Wiper fluid leak
Wiper fluid leak
Hello! I've had this problem for a while but I think it's time to pay attention and fix it.
My wiper fluid is filled to the top no problems, I activate the wipers no problem, but if I use the fluid it comes out normally and clean my windshield perfectly, but then I park the car and I see a drip coming from inside of the front bumper passanger side (obviously cuz there's the wiper fluid box) and it doesn't stop until the whole fluid is gone.
If I fill it up again it won't drip, but if I activate the wipers using the fluid it will go again draining all fluid.
This makes me think there's either a problem with the pump or the hose not the fluid container, I've tried to peek under the car but it seems a PITA to access this section, so I rather check with you guys to see if you have any suggestions before doing anything, Thanks!
I haven't take a deep look at it but my first guess when looking at the wiper fluid container was that I need to access all this section from under the car, am I right?
or probably that "black shield thingy" you refer is what it makes me think I would have to access from under the car and I just need to remove that thing.
Mine has been leaking for years, it's a slow leak, usually takes about a month or so for the washer fluid light to come on.
I poked my head under there some time back, i think it's leaking somewhere around the pump motor seal. I'll fix it if it gets worse.
Mine did this before the engine swap (back in January I think) and never put enough attention to it, but since winter is coming up I'm going to use the wipers and well I think I'm missing to fix something in the car
BTW, my washer fluid light never comes on, and it's a slow dripping also but maybe faster than yours, I used the wipers on saturday and sunday morning was a considerably big spot of fluid then monday a little bit smaller so tueday and today just a few drops.
LMAO
mmmm.... I didn't get exactly what you are asking me caped, first, yes if I go right now and pull the wiper switch to activate the fluid I can hear the buzzing sound from the pump and after about a second fluid start coming out from nozzles and hit the windshield.
The dripping has completely stopped by now, so if I go out and fill it up it won't drip until I activate the wipers again, after I use it it will keep draining the entire tank until there's something like 10% of fluid, or least that's what I can see aprox, the drip is exactly from inside the fender where the front bumper ends on the very corner
rmd, just jack the front up, put the car on stands, remove the plastic sheild, and get someone to operate the pump when you are there watching. It's much easier to re-produce the problem and you'll see exactly what's happening.
I think I recall removing that front wheel to access moving the sheild - and I didn't completely remove the sheild, I just pulled the front part down when I removed 3 of the plastic clips.
I had a similar scenario as you, but when I poured it into the tub, it started leaking right out the bottom. Somehow the hose got disconnected - that's all it was. But yours is a bit different.
I drove a whole winter without washer fluid - it was the worst.
litch
123
01-04-2024 07:01 PM
06-06-2017 02:01 PM
Need help
23
10-02-2015 08:56 AM
