U DONT HAVE THE KIT OR NEVER INSTALLED ONE...LET IT BE KNOWN BEFORE YOU TYPE* that way when people come to read they will know right off the bat what they need to know without reading something thats gonna have them running up walls. thanks.
Infam0usMax is offline   Reply With Quote
Old 07-29-2009, 06:53 AM   #2
Decal Specialist
erty67's Avatar
Send a message via AIM to erty67
one of my old threads. It's for a 4th gen, but maybe it will help.
questions for those who installed their own stillen body kit...
erty67 is offline   Reply With Quote
Old 07-29-2009, 07:08 AM   #3
Ad·min·is·tra·tor
DanNY's Avatar
i owned it...installed it...painted it...
what shape is the kit now? is it painted? unpainted? mounting holes in it?
DanNY is offline   Reply With Quote
Old 07-29-2009, 01:14 PM   #4
Its all bent right now except for the sides the guy said i could HEAT them up a lil to get them back in the right shape. im not sure if holes are in it or now i doubt that they are because the kit was never used. its pretty much new. and its NOT painted.
__________________
Numbers or strength doesn’t mean you will win the war but whichever army goes into battle stronger in soul their enemies can’t withstand them...think about it..GetIt?GotIt? Go....-Infam0usMAX-
Old 07-29-2009, 03:05 PM   #5
Ad·min·is·tra·tor
DanNY's Avatar
ok well it'll go back to shape if you throw it in the sun for a littlee while.
follow directions (if they came with it).
ditch the foam tape they give you and use 3M mounting tape...it's gray in color.
test fit everything...make sure it looks ok w/o the tape.
use a 3M maroon pad and some soft scrub and scrub all the pieces....rinse clean.
get some prep sol and clean it up really good. then follow the painting procedures.
to mount use the double sided tape and put it on the pieces...then use the prep sol to clean the car and stick it on there. use screws to mount the end points that are in the wheel wells.
i used counter sunk rivets for the corners of the front lip...right next to the corner blinker.
that's about it...not too much to it i guess.
Old 07-29-2009, 07:36 PM   #6
Some mounting tips from when i put mine on.....for the rear lip i used 2 rivets on each wheelwell and also 2 inside the muffler pocket with the 3m doublesided tape its grey with a red outer peal-off.....for the side skirts i put 1 in each wheelwell and 2 inside the door jamb along with the 2 sided tape...... the front i used 2 rivets in each wheelwell and 1 on each side where it comes to a point right above the fog light with tape around it also.... i black majic markerd the tips of the rivet heads to make them black.... also up front i used a peice of aluminum to attach underneath the front lip where it meets the car for rigidity....
__________________
( VG30E 5-speed, InTraX Springs, Koni Red Adjustable Shocks, Stillen LipKit, WarpSpeed Y-Pipe + Cat Back, N1 muffler, UnOrthodox Underdrive Pulley, Blemco Groundwires, 18" Akuma Black w/ Chrome lip, Custom Short Ram Intake, 35% Tint, 12" Kicker L5 w/ 1200w Sony Amp,
1991- pb 15.724 87 mph
1991Maxima1991 is offline   Reply With Quote
Old 07-30-2009, 12:45 AM   #7
I bought it from a guy for only $150 nothing else came with it but the kit itself...it was never used...but Ok... I think I got it now so to sum up this thread....
1. Set kit in the sun to bend it how u want it.(or can i use a heat gun?)
2. Dont use the foam tape they/Stillen gives you and use 3M MOUNTING TAPE..(gray in color)
3.Test all parts to make sure they fit WITHOUT TAPE.
4. Use a 3M MAROON PAD and some SOFT SCRUB and scrub all the pieces.... and rinse clean(to get off any oils or whatever is on there?)
5. Use 3M MOUNTING TAPE on the whole kit...
6. FOR REAR LIP: Use 2 RIVETS on each wheelwell and also 2 RIVERTS inside the muffler pocket (IF NEEDED)
7. FOR FRONT LIP: Use 2 RIVETS in each wheelwell and 1 on each side where it comes to a point right above the fog light.
8. FOR THE SIDE SKIRTS: PUse 4 RIVETS 1 in each of the wheelwells and 2 inside the door jams..
and im not sure what ur talking about with the "piece of aluminum to attach underneath the front lip where it meets the car for rigidity...."
__________________
Old 07-30-2009, 08:10 AM   #8
Ad·min·is·tra·tor
DanNY's Avatar
that last part is not really needed.
the bottom flap of the lip should sit on top of the stock bumper ridge and screwed in.
Old 07-30-2009, 09:16 AM   #9
alright thanks Dan.. I hope this thread will be tha last one about the body kit. I ALSO JUST ADDED PICUTRES.
__________________
Old 07-30-2009, 09:56 AM   #10
Would be lost w/out the org
traxtar944's Avatar
Send a message via AIM to traxtar944 Send a message via MSN to traxtar944
For Side Skirts, I just did 2 Rivets in each wheel well. That way they don't rotate. You can rivet them directly to the fender lip, if I recall. The doors will hold the skirt in place, so there's really no need for an unsightly rivet. Pre drill your holes, then paint the holes you make on the body to prevent any rust from forming.
