3rd Generation Maxima (1989-1994)Learn more about the 3rd Generation Maxima here.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
ok can anyone post a link or something that shows me how to replace my power steering pump, belt and hoses with all the little tricks of the trade after doing it?? seems to me like it would be a PITA and time consuming...im not much of a hardcore DIYer but i can manage sometimes lol
__________________ 89 Maxima Aged and Experienced With 310k On The Dash Has Been Reborn!
Thanks CapedCadaver With My Motor Swap....We Both Went Thru Hell to Make It Run Again lol!
VG30E...2.5" Custom Catback to 3" Muffler...18" S-Tech Black on Chrome Wrapped in Pirelli P-Zero 215/35R18...2-10"JL Audio Powered by a Soundstorm 3600/1...5 x1/4's and 6x9's Powered by JVC 400/4 with Jensen 7 1/2 Flip-Out Touch Screen
Ok I have a question. I change my power steering pressure hose and bleed it. The problem Im having now is when I turn the steering wheel its making the sound like its low on power steering fluids. I check it and its full to the top. Does anybody have any suggestion>? Can it be the power steering pump? Thx you for ur help
It probably needs to be re-bleed..
Although, for what it's worth, I replaced my power steering hose with an aftermarket one and no matter what I've done it still whines. From what I can gather on here, several others have had similar symptoms with the aftermarket hoses for some reason
__________________
Desperately looking for a 5 speed axle carrier bracket. Either VG or VE will work. PM me if you have one!
Good working door lock timers $20 shipped. PM me if interested
the theory is incorrect inside diameter on the replacement hose.
96 Green A/T gone
94 Pathfinder POS GONE! | 79 Camaro sold
98 I30t Silver on black A/T gone | 96 Granite Pearl (AKA Purple) A/T gone
92 grey VE A/T gone | 96 I30 Black gone
92 maroon VE A/T gone | 92 white VE M/T gone
92 grey VE A/T gone | 6/84 L24E last of the RWD Maxima gone
While in park and idling, turn your steering wheel to extreme left and extreme right until all the fliud is within the system, continue and top off as necessary to prevent from sucking air into your system. It will make a little noise until all the air is depleted and your system is completely liquid!
I did that but it still whines. When turning to hard left and hard right the power steering fluids makes bubbles.I cant put no more power steering fluid in because its to the max.
If it's making bubble there's still air in the system be patient and keep cycling the steering!
1. Raise front of vehicle until wheels are clear of the ground
2. add fluid into tank to specified level, turn steering wheel quickly from left to right,lightly touching the steering stoppers..repeat procedure until fluid level stops going down..
3. Start engine, then repeat step 2 with the engine running...
thx u will try that tomorrow hopefully that works.
