Go Back   Maxima Forums > Maxima Discussions > 3rd Generation Maxima (1989-1994)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 07-27-2009, 08:55 AM   #1
5spd swap from 89 SE to 91 GXE
What is the difficulty of swapping the Interlock relay from my 89 SE to my 91 GXE? Has anyone just wired around it?
the relay is on the driver side strut tower. it is hard to find in the 1989 to 1994 PDF FSM, but i have a 91 specific manual that show it clearly.
__________________
1991 GXE Resurrected from the dead
1989 SE gutted for parts and 5 speed.
300zmax is offline   Reply With Quote
Old 07-27-2009, 11:42 AM   #2
Call me Wookiee Goldberg
CapedCadaver's Avatar
i wired around it. i just wired my clutch pedal start switch and the "neutral" portion of the reverse/neutral switch in parallel to the park/neutral switch on the stock a/t wiring.
__________________
PieceOut.FallToPeaces New to the forum? CLICK HERE!!!!
1985 Nissan 300zx 2-seater: VG30E | 5spd Swap | Bilstein | 5-lug conversion | Polyurethane everything | Resurrection-in-progress!
2004 Honda Civic EX Coupe: 1.7L VTEC | 5spd | CAI soon | LED tails and Projectors soon | ES Poly Motormounts soon | 'bad weather' car/backup for teh Z
1990 Nissan Maxima GXE: VG30E | VLSD-5 swap | Exedy | NWP | a33b(F)/z31(R) BBK | ES poly | SE susp swap | 2k2SE 17s | retired Aug 28th '09
2005 Nissan Maxima SE: VQ35DE | 6spd | Carolina Panthers front lisence plate | Brother's car, not mine | <-- Therefore still 100% stock
Quote:
Originally Posted by JasonOksa View Post
Horsepower, torque and speed are all known by The State of California to cause cancer, birth defects, and reproductive disorders.
Quote:
Originally Posted by bigleman View Post
how much would it cost to resleeve?
how does an aluminum motor form rust on the cylinder walls???
DO NOT PM ME ABOUT PROBLEMS WITH YOUR CAR UNLESS I TELL YOU TO. THAT'S WHAT THE FORUM IS FOR
CapedCadaver is offline   Reply With Quote
Old 07-28-2009, 07:11 PM   #3
what did you do about cruise control?
__________________
Old 07-28-2009, 07:48 PM   #4
Tactical Espionage Action
anomaly117's Avatar
Send a message via AIM to anomaly117
i know d!ck about conversions like this, but i feel you wouldnt have to touch cruise. isnt it a unit all on its own? it only controls the throttle position and should have nothing to do with the tranny. right??
__________________
groups.myspace.com/massmaximas
(hmm...no thanksgiving smileys)
anomaly117 is offline   Reply With Quote
Old 07-28-2009, 07:52 PM   #5
2 VE's are better than one!
Quote:
Well, pushing the clutch pedal de-activates the cruise control, so it's definitely wired in somehow. I know most guys just don't ever wire it up properly and thus never have cruise (or back-up lights for that matter)
__________________
Desperately looking for a 5 speed axle carrier bracket. Either VG or VE will work. PM me if you have one!
Good working door lock timers $20 shipped. PM me if interested
James92SE is offline   Reply With Quote
Old 07-28-2009, 09:38 PM   #6
wired the cancel switch in-series w/ the brake cancel switch. wire colors are accurate-ish.
__________________
Old 07-28-2009, 09:45 PM   #7
Quote:
back up lights are b/c ppl never rewire the old a/t's inhibitor switch thingy... it's super easy actually, as long as you have something to pop the little spade connnectors out of the harness plugs. you just have to re-arrange the a/t's wires to correspond with the m/t's wires. so my car (and nc90gxe's car, which i swapped in march) starts in neutral w/ clutch up, starts in-gear WITH clutch down, reverse lights work, and cruise works. also the cruise will work fine if you never add the clutch cancel switch. i always cancel cruise with the clutch switch actually, because of the way my pedal is set up (no return spring).
here's an example of what i meant with the R/N switch wiring
swap the wires around till you end up with this, EXCEPT you need red/black, NOT yellow/black (the original mistake was due to a misprint in the FSM)
__________________
Old 07-29-2009, 07:36 AM   #8
Why should i not use the cancel switch on the wheel. does it cause a short?
also doesnt you brake light come on when using the clutch?
