Go Back   Maxima Forums > Maxima Discussions > 3rd Generation Maxima (1989-1994)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 07-06-2009, 10:47 PM   #41
1993-VG30E-GXE's Avatar
Quote:
Originally Posted by DanNY View Post
i picked one up from these guys.
http://www.protorque.com/
Good find, I'll check it out. And good find too on the fuel pipe tool. I'm pretty sure I'll order it from the US and just pay for the shipping. Can't find that tool around here.
1993-VG30E-GXE is online now   Reply With Quote
Old 07-07-2009, 06:26 AM   #42
Call me Wookiee Goldberg
CapedCadaver's Avatar
Quote:
Originally Posted by 1990maxGXE View Post
k i was just making sure that i don't need to fix something else when i replace the tranny.
if you get a new/rebuilt a/t then it'll have a rev sensor on it.
__________________
PieceOut.FallToPeaces New to the forum? CLICK HERE!!!!
1985 Nissan 300zx 2-seater: VG30E | 5spd Swap | Bilstein | 5-lug conversion | Polyurethane everything | Resurrection-in-progress!
2004 Honda Civic EX Coupe: 1.7L VTEC | 5spd | CAI soon | LED tails and Projectors soon | ES Poly Motormounts soon | 'bad weather' car/backup for teh Z
1990 Nissan Maxima GXE: VG30E | VLSD-5 swap | Exedy | NWP | a33b(F)/z31(R) BBK | ES poly | SE susp swap | 2k2SE 17s | retired Aug 28th '09
2005 Nissan Maxima SE: VQ35DE | 6spd | Carolina Panthers front lisence plate | Brother's car, not mine | <-- Therefore still 100% stock
Quote:
Originally Posted by JasonOksa View Post
Horsepower, torque and speed are all known by The State of California to cause cancer, birth defects, and reproductive disorders.
Quote:
Originally Posted by bigleman View Post
how much would it cost to resleeve?
how does an aluminum motor form rust on the cylinder walls???
DO NOT PM ME ABOUT PROBLEMS WITH YOUR CAR UNLESS I TELL YOU TO. THAT'S WHAT THE FORUM IS FOR
CapedCadaver is offline   Reply With Quote
Old 07-07-2009, 07:38 AM   #43
doesnt the self diagnosis start with a long start signal this may be mistaken for the rev sensor so yours is prob ok
it should go ,start signal then 10 "judgement flickers" if all 10 the same
duration then ok if any are longer duration that number relates to the diagnosis chart,
the 3rd gen has these self diagnostic features for= engine(5 different modes) ,trans,abs,airbag,some sensors,digi climate and digi gauges if equipped
3rd gens dont really need them though because ive only seen codes like twice
in 9 years although to say the least ecu mode 4 helps adjust tps sensors,and modes 1+2
can tell you if your running rich or lean and if your o2 sensor works and mode 5
can help find intermittent problems while running
I have to read the fsm page like 4 times to make sure im not missing something
sometimes its over explained or doesnt make sense till i re read and apply it
__________________
91 se"magic stick",92 se"relaxima
maximagician is offline   Reply With Quote
Old 07-10-2009, 11:00 AM   #44
doing solenoid replacement in the engine compartment?
new question about the re4f02a tranny. sorry for hijacking the thread. i dont have the privilege to post.
my trans is jerky and slippy between 1-2 gear. i have not gone through all the test sequences from the factory service manual yet. but it feels like to be a solenoid problem.
looking from outside, the oil pan is on top of the transmission. i am wondering if it is possible to check and replace the solenoids without take the transmission off the engine. please share your experience on this. really appreciate.
i have kept this car for 12 years, replaced fuel injectors, timing belt(s), axles, etc. i hate to let her go.
maaxiimaa is offline   Reply With Quote
Old 07-10-2009, 02:06 PM   #45
it might just be solenoids meaning your valve body which obviously sits under the oil pan that you are talking about. once you remove that pan from above the valve body is right on top and can be easily taken out. damn, now that all you guys are having trouble with your auto trannies i recently threw out a good valve body when my car was an auto. i would have sold it to you one of you for like $100 since it was a rebuilt unit. oh well.
__________________
www.cardomain.com/id/green_max
'93 GXE 5-spd - sporting JDM power fold heated mirrors.
'97 SE Auto - finally running.
'08 BMW 335i Twin Turbo 6-speed - d/d temp.
GRNMAXDMON is offline   Reply With Quote
Old 07-11-2009, 10:47 PM   #46
thanks very much for replying. it really encouraged me. i wish i could buy your vb too.
i went through the electronic sequence. no problem was found. so i went ahead taking the valve assembly body out. indeed, it has some metal powder residue sticking on the solenoids and the valve body. by measuring the resistance of each solenoid i dont see any thing wrong with them.
reading through others post, i saw some people fixed the problem by replacing it anyway.
I am wondering if i can apply the battery voltage to test them.
also is it possible just clean the vb from outside (i dont have the rebuild kit) clean and re-seat the solenoids to get the whole thing work?
thank you!
Old 07-12-2009, 05:06 AM   #47
is it possible to clean the vb from outside (i dont have the rebuild kit) clean and re-seat the solenoids to get the whole thing work?
thank you!
could it be the metal powder? is it making a path around any exposed electrical stuff? gumming up anyting?and wheres it from? i havent ever seen the insides of vg autos
ive only swapped the autos i do have a ve 5-speed opened up tho
__________________
Old 07-12-2009, 09:54 AM   #48
thank you!
im not sure about applying battery voltage to the solenoids??? have you tried searching for a rebuilt VB unit? look into that. like i said when my car was an auto and i needed a rebuilt VB, i paid about $100 for it and just swapped it out with the old one.
__________________
Old 07-13-2009, 11:43 AM   #49
Ad·min·is·tra·tor
DanNY's Avatar
if it only slips on 1-2 and not anything else i doubt it's your VB. your 1-2 shifts are used most often and they wear out 1st. if you tested it and it looks ok then don't even bother going any further. pull the unit down and replace the clutch packs.
DanNY is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
