Go Back   Maxima Forums > Maxima Discussions > 3rd Generation Maxima (1989-1994)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 12-03-2008, 10:07 PM   #121
Ok so I took the pin out of the MAFS But before i unplugged my MAFS I tried to start my car and it fired right up almost stalled after about 5-10 seconds. Should i take it for a drive and see what goes on or should i unplug the sensor and do that or what???
92maxima92 is offline   Reply With Quote
Old 12-03-2008, 10:09 PM   #122
Quote:
Originally Posted by 92maxima92 View Post
It was the left one on passenger side but im going to unplug my MAFS now ill let you guys know what happens
There's simple test to check your CMPS and few other vital parts: remove it from the engine but keep the harness connected. Put ignition to ON and turning its shaft by hand - LISTEN. You should hear injectors clicking while turning the shaft. If you remove a coil and put a spare spark plug in and put it somwhere to touch the engine ground you can also watch the sparks while turning the shaft. ECU trusts this sensor a lot . It is a little tricky to put back, please be patient, it is not that bad: you have to turn its shaft to match the camshaft, don't force it in.
__________________
2k GLE
Max_5gen is offline   Reply With Quote
Old 12-03-2008, 10:13 PM   #123
Old 12-03-2008, 10:14 PM   #124
Wanna Go Muddin?
Greeny's Avatar
Hmmm..Bad connection maybe? lol j/k
TEST:
Try unplugging first..(engine will not rev over 2000rpm with it unplugged) see if it will idle/rev ok with it unplugged(trying to diagnose a bad maf here)
If idle/rev ok with unplugged, shut car off, plug back in, restart,let us know...
Check the maf connector for corrosion and/or loose connection first!!
Greeny is offline   Reply With Quote
Old 12-03-2008, 10:16 PM   #125
Wanna Go Muddin?
Greeny's Avatar
and i'm off to bed mang..Good luck
Old 12-03-2008, 10:22 PM   #126
OK im gonna go do that right now even tho its 12:21 i dont care what ever thanks for all the help ill let you guy know in a could mins.
Old 12-03-2008, 10:47 PM   #127
OK so i unplugged it and it revved to 2500 rpm no higher. I didnt try to start it after that cause i dont want to cause anymore problems but i have no idea??
Old 12-03-2008, 10:50 PM   #128
It wouldnt start after it stalled and i tried to start it again wtf is going on here????
Old 12-03-2008, 11:01 PM   #129
Im pretty sure i forgot to hold the clutch down after it fired up. It confused me and i dont know whats going on here
Old 12-03-2008, 11:05 PM   #130
Call me Wookiee Goldberg
CapedCadaver's Avatar
Quote:
good idea. but remember to make paint marks on the sensor and on the engine so you line it up the same as the way you took it off..... you don't want to mess up your base timing by lining it up wrong.
when the maf is unplugged, it will not rev past 2500. that's normal.
__________________
PieceOut.FallToPeaces New to the forum? CLICK HERE!!!!
1985 Nissan 300zx 2-seater: VG30E | 5spd Swap | Bilstein | 5-lug conversion | Polyurethane everything | Resurrection-in-progress!
2004 Honda Civic EX Coupe: 1.7L VTEC | 5spd | CAI soon | LED tails and Projectors soon | ES Poly Motormounts soon | 'bad weather' car/backup for teh Z
1990 Nissan Maxima GXE: VG30E | VLSD-5 swap | Exedy | NWP | a33b(F)/z31(R) BBK | ES poly | SE susp swap | 2k2SE 17s | retired Aug 28th '09
2005 Nissan Maxima SE: VQ35DE | 6spd | Carolina Panthers front lisence plate | Brother's car, not mine | <-- Therefore still 100% stock
Quote:
Originally Posted by JasonOksa View Post
Horsepower, torque and speed are all known by The State of California to cause cancer, birth defects, and reproductive disorders.
Quote:
Originally Posted by chrome91 View Post
if i had a AE86 delivering tofu, i could have dr1fted around miss JDM van
DO NOT PM ME ABOUT PROBLEMS WITH YOUR CAR UNLESS I TELL YOU TO. THAT'S WHAT THE FORUM IS FOR
CapedCadaver is online now   Reply With Quote
Old 12-03-2008, 11:34 PM   #131
I just started it again but i had to give it some gas before it started again. Once warm It idled at 1200-1300 rpm??? How do i post a video so you guys can see whats going on??
Old 12-03-2008, 11:36 PM   #132
Send a message via MSN to burhan92SE
it fired up without holding clutch? is that wut u meant?.....if that so then ur safety switch is messed up....and how about the maf? after u plugged in, did it start?
