Go Back   Maxima Forums > Maxima Discussions > 3rd Generation Maxima (1989-1994)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 04-08-2009, 05:17 AM   #1
Grounding VTC
So I'm going to ground my VTC and I seen on craig braces page that he used a spliced/bullet connector but i wanna solder my ground wire in thats ok as well right..........
biggz2332 is offline   Reply With Quote
Old 04-08-2009, 05:58 AM   #2
Wanna Go Muddin?
Greeny's Avatar
Go for it, but good luck getting solder to stick to anything.
__________________
3rd Gen parts--> http://forums.maxima.org/1st-3rd-gen...-part-out.html
Greeny is offline   Reply With Quote
Old 04-08-2009, 12:30 PM   #3
Quote:
Yea I just spliced them now VTC knock gone one more problem gonna change my PCV valve and can't locate it
Old 04-08-2009, 07:55 PM   #4
Wanna Go Muddin?
Greeny's Avatar
Back behind the rear valve cover on the passenger side...
__________________
Old 04-09-2009, 05:17 AM   #5
Ok and it has a little hose going to it right
Old 04-09-2009, 05:53 AM   #6
Wanna Go Muddin?
Greeny's Avatar
Yup, it's a pita to access, so be prepared to yell, throw tools, etc.
__________________
Old 04-09-2009, 09:37 PM   #7
Thanx 4 da heads up
Old 09-21-2009, 08:37 PM   #8
mforrest100's Avatar
Send a message via AIM to mforrest100
Can someone point me in the direction of the thread made by Craig Brace?
Thanks...
mforrest100 is offline   Reply With Quote
Old 09-21-2009, 08:58 PM   #9
Send a message via AIM to gapboi210 Send a message via Yahoo to gapboi210
Not a thread, it's a seperate site.
http://www.geocities.com/craigbrace
__________________
'90 GXE
Leather
Bose
Sunroof
120K
gapboi210 is offline   Reply With Quote
Old 11-04-2009, 08:22 PM   #10
anyone know of any faqs to grounding the vtcs. i can't find a link that hasn't expired. thanks
beefbowl is offline   Reply With Quote
Old 11-06-2009, 07:37 PM   #11
Quote:
wat u mean faqs??
Old 11-06-2009, 07:42 PM   #12
Call me Wookiee Goldberg
CapedCadaver's Avatar
Quote:
Originally Posted by biggz2332 View Post
wat u mean faqs??
faq = "frequently asked question"
__________________
PieceOut.FallToPeaces New to the forum? CLICK HERE!!!!
1985 Nissan 300zx 2-seater: VG30E | 5spd Swap | Bilstein | 5-lug conversion | Polyurethane everything | Resurrection-in-progress!
2004 Honda Civic EX Coupe: 1.7L VTEC | 5spd | CAI soon | LED tails and Projectors soon | ES Poly Motormounts soon | 'bad weather' car/backup for teh Z
1990 Nissan Maxima GXE: VG30E | VLSD-5 swap | Exedy | NWP | a33b(F)/z31(R) BBK | ES poly | SE susp swap | 2k2SE 17s | retired Aug 28th '09
2005 Nissan Maxima SE: VQ35DE | 6spd | Carolina Panthers front lisence plate | Brother's car, not mine | <-- Therefore still 100% stock
Quote:
Originally Posted by JasonOksa View Post
Horsepower, torque and speed are all known by The State of California to cause cancer, birth defects, and reproductive disorders.
Quote:
Originally Posted by bigleman View Post
how much would it cost to resleeve?
how does an aluminum motor form rust on the cylinder walls???
DO NOT PM ME ABOUT PROBLEMS WITH YOUR CAR UNLESS I TELL YOU TO. THAT'S WHAT THE FORUM IS FOR
CapedCadaver is offline   Reply With Quote
Old 11-06-2009, 07:58 PM   #13
lol oh i thought he was using that to say facts
Old 11-07-2009, 04:19 PM   #14
Did Craig post his site off geocities since it no longer exists???
__________________
1991 GXE Resurrected from the dead
1989 SE gutted for parts and 5 speed.
300zmax is offline   Reply With Quote
Old 11-07-2009, 06:39 PM   #15
What information are you looking for.
Basically the VTC solinoid is activated by the ECU. The Solinoid has constant power, and the ground is switched by the ECU at RPMS off idle that have a higher throttle point. When the solinoid is activated, it presurizes the VTC by oil pressure. The oil pressure rotates the inside of the VTC 10 degrees to advance the Intake cam timing.
Nissan used the VTC to increase mid range torque, and high end horse power without sacraficing the idle and emmisions.
The ground wire from the two VTC solinoids are hooked together already, so if you ground one of them, they will both be grounded and activated. The problem is, this can also cause idle problems. But the VTC clatter should go away.
__________________
Bill, 1992 Maxima SE, White, black leather seats, ATX with factory VLSD, completly stock.
2003 Altima SE 3.5, Black, black leather seats, HID head and driving lights, Dual Halos, Active tunning grill, Nismo CAI, Nismo STS, OBX Headers, Magnaflow Exhaust, Koni Adjustable shocks, Eibach springs, Maxima LSD, 20" wheels.
wpendl1 is offline   Reply With Quote
Old 11-07-2009, 06:41 PM   #16
Also, when i did this, I was able to solder a wire to the front solinoid wire, then ground it.
__________________
Old 11-15-2009, 05:06 PM   #17
I soldered the ground to the solenoid wire as well, but I also put it on a switch because the engine runs a little lumpy during warm up in colder temperatures. Anyone else have that issue? At the time I grounded mine, I didn't read any posts with others having that issue, and haven't bothered looking up much on it since. It's not bad by any means, the vibration is hardly noticeable, but the exhaust definitely has a lumpy sound, as opposed to that nice smooth hum I was used to. I took the splice I already made into the solenoid wire, ran it through the firewall, and mounted a switch on the console, above the shifter where the coil holders are.
