speedometer going crazy
Old 06-05-2009, 05:31 AM
woot's Avatar
its a 90 se, the thing is i can be driving it and will be keeping a constant speed and the needle will start jerking from say 20mph faster to 20 mph slower.. Another thing is that sometimes it will work imediatly after startup and pulling out and other time i might drive 5 miles before it decides to work, i am leaning toward speed sensor but don't really know !!
woot is offline
Old 06-05-2009, 06:11 AM
woot's Avatar
forgot to mention that my cruise control is not working either but it never has, so dont know if that anything to do with it either
woot is offline
Old 06-05-2009, 07:38 AM
mod or sell?
internetautomar's Avatar
i'd have to concur on the speed sensor. you may be able to fix the sensor by pushing on the topmost part that sticks out of the trans. Sometimes that piece will pop up causing issues.
internetautomar is offline
Old 06-05-2009, 08:46 AM
woot's Avatar
are you talking about the center section, or the whole speed sensor?? i mean can you visually see it sticking up??
woot is offline
Old 06-05-2009, 10:02 AM
Call me Wookiee Goldberg
CapedCadaver's Avatar
center section of what? the gauge cluster? he said "part that sticks out of the trans", which, last time i looked, my gauge cluster was not sticking out of my transmission....
just go look at your speed sensor sortof close to where your steering linkage comes through the firewall) and see if the black cap popped up or if it's still attached.
CapedCadaver is offline
Old 06-05-2009, 12:07 PM
woot's Avatar
yeah i know the part, and yes it is still on the sensor pushed it but no movement,and still screwed up speedo....
woot is offline
Old 06-05-2009, 12:17 PM
then i guess you have to get another sensor. fortunately they're pretty easy to swap.. just a single 10mm bolt and one plug.
Old 06-05-2009, 12:28 PM
woot's Avatar
yeah i took it out the other day to look at the gear on it thought it might be stripped, but it looked good. guess i will have to start looking
woot is offline
Old 06-05-2009, 02:54 PM
see unfortunately, the fact that your cruise control doesn't work makes it harder to conclusively say what the problem is. my speedometer jumped around, and was the gauge (replaced a black w/ a black in 07... then switched to whiteface in 08 and the first white speedo failed too)
replacing either part will hopefully either fix it or let you know it was the other one... findin out what's wrong with your cruise control, however, would make the diagnosis more likely to be accurate the first time.
MR2 T'd
07-09-2021 05:06 AM
Garrettz459
09-28-2015 02:50 PM
jchronis2552
09-21-2015 05:52 AM
Djsmaxima
09-14-2015 11:58 PM
Quick Reply: speedometer going crazy
