Rough Low Idle Speed????
Old 05-08-2009, 03:47 PM
fotoman's Avatar
94 6 cyl Maxima GXE
I have changed spark plugs, wires and rotor and that eased the vibration and rough idling but now the rough idleing has returned with a check engine light that stays on ... the car idles at around 75 rpm under the 1 and has a noticable vibration .... what might be happening what do I need to do? What is a normal idle speed?
Changing fuel injectors is a project over my head what is a reasonable price to get one if not all replaced at a shop and what type of shop????
fotoman is offline
Old 05-08-2009, 03:50 PM
¯\(°_o)/¯
Greeny's Avatar
Check the codes first..
how to check codes--> http://forums.maxima.org/4873104-post18.html
Greeny is offline
Old 05-08-2009, 07:14 PM
fotoman's Avatar
Thanks this looks like something I can Do .......
fotoman is offline
Old 05-09-2009, 12:14 AM
fotoman's Avatar
Going back to the idle speed question
Going back to the idle speed question what is the normal speed and can/should/how is it adjusted?????
fotoman is offline
Old 05-09-2009, 12:36 AM
Call me Wookiee Goldberg
CapedCadaver's Avatar
first warm the car up and have all the accessories (a/c, radio, radiator fans, etc) offturn the screw thing on the ecu to the right (ecu is to left of passenger's feet behind black plastic cover), then go under the hood and adjust the screw on the IACV until you like the idle, then turn the screw on the ecu back to the left again. iacv is the cylindrical thing on the front-driver-side of the intake, sortof between the battery and the throttle body.
CapedCadaver is offline
Old 05-09-2009, 02:33 PM
fotoman's Avatar
ANYONE ....... Im a newbie so pictures are worth a thousand words to me if possible......
I know how to check the ecu but even with a clue i dont see this iacv
fotoman is offline
Old 05-09-2009, 02:45 PM
blue circle = iacv's idle adjustment screw
red x = throttle body and sortof off-frame near the green x is the battery, as i uesd earlier for reference points
Old 05-09-2009, 03:22 PM
1991Maxima1991's Avatar
wow didnt know it was that easy to adjust our idle speed..... nice
1991Maxima1991 is offline
Old 05-09-2009, 05:31 PM
sleepyvg30e's Avatar
if ur check engine light is on u need to do more than adjust idle i would suggest leaving it alone until u check the ecu codes first if no codes pop up (which probably wont happen) then clean the intake in this order
1 maf
2 throttle body
3 iacv
4 entire plenum
....if all that is clean and there are no ecu codes and the check engine light dissapears then try adjusting idle
btw did u adjust timing when u changed plugs wires and the rotor?
sleepyvg30e is offline
Old 05-09-2009, 06:07 PM
¯\(°_o)/¯
Greeny's Avatar
1 maf
2 throttle body
3 iacv
4 entire plenum
http://forums.maxima.org/3rd-generat...code-51-a.html
Greeny is offline
Old 05-20-2009, 08:31 AM
RustyMaxima's Avatar
Do u need to do anything else other then turn that?
RustyMaxima is offline
Old 05-20-2009, 09:48 AM
for idle adjustment? no. if your idle is rough or low though, odds are there's something else you need to fix first. like a misfire or a vacuum issue or a maf issue, etc.
captchaos
03-15-2016 12:18 PM
lrb6805
09-17-2015 04:49 PM
ballerchris510
09-10-2015 09:35 PM
Quick Reply: Rough Low Idle Speed????