__________________
WANT MAXIMA ON FACEBOOK? click here http://www.facebook.com/home.php#/gr...id=40968904022
Selling my VG --->http://forums.maxima.org/canadian-cl...m-edition.html
burhan92SE is offline   Reply With Quote
Old 12-03-2008, 11:37 PM   #133
www.youtube.com
__________________
Old 12-03-2008, 11:58 PM   #134
Quote:
that won't cause the car to stall out while driving!
he was flustered and accidentally let off the clutch with the car in gear, and stalled it sitting in his driveway, while trying to see if unplugging the maf would help. READING>>>>>>>>>>>> you
__________________
Old 12-04-2008, 04:02 AM   #135
I had the MAFS unplugged and it did start but wouldnt rev past 2500 Rpms. And yes i Believe i let go of the clutch while in gear like you said.
Old 12-04-2008, 05:26 AM   #136
Wanna Go Muddin?
Greeny's Avatar
running the engine with the maf unplugged will not hurt anything..No rev past 2500rpm is normal with the maf unplugged...
You need to do the maf testing procedure exactly like i outlined in post #124, We cannot help you diagnose and fix the problem unless you do the tests and report back the results..calm down, relax, read, test, report back..
Post #124---> 92 VE Stalling out while driving??
Old 12-04-2008, 05:52 AM   #137
Quote:
Originally Posted by Greeny View Post
running the engine with the maf unplugged will not hurt anything....
Hurts stomach: the idea that now I cant pass even vw beetle makes me sick.
Wiking is offline   Reply With Quote
Old 12-04-2008, 10:05 AM   #138
OK so you want me to unplug the MAFS and then what would you like me to do after i start the car??
Old 12-04-2008, 11:14 AM   #139
OK i unplugged the MAFS and it fired right up. This is weird because after i got home the car wouldnt start. But anyway with the MAFS unplugged it idled fine but wouldnt rev over 2500 rpms. Whats the next thing i should be looking for??
Old 12-04-2008, 11:27 AM   #140
Wanna Go Muddin?
Greeny's Avatar
Ok, now plug the maf harness back in, make sure the connection is not loose, start car....If it has problems running after plugging the maf back, then you need to replace the maf sensor.
__________________
3rd Gen parts--> http://forums.maxima.org/1st-3rd-gen...-part-out.html
Old 12-04-2008, 11:45 AM   #141
Ok im gonna start by saying WTF. After doing these things things i took it for a drive and she ran like a beauty?? Im really confused but im not complaining. It didnt have the problems at all?? Its about 10-15 degrees warmer outside maybe my maxima doesnt like the cold weather it didnt start happening untill it was cold outside. Ill keep you guys updated. All of your help was greatly appricated! Thanks guys!!
Old 12-04-2008, 01:17 PM   #142
Wanna Go Muddin?
Greeny's Avatar
sounds like you had a bad connection at the maf harness, just fiddling with it restored the connection back to good.
Let us know if you have anymore trouble with this issue, good luck..
Old 12-04-2008, 02:12 PM   #143
Oh, that ... There's a spray called Deoxit which works from my experience. I recently got some gremlins myself - car started to act so strange when shifting gears (auto) that I started to worry if I would be able to get home by myself. Opened the hood pulled all the important sensor connectors, sprayed with that thing and put electrical grease in the connectors - 40 minutes later everything was back to normal and it's has been staying this way for a month already. I didn't even bother to pinpoint which one was actually at fault. The car shifted harsh like it does when you remove resistor but it also was doing 'double shift' when going 1->2, it felt like it engaged-disengaged-engaged again detween 1 and 2 and also didn't want to upshift to 3 and 4 easily. I didn't even bother to think much with all that went wrong at once.
__________________
2k GLE
Old 12-04-2008, 05:48 PM   #144
buy a car from him?
internetautomar's Avatar
Send a message via AIM to internetautomar
Well, you didn't "Flood" it if thats what you are worried about, this is not possible on fuel injected engines.
you can flood a fuel injected motor. That is why you have the hold the pedal to the floor shut off the injector feature.
__________________
Maxima parts catalog< Website for sale
96 Green A/T gone
94 Pathfinder POS GONE! | 79 Camaro sold
98 I30t Silver on black A/T gone | 96 Granite Pearl (AKA Purple) A/T gone
92 grey VE A/T gone | 96 I30 Black gone
92 maroon VE A/T gone | 92 white VE M/T gone
92 grey VE A/T gone | 6/84 L24E last of the RWD Maxima gone
internetautomar is offline   Reply With Quote
Old 12-04-2008, 08:57 PM   #145
Wanna Go Muddin?
