Go Back   Maxima Forums > Maxima Discussions > 3rd Generation Maxima (1989-1994)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 07-02-2009, 08:42 PM   #1
1993-VG30E-GXE's Avatar
Hose Barb Terminating Fuel Lines
Does anyone know how (is there a tool) to make those hose barb ends of the metal pipe - the bulge in the pipe, exactly like the fuel pipes that go under the car and end up down below hear the steering rack boot at the bottom of the firewall, then our hose connects from that to our fuel filter.
The fuel filter also has the bulges top and bottom.
When I replace the fuel pipes underneath the car, some guy told me I don't even need those bulges, I can just clamp a hose to the pipe. I'm concerned though it could slip off from vibration and movement.
1993-VG30E-GXE is offline   Reply With Quote
Old 07-02-2009, 08:57 PM   #2
Send a message via AIM to infinitiblast
Sure is sold in most hardware stores. I'm at a lost for the name of it right now, but I remember it was less then 10 bucks.
__________________
I miss my Sterling Mist Maxima.
infinitiblast is offline   Reply With Quote
Old 07-02-2009, 09:16 PM   #3
The Dirty Pearl
pmohr's Avatar
To make the barbs or just to make the hump in the end of the pipe? Very big difference.
I'm sure you could find a bead roller for 5/16" tube somewhere.
__________________
Quote:
Originally Posted by 2damax View Post
This jerk is right so often I just search threads hoping he gets something wrong so I can catch him
Quote:
Originally Posted by kizzmyazz View Post
ok so what i found out is that because of the FMU, i dont need to get injectors because it will neutralize the oil pressure to prevent detotnation
FSMs | A32 CEL Decoder | Howto Videos
pmohr is offline   Reply With Quote
Old 07-02-2009, 09:29 PM   #4
Actually, maybe you guys or anyone that did it, can tell me what I need to do on the ends. I thought the word barb meant that end of the pipe with the bulge in it. There's 3 fuel pipes in total. I beleive they are all 5/16".
Do I make 1 hump on each end of the pipes...and the end at the fuel tank, does it basically connect to a piece of fuel injector hose that go straight into the fuel pump? This is the photo in the FSM but haven't seen it in real life yet. I'll need 6 fuel injector hose clamps, 6 humps total at ends of each pipe (3) right?
If anyone has the measurements please post them.
Old 07-02-2009, 09:40 PM   #5
The Dirty Pearl
pmohr's Avatar
Quote:
Do I made 1 hump on each end of the pipes...and the end at the fuel tank, does it basically connect to a piece of fuel injector hose that go straight into the fuel pump? This is the photo in the FSM but haven't seen it in real life yet. I'll need 6 fuel injector hose clamps, 6 humps total at ends of each pipe (3) right?
They should indeed all be 5/16" or 8mm (close enough to be interchangeable), IIRC every Nissan I've ever touched has those size fuel lines.
Well a barb is this (obviously ignore the threads on the right):
The name is pretty intuitive.
Fuel lines generally have a bead rolled into the end, such as this:
Which is what you're referring to.
Looking at FAST (with an image from Courtesy), it does look like there are two fuel hoses coupling the lines to the nipples on the pump assembly:
If you can't find anything to roll a bead in the pipe with, you could always rent/buy a flaring kit for brake lines; when you flare the end, it produces a pretty well defined 'hump' that would serve an identical purpose. Not sure how the ID is affected by that at the flaring site, though.
If you've got some free time and like to construct things, you could try something like this: http://forums.turbobricks.com/showthread.php?t=58790
I know there's an extremely simple answer that I'm overlooking, I tend to do that sometimes.
__________________
Old 07-03-2009, 01:19 AM   #6
Thanks buds this helps alot.
Fuel Spill Question:
After I've released fuel pressure, if there's still fuel in the tank, when I go to remove the send & return pipes from the hoses connecting to the Fuel Gauge Sender Unit, will fuel start spewing out like a syphoning action, and not stop until I plug it with something or the tank ultimately empties?
Old 07-03-2009, 04:35 PM   #7
buy a car from him?
internetautomar's Avatar
Send a message via AIM to internetautomar
Quote:
a flaring tool?