__________________
Old 07-29-2009, 10:03 AM   #9
no it still works, i just personally prefer using the one on my clutch pedal.
i deleted the pedal return spring on my clutch pedal, so the clutch pressure itself is what holds my pedal up. so now that my pedal doesn't 'bottom out' the cancel switch, i was able to adjust it so that the pedal just BARELY touches the cancel switch (just enough to enable cruise) so that i just TAP the pedal and it cancels cruise, rather than having to push it an inch like you would on a non-modified pedal. thus my pedal also does not make that silly CLUNK when i take my foot off it...
__________________
Old 07-29-2009, 10:47 AM   #10
I decided to just swap in the VE 5 wiring harness on mine (since I either lost/sold the VE auto ECU and I do have a VE 5 ECU, plus this way I can run the 5 speed intake mani), although after dragging the auto wiring harness out yesterday a thought dawned on me. Maybe you'll know the answer:
I thought the dash wiring was wired into the same harness as the engine harness but it's not. So yesterday it dawned on me that if I want to do this 100% factory that the VE 5 engine harness I have coming isn't going to help any with the actual clutch pedal wiring.
Now I can't check the car out right now and can't remember off-hand, but doesn't the clutch pedal have two switches? I know the top switch is the cruise cancel switch, but what's the other one? The pedal assembly I bought from goon is missing that switch, so I need to figure out what I need to do with that
__________________
Old 07-29-2009, 11:23 AM   #11
The Dirty Pearl
pmohr's Avatar
The lower switch is the main clutch switch, allows the engine to crank on a factory 5 speed (or properly wired conversion).
__________________
Quote:
Originally Posted by 2damax View Post
This jerk is right so often I just search threads hoping he gets something wrong so I can catch him
Quote:
Originally Posted by kizzmyazz View Post
ok so what i found out is that because of the FMU, i dont need to get injectors because it will neutralize the oil pressure to prevent detotnation
FSMs | A32 CEL Decoder | Howto Videos
pmohr is offline   Reply With Quote
Old 07-29-2009, 12:05 PM   #12
I guess I'm missing something:
The clutch cancel switch has two wires - a green/white wire, and a blue/orange-ish wire.
The brake cancel switch has two wires - a blue/orange-ish wire, and a light green/red wire.
The blue/orange wire from the clutch cancel switch gets spliced (or re-pinned) into the "left over" blue/orange wire that was going into the brake cancel switch.
Is this right? So there's actually TWO splices, correct?
__________________
Old 07-29-2009, 07:52 PM   #13
well you are making 2 new connections but if you use the needle method, you can get away with using only one splice.
on the a/t car, wires 1 and 2 are for the brake pedal switch, and wires 3 and 4 are the cut-off pigtails on the clutch pedal from snipping that plug out of my parts car. so i used the needle method (just like the R/N switch) to pop wire 1 out of the brake pedal plug and swapped it with wire 4, and then just used a splice to connect wires 3 and 4 to finish the circuit.
but you're right about the VE5 harness; the dash harness IS separate from the engine bay harness (they connect at the SMJ behind the fuse block inside the car). So what you do is, wire the cruise switch up the way you see there, and then for the clutch start switch, just drill a small extra hole in the firewall and send those 2 wires down to the R/N switch wiring, and splice it in parallel (connect one to the narrow green wire, the other to the brown wire). I chose to do my own car differently (by tapping the brown wire where it comes into the SMJ) which was WAY more of a PITA than it is to just send the wires back thru the firewall.
__________________
Old 07-29-2009, 07:56 PM   #14
i wired around it. car starts in neutral with clutch pedal up, reverse lights work and so does cruise control. basically the same thing as CapedCadaver stated minus in his post minus the whole rewire in his clutch pedal.