__________________
Ian McLeod - Creedence85
1992 Nissan Maxima SE 5 speed || Hear it!
Creedence85 is offline   Reply With Quote
Old 11-15-2009, 05:13 PM   #18
STFU n00b!
Yeah I ran into that with my car too for a long time. (before I rebuilt the VTCs).. My car had a hard time idling properly when I had the VTCs grounded, so I'd leave them off in the winter when the car was always 'grumpy' on cold mornings. I'd reground them in the summer when it idled better and I had no power from heat soak anyway.
__________________
04 G35 Sedan 6MT- The DD
96 240SX 5 speed- The track toy
93 Maxima SE 5 speed- retired 1-5-09
Check out the toys I make on my website!
Matt93SE is offline   Reply With Quote
Old 11-15-2009, 05:21 PM   #19
Interesting. Good to hear it's normal and not just me. I haven't had too much idle trouble, though I did have trouble with the coolant temp sensor contacts in the harness getting corroded, which lead to coolant temp sensor like symptoms, namely stalling. I chased it around for a while, including readjusting the TPS and cleaning the idle air control. Since then it sometimes stalls during warm up, when I push in the clutch - the idle drops down below normal and ususally picks itself back up, but seems to go lower during warm up and sometimes doesn't catch itself. Lately it's been better though and I haven't touched anything.
__________________
Old 11-15-2009, 05:47 PM   #20
STFU n00b!
You might just have to replace that/those connector/s. Nissan usually sells them with like 6" leads. peel back the rest of the wiring harness, then cut and solder & shrink wrap.
I suggest replacing the TPS, IACV, and temp sensor connectors in your case...
My car won't idle for sheit now with AC on after I ported the heads. I think the engine just needs too much airflow that the IACV can't compensate enough. with AC off, it runs fine although it will dip a bit low when I first let off the gas. with the AC on, it'll just shut off every time I push the clutch in. CONSULT says the thing is working fine electrically.. so I think it's just a matter of not enough airflow. I guess I need to take it apart and drill out the openings a bit to increase the throughput of idle air....
__________________
Old 11-15-2009, 06:15 PM   #21
Wanna Go Fast?™
MrGone's Avatar
IMHO putting them on a switch is the way to go and I think it is easier because you can do all the wiring inside the car vs. hacking up the harness in the engine bay.
Mine had troubles idling at first when it was grounded, eventually they learn but having them on the switch is nice. Plus depending on their condition you can leave them ungrounded and then if they start clacking ground them for 10 seconds or so and then unground them and they'll be quiet for a while. If you have a 5spd car try to find an Automatic Transmission switch (the Power/Comfort switch) and wire them to that for a clean factory look (you'll only use one side of the switch). If you have a FSM or if some of the old links work you can find out how. I probably did a write up, hopefully I wrote the colors in the post instead of just posting a picture that is probably long gone now
MrGone is offline   Reply With Quote
Old 11-15-2009, 06:35 PM   #22
Wanna Go Fast?™
MrGone's Avatar
I hope that works! That would be annoying :-/
It has been a long time since I've toyed with a VE IACV, I hope it isn't too challenging to machine.
Old 11-15-2009, 06:53 PM   #23
STFU n00b!
I'm not too worried about it. I probably won't even run AC when I'm done with what I'm planning, so the AC problems will sovle themselves...
__________________
Old 11-15-2009, 08:53 PM   #24
I was thinking of using an auto. trans. switch but couldn't find one, so went with a black rocker switch that looks pretty good. My VTC's don't tick too bad, but it's nice to have a switch so you don't look like an *** at a stop light when it starts to tick. A guy shouted to me once "your engine needs oil" and then he wondered if it was a diesel. That's good motivation.
I tried cleaning the corrosion on the coolant sensor harness but finally gave up and replaced the harness in the manor you mentioned, about a month or two ago. The corrosion had gotten into the wires a good way down the harness. The TPS and IAC connectors all seem to be in good order and are clean. I would have replaced the coolant sensor too but it appeared to be working fine when I checked it. I still may do it on spec soon but it's been running well.
Funny the IACV might not be large enough for just ported heads. A friend of mine has a 2005 Corvette with a bored and stroked 6.8L LS3 V8, with L92 heads (intake ports are massive), high lift and duration cam, ported intake manifold, and it idles great once retuned. Comparing the stock engine to the 6.8L, the fuel table was bumping up to its maximum level it could adjust to under the stock tune, which is evidence that there is significant increase in airflow, but once retuned idled fine. Now that I think about it though it's a wireless throttle so I don't think it has a conventional IACV.
__________________
Old 11-16-2009, 12:10 AM   #25
So you still have plan for it?? I thought you retired it already? But whatever it is, go for it, i'm sure it is gonna be good!!!
__________________
ebay CAI, DIY ground wires, Otto FTSB, Matt's type II LTB, RSTB, Rear Sway Bar link, Warspeed y-pipe, Full Exhaust W/Hight Flow Cat, ST FSB, Addco RSB, Jeff's Front 13" Z32 BBK, Jeff's Rear Z31 BBK, SS Brake and Clutch Lines, Driver and Passenger Corbeau TRS, E36 head light conversion, Murano 18x7.5 W/225/40/18 Falken 115, Tokico HP shocks and Struts, Eibach spring, Blehmco Parallel links
NismoChi is offline   Reply With Quote
Old Yesterday, 03:11 PM   #26
VTC idea
Hey guys I've been thinking - I want to get an old VTC valve and turn it into AIR house adapter, and then connect it to air compressor and clean the oil galleries with air.
What do ya think ?
Lapajgo is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