__________________
Maxima parts catalog< Website for sale
96 Green A/T gone
94 Pathfinder POS GONE! | 79 Camaro sold
98 I30t Silver on black A/T gone | 96 Granite Pearl (AKA Purple) A/T gone
92 grey VE A/T gone | 96 I30 Black gone
92 maroon VE A/T gone | 92 white VE M/T gone
92 grey VE A/T gone | 6/84 L24E last of the RWD Maxima gone
internetautomar is offline   Reply With Quote
Old 07-03-2009, 07:57 PM   #8
The flaring tool, for brake lines, I've used will produce a "funnel" shape on the tube end. Must be a tool for the "bulge".
__________________
'97 SE 5spd Super Black
FSTB, Addco RSB, K&N panel filter,
"4DSC" decals, AE shift knob.
Winter Mod - sand bag in the trunk
Curt Deiner is offline   Reply With Quote
Old 07-04-2009, 01:37 AM   #9
Went to the store and bought the SAE 45 flare tool kit and the line bender tool. There is a tool to do the bulge but it's over 900 bucks.
The bulge i'm talking about is not the bulge in Pmors photo. It's the 2 bulges found on your fuel filter, as well as end of injector rail send & receive pipe. The purpose of the bulge I beleive is to position the fuel injector clamp next to it, to give an even better seal or to possibly prevent the hose from slipping off the pipe (once the clamp is tightened down it may be difficult to pull hose off)if it were to move.
I don't think i'm going to follow the advice of one of my automotive buddy, he claims just cut the pipe and use the injector clamp and forget about the bulge. Guy at the store recommended use your OEM bulges and cut the pipe back from that maybe a foot, then use unions or something to join the new pipe. I personally don't like this idea because your adding un-necessary joints...but we'll see.
Here's the example of the tool. And that is one damn expensive tool just to make a bulge, out of my budget. ...............Pmor, the makeshift way is impossible with pipe this tiny inner diameter - sure with a huge pipe like the one in your photo, but imagine trying to do that within a fuel pipe.
www.vansantent.com/Catalog/2009/Bead_Form.pdf
Old 07-04-2009, 09:43 AM   #10
The Dirty Pearl
pmohr's Avatar
You mean like the second picture in my post
Fuel lines have the 'bead' around the end of the pipe to keep the hose from slipping off.
FWIW you could always just take some needle nose pliers and bend the edge of the tube out a little (smooth out any burrs), that would work the same.
__________________
Old 07-04-2009, 09:01 PM   #11
buy a car from him?
Quote:
I was thinking bubble flare.
__________________
96 Green A/T gone
Old 07-04-2009, 11:44 PM   #12
I think a double flare tool can make a bubble flare if you stop before the last step of the double flaring process.
jakeru is offline   Reply With Quote
Old 07-04-2009, 11:52 PM   #13
Ahh... I just learned that a "push connect flare tool" is made just for this job.
Costs a lot more than a double (/bubble) flare tool though. Ones I found with a quick google search were running ~$200.
http://www.inlinetube.com/Straight%20Length/tools.htm
Old 07-05-2009, 01:50 PM   #14
That hydraulic tool is nice but damn is it expensive!
nitrous360 is offline   Reply With Quote
Old 07-05-2009, 02:08 PM   #15
Too bad it's so much. It would be a total waste of money for me, once I do these brake and fuel lines I wouldn't have much of a use for it.
Old 07-06-2009, 12:30 PM   #16
Ad·min·is·tra·tor
DanNY's Avatar
you need this tool (sorry for the large pic).
basically the center hex will push the metal ball out...you then turn the large hex and it will put a bead/groove on the tube.
it's about 30-40 bucks for each size...assuming they have the size 5/16.
http://www.holley.com/types/Earl%E2%...0EZ-Beader.asp
the bead form tool (bead form I) i have and it's great for ICs and etc...but it's too big for your 5/16 tubing.
the 45 flare is ok..but it's a ISO flare...so it bends out and pretty much folds over. that's what's on the stock brake lines. you must use a quality tool and tubing here or else it'll leak.
37 flare is used for AN plumbing.
any questions?
DanNY is offline   Reply With Quote
Old 07-06-2009, 10:49 PM   #17
Good find, I'll buy it. One more question:
After I've released fuel pressure, if there's still fuel in the tank, when I go to remove the send & return pipes from the hoses connecting to the Fuel Gauge Sender Unit, will fuel start spewing out like a syphoning action, and not stop until the tank ultimately empties?
Old 07-07-2009, 05:23 AM   #18
Ad·min·is·tra·tor
DanNY's Avatar
pull up rear seat..pull gas pump cover...pinch lines?
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
