MAF?? or other things?
Old 07-29-2009, 11:40 AM
MaximaFan4140's Avatar
ok heres another fix im in...my cars burning gas like crazy after i fill her up til she hits bout half a tank then from there til bout empty it seems a bit more normal of gas usage...could my MAF sensor be causing this problem or wut else could be any ideas wut to check?? car has had recent full tuneup, and im tired of having to put gas in the car like every 4 days lol
MaximaFan4140 is offline
Old 07-29-2009, 12:00 PM
2 VE's are better than one!
James92SE's Avatar
First of all the gas gauge isn't linear, so don't go by "halves" as indicators of gas usage.
Secondly, to be more accurate, how many miles are you getting per tank?
As far as I know, the MAF doesn't generally have any bearing on gas mileage. Did you replace the 02 sensor with your full tune up?
James92SE is offline
Old 07-29-2009, 04:51 PM
Maximus94's Avatar
Like James92SE said, gas gauges aren't linear. Most cars burn fuel at the same approximate rate for the whole tank (unless you start doing some unusual acceleration, etc, half-way thru the tank). Maybe you could let us know a few details about what your tuneup included. Was mileage the same before the tuneup?
Maximus94 is offline
Old 07-29-2009, 06:02 PM
burhan92SE's Avatar
pull the codes out of the ECU first...
burhan92SE is offline
Old 07-29-2009, 06:47 PM
Dhunterx's Avatar
This. I noticed better fuel mileage after the meticulous and stressful task of replacing the knock sensor. (This is related since I had code 34.)
Dhunterx is offline
TallTom
50
07-08-2022 09:54 AM
doctorpullit
03-29-2016 11:08 AM
bigfrank
10-01-2015 12:51 PM
09maxshawn11
09-30-2015 10:28 AM
Quick Reply: MAF?? or other things?