Greeny's Avatar
Quote:
No, you cant brian, unless their is a mechanical problem causing the flooding, you can press the gas pedal all day long on fuel injected engine with the ignition on or off and it will never flood the engine out, unlike a Carbureted engine.
Old 12-05-2008, 12:19 AM   #146
he meant cranking the engine over a whole bunch (which does simultaneous injection... lots of fuel for startup) and having a problem keep it from starting. if you then quickly fix that problem (for example, forgot to plug a harness back in that was needed for you to make spark) and go back to start it, all that no-spark cranking will have put a lot of gas into the cylinders... hence why you floor the pedal to start it in that condition, cuz you already have gas a-plenty in the cylinders.
as for the problem itself with this dude's car.....
he's checked all the harness connectors..... but what about grounds?
__________________
Old 12-05-2008, 01:14 AM   #147
Well, i have been in here for a while since i bought a newer car, anyway, i was having a almost identical problem he is having, once in a while the car will stall wile driving, post a message here trying to find an answer, not much responded back then, started looking around under the hood and found out the battery terminal was crack, don't remember which one, replace it, never happen again.
It will only take a second, go check the terminal.
__________________
ebay CAI, DIY ground wires, Otto FTSB, Matt's type II LTB, RSTB, Rear Sway Bar link, Warspeed y-pipe, Full Exhaust W/Hight Flow Cat, ST FSB, Addco RSB, Jeff's Front 13" Z32 BBK, Jeff's Rear Z31 BBK, SS Brake and Clutch Lines, Driver and Passenger Corbeau TRS, E36 head light conversion, Murano 18x7.5 W/225/40/18 Falken 115, Tokico HP shocks and Struts, Eibach spring, Blehmco Parallel links
NismoChi is offline   Reply With Quote
Old 12-05-2008, 02:05 AM   #148
u can take that rubber cover off from the maf harness and pull the each wire going to the maf and u will find ur lose connection....i had the same problem and i jus went to the JY and cut the maf harness from GXE ( i have VE ) and hooked it up..since then never got any problems.....i hope dat helps bud....gud luck...
__________________
Old 12-06-2008, 01:36 AM   #149
Sorry guys i havent been on in a couple days. But my maxima is still acting up. Im gonna check out the terminals and check out that MAFS plug. Ill let you guys know if i find anything different. Again thanks for all the help. Oh and if anybody has a diagram where all the ground wires are please post it.
Old 12-06-2008, 02:49 AM   #150
Wanna Go Muddin?
Greeny's Avatar
Unplug the maf again, actually drive the car for a while with the maf unplugged(yes, 2500rpm will be your redline with it unplugged, this is normal, it's called "limp home mode") just ease the car around, don't hit the 2500rpm if at all possible..
If the car doesn't "act up" during this test, then you have narrowed it down to either the maf harness not getting a good connection, or a bad maf.
Old 12-08-2008, 02:23 PM   #151
Ok so i unplugged the MAFS and it didnt help. It still had the problems. I dont know what to do anymore. Do you have anymore suggestions to do or look for?? I wasnt able to hit 2nd gear before it acted up (I was pushing on the gas pedal and all of the sudden nothing and then it came back and happened again and again.) The tachometer actually works while this is happening also. It must have just dropped to zero when it was stalling or almost stalled. Any help would be great??
Old 12-08-2008, 02:26 PM   #152
Wanna Go Muddin?
Greeny's Avatar
Are you keeping the rpm of the engine under 2500rpm while driving around with the maf unplugged?
Old 12-08-2008, 02:41 PM   #153
Lol I understand do you recommend that i should use the black Rtv sealant or and of them will do the job to try to fix the cracked coils??
Old 12-08-2008, 02:42 PM   #154
Yes i did but the problems were still occuring.
Old 12-08-2008, 02:45 PM   #155
Wanna Go Muddin?
Greeny's Avatar
Yes, use black rtv sealant on the cracked coils, it may fix them unless they have failed internally.
Old 12-08-2008, 02:46 PM   #156
Sorry Yes I did keep it under 2500 rpms.
Old 12-08-2008, 03:12 PM   #157
Wanna Go Muddin?
Greeny's Avatar
Post a video of what the car is doing while driving it..
What kind of camera do you have?
Old 12-09-2008, 04:02 PM   #158
Im having trouble finding rtv sealant gasket maker but i found gasket sealant will that work??
Old 12-09-2008, 04:05 PM   #159
Or i just need the stuff thats posted in your pic??
Old 12-09-2008, 04:05 PM   #160
Wanna Go Muddin?
Greeny's Avatar
Trouble?
It's at walmart/autozone/advanced auto/napa/etc.
What kind did you find?
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
