Turbo
Turbo
Why do i always see 3rd Gen Maxima's with T4 and T5 turbo's? i want to rebuild and turbo my 93 GXE but was thinking why not go with a major HP gain and get a T88 or something. Also, where should i look for inexpensive parts to rebuild my engine?
Thanks.
Thanks.
well i don't think he was looking for cheap crap.... rather just the best price on good stuff. cuz you know a lot of places will charge you way more than the parts are worth. like the JY i don't go to anymore... wanted $75 for a used window regulator. or $550 for a 5spd tranny. so i went and bought a parts car for $200 less (and for being a parts car, it ran good enough that i'm taking the motor for my car too). so yea... i guess what he's looking for is best bang for the buck
I got all my stuff from my favorite place, Ebay. I got the turbo for 450 (turbonetics 60-1) and the intercooler,piping, couplers, clamps, and downpipe flange were the ebay kit. I am using a n2o line for my oil feed with a restrictor from atp. It can be done fairly cheap but you dont want to cheap out on your tune. You can have a 10000 car and a bad tune and you will end up with a 10000 parts car.
Hahaha I was wondering why nobody mentioned turbo lag. Either way unless you've got a fully built motor I don't see what a big turbo would do for you cause you will end up wit engine problems in no time.
and then there's the issue of massive HP in a FWD car will just lift the front and spin tires. that's one time when a high-end biased engine is good tho... because once you're moving you can turn on the power, but just taking off through 1st and the shift into 2nd... it simply can't take that much power. maybe an a/t is a different story... but the VG AT won't take but about 5 miles of t88 abuse before throwing in the towel.
Yep I was with you there a long time ago or I would be rolling in a turbo Maxima by now. Funny thing is we're now talking about traction issues in 2 threads.
when it comes too turbo bigger is not always better check out the vg30det somehow they added a smaller t25 to replace the t3 which somehow gave the engine the exact same hp but 5ftlbs more torque and has less turbo lag which is good unless your trying to break a land speed record
Well the reason the T25 can produce the same boost is the fact that factory turbos are not usually set up to run at their limits. So you get a 5-7lb boost factory turbo that just as easily could put out lets say 10-15lbs. You can replace it with a smaller turbo, run it closer to it's limits and make the same horsepower, get less lag but the bad part is the factory turbo would be capable of a bit more if you desired it.
no thread in particular. it's just a few concepts that can fairly easily be reasoned through when considering how a car will behave in different circumstances. like the fact that the faster you are going, the more tq you can put to the wheels without spinning them. or the fact that the car's nose lifts during acceleration and that's bad on FWD. a/t will smooth out the launching and shifting so you won't chirp as hard (b/c you have a tq converter), but the vg a/t has enough trouble as it is...
Im going to run 6 turbos. One for each cylinder. That way i have instant boost and plenty of power. Im put them right where my seat goes so i can make sure they are working right.
yea.. i know what you mean there. and i know JUST enough about sequential TT to know that i'm never going to mess with it unless i have a spare car and $10k of "oops i f**ked up again!" surplus money.
or this one? http://www.turbo-kits.com/images/sts...in_turbo_3.jpg
ever seen this one? http://www.britishv8.org/Triumph/EdOlson/EdOlson-A.jpg
I was talking about a ghetto made, barely holding on turbo mounted where the passenger seat used to be, in a non-convertable car. Exhaust was leaking INSIDE the cabin! I've been trying to find pictures or the thread I saw on it for the last 10 minutes, no luck so far...
I don't see anything wrong with either of those
I think this is what you think of http://forums.nicoclub.com/zerothread/200437
b) VG AUTO Twinturbo?
c) must be hot in there
d) so... he ruined his cabin to keep the turbos out of the engine bay... but STILL had to relocate his battery. smooth.
e) i thought the intercooler went post-turbo... his is preturbo
f) if the turbo blew up, i'd rather have it under the hood where i WON'T get shrapnel in my eye, arm, etc... and not be deafened by the exhaust blasting in my with no muffling, etc etc.
FOUND IT!!! Best part is, It's on a turd gen!!!
Complete thread is here with more pictures: http://www.thewolfweb.com/message_to...=413656&page=2
Yeah, same thing.
i like this one the best isn't just as possible to stick all that piping in the trunk instead of passenger seat that would eliminate most of those problems with..... ya know death when it blows up... but the trunk is fine just as safe as the engine bay with more than enough room plus you could really make them visible this way
[IMG]http://www.turbo-kits.com/images/sts_mustang_gt_twin_turbo_3.jpg[IMG]
not to contradict myself, here, but some people have seen pretty decent results from it. I don't know of anyone in the 3rd gen forum, but I think there are in the 4th gen and 5th gen. may also want to check the turbo/supercharge forum.
Is there anyway a T4 or T5 would work with the new HKS special edition universal BOV with my VG30E?
