6 cly to 4 cly
Old 08-03-2008, 05:47 PM
  #41
Nismo87SE's Avatar
I've done something similar to this with my se-r. One thing I found is that my car needs only 90-100wtq to accel from 40-65 in 7sec. Basically my engine is only making around 60-65whp at 65mph. Once I unplugged a cylinder my wideband went from stoich to 18-19.x AFR, which made my ecu start dumping gas. I unplugged my o2 output to ecu and this time in open loop the ecu didn't wig out. The car was down on power and accelerated a lot slower during city driving.
With some ecu programming it could be adapted for our cars, outside of dealing with a crappy idle I believe it would help. The question is how much gas would the DOD V6 need to maintain 60mph vs non DOD.
Nismo87SE is offline
Old 08-03-2008, 05:54 PM
  #42
burhan92SE's Avatar
good point...make sense
burhan92SE is offline
Old 08-03-2008, 06:22 PM
  #43
Gunther's Avatar
Originally Posted by GRNMAXDMON
i don't notice any difference in that crap??? it came with the engine that i bought from the junkyard back in '05. i took it out for a couple of days and put it back in but i don't notice any difference in saving gas with it.
yea just a joke... heh
Gunther is offline
  #44
tv4184's Avatar
I know of someone that did this because the engine ran pretty bad with all 6 cylinders firing at the time so he ran it with only 4. He said it was really slow but it ran smoother than when it did with 6 because of the issue he was dealing with. I'm not sure the details of the situation though.
tv4184 is offline
Old 08-03-2008, 06:34 PM
  #45
3g94MaxGXE's Avatar
Well if you've got a bad misfire then that might be true.
3g94MaxGXE is offline
Old 08-03-2008, 07:20 PM
  #46
300zmax's Avatar
if you want to make your car slower why dont you drive slower. you enegine will love you for not screwing with the way it was ment to work.
300zmax is offline
Old 08-03-2008, 07:24 PM
  #47
tv4184's Avatar
Yeah when mine wasn't hesitating and wasting gas like it is now. I got 405 miles on a tank of gas averaging 27 mpg. W00t.
tv4184 is offline
Old 08-03-2008, 08:40 PM
  #48
maxitech's Avatar
It's crap like this that has driven the older members away from this forum. If you want a 4-cyl car, buy a Civic...end of story.
maxitech is offline
Old 08-03-2008, 10:34 PM
  #49
I can has?
Pearl93VE's Avatar
If Wayne was ever around this would have been locked when it started...
Pearl93VE is offline
Old 08-04-2008, 05:44 AM
  #50
¯\(°_o)/¯
Greeny's Avatar
Originally Posted by redwood_usa
If I wanted to run the engine only on 4 cyl anyone know which pairs of injectors I could disconnect to maintain a smooth ride.
If you want a 4 cylinder engine, then buy one. Unplugging injectors on a 6 cylinder will not improve fuel mileage, it will unbalance the engine causing it to work harder to get up to speed.
Both my ve and vg have had injectors go down, during this time they both experienced terrible fuel mileage.
Greeny is offline