To make the gap look nicer, a bead of white silicone in all the creases will make the kit look like it's molded to the body. Just be careful and don't glob it on. You can follow the caulk gun with a finger to make it look really nice.
PS: The 3M tape has a red plastic backing, but the tape itself is gray.
__________________
For Sale: Stillen POP Charger, BlehmCo Links, Draw-Tite Trailer Hitch with Wires, OEM VG Engine Gaskets, and more! Check the classifieds!!
traxtar944 is offline   Reply With Quote
Old 07-31-2009, 07:45 PM   #11
o and behind your rear license plate it a good spot for rivets or screws...
__________________
Old 08-03-2009, 02:57 AM   #12
Is this the tape?
__________________
Old 08-03-2009, 08:33 AM   #13
Blown
Send a message via AIM to cardana24
yeah, that's the right stuff. It should be grey in color and you pull back the red tape/seal to expose to sticky part.
cardana24 is offline   Reply With Quote
Old 08-03-2009, 11:10 AM   #14
damn how did that thing get bent so badly?
austin from texas is offline   Reply With Quote
Old 08-03-2009, 11:33 AM   #15
Blown
Quote:
It comes like that from stillen. It's urethane, its not a big deal, you can just unfold it and everything works out fine.
Old 08-03-2009, 03:25 PM   #16
Send a message via AIM to Stwodahorty
dam that doesnt look too kool lol.
__________________
Maxima FTW------>
->Kyb gr2 shocks ->Eibach pro springs ->Stillen lip kit ->G35 Sedan dual tip exhaust ->2.25 inch Custom Piping Upgrade->Warpspeed Y pipe ->Power acoustik sound system
->Clarion MAX675VD touch screen head unit->Painted grill ->Intake air filter w/ adapter ->Front Strut bar ->Clear corners ->Promax Hid kit ->Mb motoring Rev rims w/ Kumho exsta AST tires.<-
Stwodahorty is offline   Reply With Quote
Old 08-03-2009, 08:32 PM   #17
Its not this plastic or fiberglass that everybody seems to think it is...It's urethane and all I had to do was leave it in the sun but I am gonna have to use a heat gun to get it completely right but yeah its nothing bad in fact its one of the best things because u don't have to worry about it craking if u hit something just the paint.
__________________
Old 08-03-2009, 09:26 PM   #18
yep, urethane can take some good hits. theyre the best in cities with rocks etc
__________________
1992 GXE l 414,000km on original tranny and original VG30E l Pioneer Premier 12" 3500w subwoofer l 600w amp l JVC H/U l aftermarket fog lights l 2.5" Magnaflow catback exhaust l Momo summer rims l Stock winter rims l Sparco Sprint driver/passenger seat w/drivers 6 point harness l Sparco Volanti steering wheel l Castrol Syntec oil/premium Vpower gas
Future mods- 5spd swap, Z31 turbo w/intercooler
This winters mods- Z31 hood scoop, digital cluster swap, lowering springs
chrome91 is offline   Reply With Quote
Old 08-03-2009, 10:59 PM   #19
traxtar944's Avatar
You should get a bigger roll from autozone. It'll save you some coin in the end. That tape is expensive, but for a reason... it's the best stuff out there.
__________________
Old 08-04-2009, 02:33 AM   #20
Quote:
That was the next thing I was about to ask because this was a short piece I came across at wal-mart and is like 4.89 per roll and I know i would need like 7-8 of them to fit the whole car maybe even more, but thanks for the heads up.
__________________
Old 08-04-2009, 06:34 AM   #21
Send a message via AIM to Prophecy99
....good luck
Prophecy99 is offline   Reply With Quote
Old 08-11-2009, 02:13 AM   #22
Quote:
Originally Posted by Prophecy99 View Post
....good luck
Thanks for tha advice guys i will post pix of it once its on...
__________________
Old 10-15-2009, 11:48 PM   #23
heres the pix but now my car is dead... but not for long...
As you can see the thing started coming off a lil becasue the guy didnt use the rivets the right way (another reason why I should have done this myself)
Dang rivets came out...
__________________
Old 10-19-2009, 12:19 PM   #24
JPW 4 Heisman
Michael's Avatar
Send a message via ICQ to Michael Send a message via AIM to Michael Send a message via MSN to Michael Send a message via Yahoo to Michael
Been a while since I have been on here (man I need to change my avatar JPW graduated last year)...just got an email about a PM so when I came to answer that I decided to browse through the messages. Saw this one and figured I would try to help.
I have installed and painted a few of these. What I do on the front corners is put rivets in them (I drill a larger hole slightly in to counter sink the rivet) but you have to put a rivet washer on the other side to keep it from pulling through the plastic bumper (this is a huge pain because of where the washer will go but is doable if you dont mind taking the bumper off. Another thing is to put a screw on the inner part behind the fog light to help hold it in place but the little edge still pokes out some if you do that (most of the time anyway). With the bottom take those rivets out and buy new rivets along with the rivet washers (they will be sold next to the rivets). Push the rivet through, put the washer on the other side and be sure you push up on the washer as you are pulling the rivet so it will not fall off.
If you do that it will not pull off nor will the rivets pull through.
__________________
Roll Tide Roll!!!
Michael
Michael is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
