No radio reception
Old 05-09-2016, 06:08 PM
Say Candyman 5 times
CandiMan's Avatar
No radio reception
Radio and antenna have been changed. No difference, still no reception. Is there a ground wire for the antenna circuit or something similar ?
CandiMan is offline
Old 05-10-2016, 02:08 AM
DennisMik's Avatar
There is a long antenna wire that runs from the rear powered antenna to the radio in the dash. Perhaps this wire has been damaged.
What I do is put a # 0 Philips screwdriver in the radio's antenna socket (or anything that is the size of the antenna wire tip) and then touch the screwdriver shaft. I then become the antenna. If you touch the radio chassis, you are grounded out and this won't work. This also won't work if you have weak radio reception. You could also attach a piece of wire to the screwdriver shaft.
DennisMik is offline
Old 05-10-2016, 10:40 AM
ac max 92's Avatar
Or you could always make sure you pick up a passenger that can sing my guess would be like Dennis mentioned the wire may be damaged. Have you checked the connection on the back of the deck?
ac max 92 is offline
Old 05-13-2016, 05:59 AM
Ad·min·is·tra·tor
DanNY's Avatar
is your back windows tinted?
IIRC - nissan used two antennas...one that's in the back glass/defroster and the other is the actual antenna that goes up and down.
if you swap to an aftermarket radio i believe the antenna adapter only uses one of the signals. maybe swap the antenna wire to the other one? total guess here.
DanNY is offline
eastsidemoon
05-15-2021 05:51 AM
FTMFW702
05-09-2016 08:30 AM
Publixman99
05-03-2016 08:09 AM
cowboyup
04-24-2016 12:26 PM
cols
04-15-2016 11:37 AM
Quick Reply: No radio reception
