3rd Generation Maxima (1989-1994)Learn more about the 3rd Generation Maxima here.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
..since today in class (about 2 hours ago), we were checking my heater control valve and there's 2 (looks like) vacuum lines that go into it, and one was unhooked and it was fine, we hooked up the line and the metal piece in the valve moved now, then we turned off the car (completing a jobsheet)
about 5 mins later (to check to see how cold the A/C was out of curiosity) and the car wouldn't start but prior to that, my exhaust tube came out and i saw black smoke coming out of the pipe for about 5-10 seconds and then we shut it off, hooked the hose back up, then tried to start it again and it wouldn't stay running
I cranked it about 5 times and it turned over then would shut off immediately, then the 6th time i cranked it and gave it high revs for about 10-15 seconds and then it idled on its own but now it idles at barely 500rpms and it vibrates more violent then before, it even idles bad in park. and the idle surges from time to time as well.
anyone think it could be the vacuum lines?
We unhooked the line that we initially hooked back up but that didn't help at all
If anyone has any ideas on how to fix it, please help!!
__________________ Proverbs 13:18
"He who ignores discipline comes to poverty and shame,
but whoever heeds correction is honored."
WHOA!!! did you notice your temp gauge??? has that been that way for a while or what? mind you, the gauge has one sensor, and the ECU has another (for temperature)... but uh.. did the temp needle go crazy like that before?
__________________ PieceOut.FallToPeacesNew to the forum? CLICK HERE!!!! 1985 Nissan 300zx 2-seater: VG30E for now | LS1/T56 swap coming | Bilstein | 5-lug conversion | Polyurethane everything | Resurrection-in-progress! 2004 Honda Civic EX Coupe: piece of crap | i mean seriously it's a civic | selling soon 1990 Nissan Maxima GXE: VG30E | VLSD-5 swap | Exedy | NWP | a33b(F)/z31(R) BBK | ES poly | SE susp swap | 2k2SE 17s | retired Aug 28th '09
My temp gauge i noticed is bad though, cuz it'll intermittently jump to really hot or really cold out of nowhere (like in the video, just went to really hot)
Here's a list of my problems with the car thus far:
Fans are on constant run as soon as the car is cranked
Idle is bad, start is bad (as seen in video)
Power locks stopped working out of nowhere (has done this two times before)
if the fans are running nonstop then def check the CTS first... the fans are supposed to run nonstop if the sensor goes bad.
Ok well, as i was trying to remove the CTS, the fans kicked off of constant run and my idle is now back to normal. I'm going to verify it in the shop or a garage cuz it's cold out and i was having trouble getting the pin out to check the connection of the CTS
I'll post the video shortly, so you can see what i'm talking about. Could be a bad connection (corrosion maybe; i'll check it as soon as i get it in the garage) Oh and i have a gas leak under the hood woohoo
here's a pic of it
video:
heh, the gas leak at the crossover pipe hoses is very common on these cars. Try tightening up the screw clamps on each one. this usually stops the leak until you are able to replace the hoses with new ones..
seems like everything in that general area is a common problem..the leak at the crossover pipe..the VTC clacking..lol
lol
yeah the idle has always dropped (ever since i've been driving it)
i don't knlow where the iacv is and/or how to clean it
i dunno either on the VE... but the idle shouldn't dive like that. on my brother's car (camry), you can't even tell when he puts it in D just by looking at the tach...
another problem to diagnose..
i wanna clean it up real good but am sketchy on putting on engine degreaser and water this time of the year
small = smaller around than your finger. like the ones going to the fuel pressure reg, the EGR, the charcoal canister, the thing up on the firewall, etc.
ahh i see
the way they did the receiver drier line to the compressor was quite interesting
and i couldn't get that connector out...either they put a real good seal on it or it's got buildup in it causing it to not budge..
wait.... what? pics? why were you messing with it?
and the 'connector' is the CTS connector right? already got the stupidclip off?
Well in class we were testing/identifying the compressor and i had to find out what kind of system and all that it used..
it's a Zexel compressor with 6 cylinders and has a receiver drier..cuz A/C's have 4 processes..
Expansion device
Evaporator
(receiver drier/accumulator on suction line)
Compressor
(put nothing on the discharge line)
condenser
and it repeats all over again
and i was referring to the connector on the receiver drier.
Expansion device
Evaporator
Compressor
condenser
o ok... i thought you were saying this was related to vac lines and i was like... wat
and i didn't wanna make another thread since i haven't 'fixed' this problem yet
but i was wondering if anyone knew the parts number to the front valve cover gasket.
cuz the rear one is..13270-A if i'm not mistaken
i need both of mine changed cause it looks like this now
you can see the camshaft sensor has oil built up on it
and here
behind the Intake manifold, the downpipe? (correct me if im mistaken) has a puddle of oil on it, and as i'm driving, if (like when it's snowy) and the vents where the windshield wipers are, if those are clogged up the smoke re-routes in-cabin like the car is being hotboxed.. and smoke from where it's being burned also escapes on the sides of the hood.
It got really bad just out of nowhere. before, it was an occasional "wif" of smoke and i just thought i was seeing stuff..but now, i can't drive 5 mins without it starting to smoke
anyways, yeah if you guys can help out in anyway (source me to the parts number) i'll order them tomorrow and let the demo begin :grin:
[IMG]http://i53.photobucket.com/albums/g44/Lno_Sacrifice/93%20Black%20Maxima/IMG_3269.jpg[IMG]
and here[IMG]http://i53.photobucket.com/albums/g44/Lno_Sacrifice/93%20Black%20Maxima/IMG_3266.jpg[IMG]
you will need to soak that engine for a while with some good quality engine degreaser (Gunk makes a good degreaser), you will also need to use a scrub brush on it before rising the degreaser off.
The Oil leakage will increase 2 fold in the winter months, due to the cold weather "shrinking the metal valve covers and the worn gaskets a bit..(makes for a bigger gap for the oil to seep out, or in your case, POUR OUt!!
