Bose Amp By-Pass
Bose Amp By-Pass
Well my Bose HU took a crap on me (no surprise there) So i jumped on the trust maxima.org to see what i could find and i seen someone said that if you put in a aftermarket HU you need to also change out the speaker because of the amp's. Well i dindnt take this verry lightly and decided to go about this myself like usual. A speaker is a speaker is a speaker no matter what you do to it so i just wired my HU rite to the speakers and they work wounderfull. So here is my low budget Bose fix.
----FRONT-----
First remove the speaker assembly from the car.
Now remove the 12 bolts honding the encloseure together.(shown in green)
Remove the cotton and the 4 bolts holding the amp on.
Cut all the wires as close as you can to the connector.Then remove all the wires except the green,red,yellow,and purple
Remove the amp and flip the enclosure over and remove the 3 bolts that hold the speaker and turn the speaker so the red and green wires are closer to the yellow and purple then re-install the 3 bolts.
Attach the red to yellow and the purple to green.
Reinstall the cotton and put it all back together.
Info-Both front speakers have the y,g,r,p color wires so left and right is exactly the same.
----Rear----
Hop in the trunk
Cut the 4 wires going into the amp
Cut the wires from the amp to the speaker as close to the amp as possible
Attach the wires from the speaker to the two smaller wires that went into the amp.
Disregard the two bigger ones.
I dont remember the colors of the rears but i will get them asap
---Final Step---
Enjoy music again
Here is the Proof (sorry for the music)
----FRONT-----
----Rear----
Hop in the trunk
---Final Step---
Enjoy music again
I seen someone said that if you put in a aftermarket HU you need to also change out the speaker because of the amp's. Well i dindnt take this verry lightly and decided to go about this myself like usual. A speaker is a speaker is a speaker no matter what you do to it so i just wired my HU rite to the speakers and they work wounderfull. So here is my low budget Bose fix.
If anything it will blow the speakers not the HU. 4ohm is running through it not 1. The speakers are ment to run 1ohm connected to the amp with no amp it doesn't matter. Amplified 1ohm is not much different then non amplified 4ohm.
I haven't seen anybody here (not since i have been here, anyway) do this mod, but it is standing electronics knowledge that running a speaker with the wrong impedance can destroy an amp. I have done it with a home audio stereo, and about two or three speakers (I can't remember, it was a few years ago) ran in parallel (dropping resistance to about 1 or so). fawking stereo started smoking, and blew some fuses. tried replacing the fuses, but it took a couple of other pieces out with them. it also fried the speakers.
okay, I dont mean to flame, but nearly every head unit in the past, oh, i don't know, 100 years, or so? has had an amplifier in it. so the speakers are hooked to an amplifier, just not an external one.
Well I will let you know. This is just a temporary fix until i get my tax money to buy a whole system.
A little bit of both
If a 1 ohm speaker is hooked up to a 4 ohm amp, the speaker is operating a lot less efficiently and putting stress on the amp and can cause premature damage to the amplifier. Either way it will technically work (at least for the short term), but what you want to do is match impedance whenever possible. You'll get much more accurate and efficient performance out of your equipment. Replace those Bose speakers, they are designed specifically for those independent amps when connected to the non-amplified stock HU.
Upgraded / replaced HU's
Yea my stock radio went and i ended up bringing it to the now Closing Circuit city for them to put in the Sony X-Plod unit. Works fine just sucks i can only put it on volume 3 before my ears bleed, Even with the pre-amp and equalizer turned all the way down.
But yeah i've had it for 2 years now and no problems, except i think my passenger rear speakers is getting weak
----Rear----
Hop in the trunk
---Final Step---
Enjoy music again
Here is the Proof (sorry for the music)[/quote]
any pictures of the rear?
Hop in the trunk
---Final Step---
Enjoy music again
i did almost the same thing but i was 2 scare 2 cut anything so i just ran new wire directly 2 the speakers but someone stole my hu the next day. The factory hu didn't work when i got the car so i never got a chance to hear what it sounds like, so did yours sound any different after the swap??