__________________
www.cardomain.com/id/green_max
'93 GXE 5-spd - sporting JDM power fold heated mirrors.
'97 SE Auto - finally running.
'08 BMW 335i Twin Turbo 6-speed - d/d temp.
GRNMAXDMON is offline   Reply With Quote
Old 07-29-2009, 08:16 PM   #15
Quote:
which 'clutch pedal rewire' did you omit on your own car, start-switch or cruise-cancel or both?
__________________
Old 07-29-2009, 09:08 PM   #16
I gotcha now, that makes perfect sense.
Where is the R/N switch wiring?
I was going to follow Fug43's method on the clutch starter switch but he's long gone and his post about how he wired it just confused me
But he did it the way you did, he tapped right into the SMJ somehow/where. I have it written down somewhere but can't find it at the moment
__________________
Old 07-29-2009, 09:33 PM   #17
R/N switch wiring is the 4-pin plug on the manual tranny (it's got blue+stripe wires on it, so don't expect the wire colors to match the engine bay harness wires). it's the one that wraps up from underneath the trans. the short wire w/ 2 pins is of course the speed sensor.
not to be conceited, but after doing 2 5spd swaps and having done so much work on my 3rd gen and others', i consider my writeups/methods for the 5spd swap to be the 'authoratative official version' of how to do it.. since i've never had a single problem or malfunction with anything related to the 5spd swap procedure I did. and nobody can tell that my car used to be a/t unless i tell them or if they knew my car before i swapped it. sadly i did not take very many pictures this past time when i did sam's car.. but as far as the written procedure and parts list, it's all still pretty fresh in my mind and i didn't half-a$$ anything haha.
__________________
Old 07-29-2009, 09:42 PM   #18
i just noticed your edit
why would the brake light come on when using the clutch???? there's 2 switches on the brake pedal - one for brake lights, one for cruise control. i never touched the brake light wiring.. just the cruise wiring.
__________________
Old 07-29-2009, 10:55 PM   #19
I definitely don't disagree with you here.
You should write-up a clutter-free swap wiring how-to that circumvents the "sticky". Heck, completely deleting that sticky would probably be better. I swear, the 5 speed swap sticky is semi-useless and so cluttered with speculation/useless posts/arguing it's ridiculous. Plus, half the linked threads with more info (like GRNMAXDMON's referenced clear wiring write-up) don't even work anymore (take you to random irrelevant threads - I guess due to the server/whatever change a few years back).
On top of that, I see a few guys mentioned in that thread swapping in the entire VE 5 harness(es) to avoid having to do any re-wiring. I would have to call nearly BS on that. In order to not have to do no re-wiring at all, one would have to swap in the complete engine chassis harness/firewall/dash wiring, and I would highly doubt anybody went to that much trouble.
For example, I'm swapping in the VE 5 engine harness to run the VE 5 ECU and manifold, but I still have to wire the clutch switches manually (which you've helped finally clear up for me). I highly, highly, highly doubt those couple guys swapped in the FULL harnesses which would have required screwing with the fuse boxes, relays on both sides of the firewall, etc.
BTW, this little project is gonna send me to the poor house. I noticed the coolant passages on the engine are filled with about 1/2" of brown sludge (ugh), and after draining the coolant I noticed the radiator is also full of sludge (even though the coolant was still green). I don't feel like somehow trying to clean out all the sludge so I decided I'm going to stick my JDM VE in there, and just couldn't stop myself from buying a new radiator, all new coolant hoses, ps hoses and pump, tie rod ends, control arms, etc.
