AC tensioner pulley help
My AC tensioner idler pulley self-destructed last week. I picked up a replacement from Autozone and I have a problem.
In this pic you can see the inner part of the bearing from the old pulley is stuck on the shaft so I can't put the new one on.
These are the old and new pulleys:
So is this going to work or am I going to have to order the whole OEM assembly? Also I don't understand how to move the tensioner. I turned the long screw but it only moves itself up and down. Sorry for being such a noob, I'm just trying to save some $.
Anyhow, you can try and remove the tensioner assembly and pull the sleeve of the bearing off with vicegrips or something. Having it off the car should make it alot easier to get more leverage than trying to mess with it in a cramped area. If not, I have a pulley assembly with a noisy bearing on it that i can try and pull off, and if that works, you can buy that and put your new pulley on it. Luckily for you it's almost winter, so you can leave the a/c belt off until you get this taken care of. I'll try and take mine apart today and see if it comes off ok.
ummm...if i remember it correctly there's a bolt/nut you have to unbolt on the face of the pulley and then you can turn the adjusting bolt.
i'm pretty sure it's a nut and it's a bolt/stud that holds the pulley on. So you basically need that piece. the long bolt behind it is screwed into this stud. so yeah from the looks of it that piece broke off.
if caped doesn't have one i might.
Correct me if I am wrong but I guess the sliding tightener bolt is structurally like in a 2k2 alt tensioner, see below (just replaced the bearing, 10$):
http://www.cardomain.com/ride/748507/23
look at your pic...there's a nut that in the center of the bearing that holds the pulley tight in the adjusted spot...well that's broke. in your 2nd pic the back side where it shows what it looks like a square bolt...he basically needs THAT piece.
DanNy, I have the bolt that goes into the face of the pulley (the bolt that goes into the bolt) off. But alas, the old pulley piece remains attached.
Caped: the adjuster bolt moves freely, but the tensioner assembly stays put.
either way you wana just get the one i have and put your new pulley on it?
i know they rent gear pullers at pep girls.
BUT if it's really siezed on there it might be too messed up to put the new pulley on....just becareful with it.
While i may be hijacking, i'm in the same area.
wish i woulda gotten to you sooner. as I was dremeling the original bearring off (was the only way) I stuck a screwdriver in it and pulled and the whole thing came off. good news is i didn't have to finish dremelling, bad news is I have to get the thing back in there with 1 hand pretty much.
Did you take off the wheel or slip it on through the bottom? problem with me is the frame pretty much covers where it goes on but taking off the wheel WOULD give me 2 hands to work with.
06-06-2017 02:01 PM
rbarnes
12-31-2015 06:29 PM
