Go Back   Maxima Forums > Maxima Discussions > 3rd Generation Maxima (1989-1994)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 12-03-2008, 02:04 AM   #41
Call me Wookiee Goldberg
CapedCadaver's Avatar
Quote:
Originally Posted by LvR View Post
Let me state the obvious and incur the wrath of the community:
This is not a job to experiment with - you either do it right or you don't do it at all.
A loose belt will at best allow you to retention it if nothing has happened - at worst it will jump a tooth or more or even come right off requiring an engine replacement at this age.
A too tight belt will at best allow you to slack off on the tension if nothing happened and it was only noisy - at worst the belt itself can break or more likely the nose of the crank can be broken right off (see the huge number of threads on this topic here already) also requiring an engine replacement.
Don't F**k around with this - if you are lucky to have a motor still running with an improperly adjusted belt and didn't understand the manual the first time round, make damn sure you do it right the second time round by removing the covers and following the manual - the fact that you guys are asking all sorts of funky questions leads me to believe any other method is bound to end in misery as a result of inexperience.
to be honest, i didn't actually do this by the FSM (except the torque spec on the locknut). I just put the belt on the same way my uncle did on my car.. i never saw them use any sort of force-measuring device so i didn't use one either. as far funky questions... well, wiking has some funky methods, but most of the time his endeavours are successful so i wanted to be sure i understood what he was saying. But given that i'm 99% sure i'm going to have to re-tighten the belt anyhow, yea, i'll pull the covers. It just figures that the one time i underestimate the necessary level of precision of something is the one time i pick the WRONG thing to underestimate.
__________________
PieceOut.FallToPeaces New to the forum? CLICK HERE!!!!
1985 Nissan 300zx 2-seater: VG30E | 5spd Swap | Bilstein | 5-lug conversion | Polyurethane everything | Resurrection-in-progress!
2004 Honda Civic EX Coupe: 1.7L VTEC | 5spd | CAI soon | LED tails and Projectors soon | ES Poly Motormounts soon | 'bad weather' car/backup for teh Z
1990 Nissan Maxima GXE: VG30E | VLSD-5 swap | Exedy | NWP | a33b(F)/z31(R) BBK | ES poly | SE susp swap | 2k2SE 17s | retired Aug 28th '09
2005 Nissan Maxima SE: VQ35DE | 6spd | Carolina Panthers front lisence plate | Brother's car, not mine | <-- Therefore still 100% stock
Quote:
Originally Posted by JasonOksa View Post
Horsepower, torque and speed are all known by The State of California to cause cancer, birth defects, and reproductive disorders.
Quote:
Originally Posted by chrome91 View Post
if i had a AE86 delivering tofu, i could have dr1fted around miss JDM van
DO NOT PM ME ABOUT PROBLEMS WITH YOUR CAR UNLESS I TELL YOU TO. THAT'S WHAT THE FORUM IS FOR
CapedCadaver is offline   Reply With Quote
Old 12-03-2008, 02:10 AM   #42
LvR
Absolutely nothing wrong with Wiking's suggestions either here or elsewhere - IF AND WHEN YOU UNDERSTAND THE OPERATION AND INTERACTION OF ALL THE MECHANICALS INVOLVED - I use many of the same methods to save time, but experience and understanding the implications of one's actions plays a huge role here.
LvR is offline   Reply With Quote
Old 12-03-2008, 02:17 AM   #43
Quote:
Now pls tell me which 'method' is funky? A belt tightening becomes only an issue when observed via bottle bottom...
Tension checkup; if one cant do that just prying the cover top, then its best to let others tow it to stealership for the teens.
Wiking is offline   Reply With Quote
Old 12-03-2008, 07:51 AM   #44
STFU n00b!
Wikings methods on the timing belt are spot-on. I've been doing timing belts for 15 years and that's the way I do them too. that's how a very experienced mechanic (and well qualified- not just a hack shop grease monkey) taught me, showing me the FSM for some other vehicles while he was doing it.
Belt tension checks are pretty much an industry standard. Nissan has some other strange methods of checking the tension, but this method works 100% of the time.
And also as he said, timing belts are NOT something to "learn on". If you've never done one, have someone that has help you through it. This is not a place to screw up. the potential risk is days of labor and hundreds or thousands of $ in repair costs to replace the engine. If you're lucky you *might* be able to rebuild, but 12 valves at $25 each + head gaskets + head job + valve guides + etc etc etc = about $900 for a cheapie rebuild.
That's a lotta hassles because you weren't sure of what you're doing.
__________________
04 G35 Sedan 6MT- The DD
96 240SX 5 speed- The track toy
93 Maxima SE 5 speed- retired 1-5-09
Check out the toys I make on my website!
Matt93SE is offline   Reply With Quote
Old 12-03-2008, 11:02 AM   #45
i just thought it a bit 'funky' to check the tension without removing the cover. but being that you actually have a fixed reference point (top of the cover), that lets you be even more precise than you would have with the covers off, in terms of measuring deflection.
well the motor hasn't shown any signs of trouble so far. he's been driving it since september like that...so i guess 6-8k miles. Depending how smoothly things go on thursday and friday, i should be able to have him come over here and i can fix the tension, no harm no foul.
I did watch someone else do one before (actually it was on my car, in mid-2007 before i was brave enough to perform tasks like this), but either they didn't check the tension, or i just wasn't looking when they did.
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