__________________
Old 07-30-2009, 05:25 AM   #20
I agree with james, i have been searching for weeks and have found no concrete info on the swap. lots of part lists but they become irrelivent when you have the entire donor car. in just 3 posts you have helped me as well to no end. i am now more confident about the swap
also make it a nice PDF and charge $5 for it! make some side cash
__________________
Old 07-30-2009, 09:07 AM   #21
i just wired all 4 wires from the 5spd tranny plug to the 4 wires on the auto engine harness. thats all i did. and the car still starts in neutral with clutch pedal up as well as reverse lights and cruise control. obviously once i step on the clutch pedal the cruise will not shut off so i have to turn it off from the steering wheel. but that doesn't bother me i rarely use it anyways, but it works either way.
__________________
Old 10-21-2009, 07:50 PM   #22
Bump
Finaly getting around to finishing the swap.
what do i wire the Clutch start switch on the pedal to? or do i not need to if i rewire the 4 pin connector as the dead dark knight did in the earlier post.
hopefully with a little luck i will have the max running tomorrow.
__________________
Old 10-21-2009, 09:27 PM   #23
on my car, i wired it into the brown wire on the relay atop the SMJ. pain to get to. in nc90gxe's car i ran wires through the firewall and wired it into the park/neutral wiring on the a/t inhibitor harness (which i also played musical chairs with the wiring in order to get everything to be basically plug-and-play, in terms of the manual's reverse/neutral switch)
__________________
Old 10-22-2009, 08:35 AM   #24
Since I already had the dash out and put in a 5 speed engine harness, I cut the LG/R wire on the cabin side of the SMJ (E101). Then I ran the LG/R wire going into the SMJ to the LG/R wire on the clutch switch, and ran the other side of the LG/R wire that heads to the inhibitor relay to the LG/W wire of the clutch switch.
__________________
Old 10-22-2009, 08:40 AM   #25
Just to make sure im not getting truely lost. i drew this up.
__________________
Old 10-22-2009, 09:31 AM   #26
not quite. it should be exactly like this EXCEPT red/black instead of yellow/black (was a misprint in the FSM).. and attach the clutch switch to the brown and the green/black. note the orientation of the release tab relative to the plug, so you get the wires in the right spot. when popping the release tabs on the spade connectors, use a jewelry flat-head screwdriver for best results.. you only get so many shots before the plastic is too chewed up to release. you can just cut/splice the wires if you want tho, if that happens. and dunno if it matters but i used the thicker of the 2 green wires.
draw up another diagram based on this and i'll tell you if it's right
__________________
Old 10-22-2009, 09:43 AM   #27
I Has Pushrods!
maxitech's Avatar
That's how I did mine...
__________________
MODS: VLSD 5-Speed Swap, Exedy Stage 1 Clutch, Turbo Manifold Studs, Koni/Eibach Suspension, Suspension Techniques F & R Swaybars w/ Blehmco RSB Links, Unorthodox Racing UDP, Blehmco Grounding Kit, WSP Y-Pipe, Place Racing CAI, Custom STS, Polyurethane Front & Rear Bushings, Q45 Front Brakes (Blehmco S.S. Lines, Brembo Rotors, Axxis Metal Master Pads), Courtesy Nissan FSTB, Blehmco RSTB, Blehmco Stage II LTB, NissanWorks TB & IACV Spacers, 9007 Headlight Bulb Conversion, GXE Fog Lamps, Sound System (Infinity, JVC, Polk, MTX), 2k3 SE 17" Wheels w/ 225/50R17 Hankook HR Ventus II Tires - 186K miles (bought 8/03 @ 87K miles)
Other Toy: '96 Corvette LT4 6-Speed, 75K miles (bought 3/09 @ 60K miles), Black on Black, Fassstt!!!! Stock, for now...
maxitech is offline   Reply With Quote
Old 10-22-2009, 07:28 PM   #28
Update
Got the harness wired up; little bit of trouble getting the pins out but other than that it when fairly smooth. every thing is working great.
Thanks to everyone that help and thanks to Cape for the great pictures and suport.
should be getting in some test driving tomorrow. i am currently working on an easy to follow schematic for the future 5spd swaps.
__________________
Old 10-22-2009, 08:18 PM   #29
cool. luckily for you the reverse lights worked right off the bat. my reverse switch was fubar so i had no reverse lights for 3 months
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
