Go Back   Maxima Forums > Maxima Discussions > 3rd Generation Maxima (1989-1994)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 08-17-2008, 02:01 AM   #1
1993-VG30E-GXE's Avatar
Rear Calipers - When Do You Replace?
Is there a lifespan of these parts? How many miles?
1993-VG30E-GXE is offline   Reply With Quote
Old 08-17-2008, 03:06 AM   #2
Send a message via Yahoo to jonmandude
If you check them every pad change and rebuild them when even the hint of leaks, could never need replacing.
jonmandude is offline   Reply With Quote
Old 08-17-2008, 07:25 AM   #3
buy a car from him?
internetautomar's Avatar
Send a message via AIM to internetautomar
most people replace them when the piston no longer turns back into the bore.
__________________
Maxima parts catalog< Website for sale
96 Green A/T gone
94 Pathfinder POS GONE! | 79 Camaro sold
98 I30t Silver on black A/T gone | 96 Granite Pearl (AKA Purple) A/T gone
92 grey VE A/T gone | 96 I30 Black gone
92 maroon VE A/T gone | 92 white VE M/T gone
92 grey VE A/T gone | 6/84 L24E last of the RWD Maxima gone
internetautomar is offline   Reply With Quote
Old 08-17-2008, 11:20 AM   #4
Replace when you disassemble it and find the bore so corroded and pitted that they can't be rebuilt! Change that fluid at least annually can avoid that PITA.
CMax03 is offline   Reply With Quote
Old 08-17-2008, 04:09 PM   #5
Josh's Avatar
Send a message via AIM to Josh Send a message via MSN to Josh
Quote:
When they stop working replace them. /thread
Josh is offline   Reply With Quote
Old 08-17-2008, 04:43 PM   #6
STFU n00b!
Mine have 255k miles on them...
__________________
04 G35 Sedan 6MT- The DD
96 240SX 5 speed- The track toy
93 Maxima SE 5 speed- retired 1-5-09
Check out the toys I make on my website!
Matt93SE is offline   Reply With Quote
Old 08-17-2008, 04:56 PM   #7
Wanna Go Muddin?
Greeny's Avatar
Quote:
Show off...
I have replaced both my rears with used units from my local j-yard about 70k ago. (now @ 335k)
__________________
3rd Gen parts--> http://forums.maxima.org/1st-3rd-gen...-part-out.html
Greeny is offline   Reply With Quote
Old 08-18-2008, 02:39 AM   #8
I got ya beat. I have 284K on mine. Of course I did a rebuild at 270K.
Old 08-18-2008, 01:23 PM   #9
STFU n00b!
mine are all original. all I've done is put pads on them every few years and keep driving. never even popped the seals off them.
I'm surprised I haven't had any problems with them, especially with all of the track use I've put on them.
another point for the "Italian Tune Up"!!
__________________
Old 08-18-2008, 01:30 PM   #10
STFU n00b!
__________________
Old 08-18-2008, 03:10 PM   #11
ColombianMax's Avatar
Send a message via AIM to ColombianMax
Hey if you see rust on your rotors, then you've got a problem with either your caliper being seized whether the piston or the guidepins, if so then you should remove the caliper and inspect it. If its leaking then thats another sign
__________________
SHIFT_I cant it's Automatic!!
1993 Maxima GXE Super White, Ebay FSTB, 97-99 SE Rims, KYB GR2s, BlehmCo Lower Tiebar, BlehmCo parallel link kit, RSTB, BlehmCo swaybar links,Rear Addco swaybar, z31 rear disc upgrade, Assurance TripleTreds.
1995 Maxima GXE-5 Dark Blue Pearl , 00-01 SE RIMs, I30 leather w/rear headrests, No rubber- all ES Poly in front end suspension, Pioneer InDash Navi, Kzoosho LED tails and FX35 HID retrofit
ColombianMax is offline   Reply With Quote
Old 08-18-2008, 04:18 PM   #12
Thanks guys
This was the reason I posted the thread. For some reason my rear rotors are rusty while my front ones look proper and smooth like polished metal. The rear ones look like the pads aren't even touching or barely touching.
I measured the wear limit on the rear pads, and they are 2mm greater than the min. so it shouldn't be the pads. I'll try all of the suggestions first.
Old 08-18-2008, 04:24 PM   #13
Thanks guys
Another way to tell if they work (which they dont if they have rust) is to jack up the rear and pull your handbrake, while the car is jacked attempt to turn the wheel by hand.
Since you measured the pads...do you know if either one is more worn than the other or are they both worn evenly?
__________________
Old 08-18-2008, 04:30 PM   #14
They were both worn evenly. I think the garage scammed a few years ago when they did "brake work" on it. By the looks of it, they didn't even touch the rears...the bleeder screws are completely seized into place rusted - and completely stripped when I tried to remove them with my flare crowfoot.
When I pull the handbrake, and then try rotating them (like when I'm torquing the lug nuts), the wheel doesn't move like the front ones.
The thing is, the handbrake is operated by a cable...while the foot brake is hydraulic....so I don't know if that test works.
Old 08-18-2008, 05:16 PM   #15
Yea but its the same piston that presses against the rotors whether it be hydralic or cable. who knows maybe you just gotta free up some stuck guidepins. Have you checked if the rotors are rusted only on one side?
__________________
Old 08-18-2008, 07:24 PM   #16
STFU n00b!
If the bleeder screws are rusted in place and the guide pins are rusted as well, just replace the caliper. you may be able to rebuild it, but it's not worth the time or effort- it'll just happen again soon once those pins start rusting up on you. just buy some new/reman calipers and move on with life...... and make sure the replacements have the torque arm with them. some calipers don't come with them.
__________________
Old 08-20-2008, 01:47 AM   #17
OK thanks I'm probably going to do that but this car is starting to feel like a black hole for money and I'm just doing OEM stuff & no performance stuff.
Is this year impossible to keep on the road without something breaking in 1 month of just city driving? I work for myself so I don't need to be at places on time, but I couldn't imagine how a regular working person could rely on it day to day. I still see ALOT of 3rd gens on the road EVERY DAY here in the city, but most are showing rust and alot have loud exhaust noise. They had a good stock of the 3rd Gens in the JY too. (I still think the 3rd Gen was the peak for the maxima model.)
I wish I could buy a souped up looking one like some of you have...but I couldn't fathom how much it costs to make them look that good.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
