Go Back   Maxima Forums > Maxima Discussions > 3rd Generation Maxima (1989-1994)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 01-20-2009, 03:25 PM   #201
Wanna Go Muddin?
Greeny's Avatar
Detail all things you have done so far to fix the current issue..
iirc, the last thing you done was put some gasket stuff on the cracked coils, right?
__________________
3rd Gen parts--> http://forums.maxima.org/1st-3rd-gen...-part-out.html
Greeny is offline   Reply With Quote
Old 01-21-2009, 10:59 AM   #202
what plugs are you running? also maybe u should consider a good used set of coils, if ur running the VG plugs that will be causing problems, most places dont kno the diff between the engines
PMAX08 is offline   Reply With Quote
Old 01-21-2009, 05:10 PM   #203
buy a car from him?
internetautomar's Avatar
Send a message via AIM to internetautomar
Quote:
the plugs will work for either one in either motor
__________________
Maxima parts catalog< Website for sale
96 Green A/T gone
94 Pathfinder POS GONE! | 79 Camaro sold
98 I30t Silver on black A/T gone | 96 Granite Pearl (AKA Purple) A/T gone
92 grey VE A/T gone | 96 I30 Black gone
92 maroon VE A/T gone | 92 white VE M/T gone
92 grey VE A/T gone | 6/84 L24E last of the RWD Maxima gone
internetautomar is offline   Reply With Quote
Old 01-21-2009, 07:31 PM   #204
the vg asks for diff plugs than the ve, almost a 10 dollar diff per plug 2, at the dealer anyway, other stores tho have the same plug listed for both engines, i bought my ngks from nissan, the wrong ones were in my 92 se when i bought it, i also replaced some coils to at the same time so im not sure what fixed the stumbling issue exactly, but the coils i took out werent cracked or anything and ive never bothered to test them as the issue was fixed, courtesy has em at a 6 dollar diff a piece as well and the code on the plugs are diff, im guessing the dohc ones run hotter
dohc
http://www.courtesyparts.com/22401-p...-p-183553.html
sohc
http://www.courtesyparts.com/22401-p...s-p-44570.html
Old 01-21-2009, 07:40 PM   #205
buy a car from him?
the heat range difference is 1.
the VE is supposed to have a laser platinum plug, but you can use the copper plugs in place of them.
The opposite is true as well.
These motors are not that fussy about the plug as compared to the newer toyotas which have to use the EXACTLY correct plug or you will set off the CEL
__________________
96 Green A/T gone
Old 01-21-2009, 07:44 PM   #206
ah ok, must have been a faulty coil than causing the problems, so i literally payed twice as much money for nothing it sounds like, o well guess ill kno for next time
Old 01-21-2009, 07:52 PM   #207
I can has?
Pearl93VE's Avatar
Send a message via AIM to Pearl93VE
+1 for confirmation; I've ran NGK plats and coppers in my car. Generally, copper is a better electricity conductor than platinum, but doesn't cut it for longevity. I prefer the coppers in the VE and platinum in the VG
__________________
Pearl93VE is offline   Reply With Quote
Old 01-27-2009, 09:50 AM   #208
Im running ngk platinum. I think im getting a used set of coils and an egr.
92maxima92 is offline   Reply With Quote
Old 02-05-2009, 01:45 PM   #209
Got a set of used coils. My coils were cracked. Car doesnt have the problems anymore as of now. Thanks for all the help guys. Again The coils fixed the problem thanks GREENY!!
Old 02-05-2009, 01:51 PM   #210
Wanna Go Muddin?
Greeny's Avatar
Old 02-05-2009, 02:01 PM   #211
Way out West
Cliff Clavin's Avatar
Send a message via AIM to Cliff Clavin
I didn't want to read through 6 pages of this crap.
It is almost certainly your coil packs. With the used ones, this could happen again. It's somewhat common.
Do a search for the phrase "bucking" in the 3rd gen section. There is a long thread about this from maybe 4 years ago.
MrGone and I tried swapping out virtually everything possible on my car and it ended up being one of the rear coil packs that was bad.
__________________
Cliff Clavin is offline   Reply With Quote
Old 02-05-2009, 02:03 PM   #212
Wanna Go Muddin?
Greeny's Avatar
He fixed the problem with a different set of coilpacks chris..
Old 02-13-2009, 10:11 PM   #213
I have a 92 max se dohc. ve30de, with an automatic tranny. I have been having the same probs as this guy. The car cuts out when driving down the road or sitting still. The tack. will drop to zero when driving or sitting still. Accelerator will respond sometimes and sometimes it will not cause the car will die, but not always. I shift to neutral and the engine always starts backup immediately. When you give it throttle it will usually take off again, but sometimes not. Its as though you have turned the key off when this happens. I have replaced the cam position sensor and other items as well. Plugs, wire, injectors. Have done numerous other tests. Its been a year or so since I last worked on it. Started out doing this occasionally, but now its everytime you start it up. Any help would be deeply appreciated. Love the car so much its still in the drive, just hoping to fix someday thank you
himey58 is offline   Reply With Quote
Old 02-14-2009, 09:22 AM   #214
gen3fan's Avatar
OK, I don't know how far things have diverted from the original question at this point, but I've been having a very similar issue:
1) motor "cuts out" a lot, meaning it acts as if it suddenly loses spark or fuel, just for a second, then regains and runs again. Its especially bad several minutes after its been running and before it warms up completely. Sometimes it stalls out completely, and have to restart. Often while its driving during this period, it behaves similar to how if you're running out of gas (and we've all been there, admit it) and using the last few drops of fuel and you get that "surging" effect. After it warms up completely, it pretty much goes away, except for occasionally stalling out, especially when I'm at a light right after it turns green (of course).
2) I had it hooked up to a diagnostic and it showed no issues with spark or fuel. The supposed explanation is that there is a lot of carbon buildup in the motor and it will just have to slowly burn out. I've been filling up with high test, plus a couple containers of octane boost, plus a dose of Seafoam, each time, and the problem has been marginally getting better.
Hope this helps, or at least rings a bell with somebody.
gen3fan is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
