Fuel pump relay
Fuel pump relay
Where the heck is it? lol...all of my fuse covers are worn so there are no writing on them. My fuel pump isn't kicking in so i want to check to see if it is the relay before i drop the tank to see if i am getting current back there or my pump is finish. thanks s
Fuel pump relays (yes there are two) are in the trunk. Green one is pump relay, orange one is emergency fuel cut off.
Also there is a relay under the hood labelled "engine cont" that does control the ECCS and will effect the fuel pump.
Image of fuel pump relay in trunk of 1990 Maxima
Here is image of the location in trunk: behind lower trim panel between left tail light and trunk latch.
You need to remove the plastic trim and pull down the trim panel to access the relays. (see image)
jmlee44
10-02-2022 02:13 PM
06-06-2017 02:01 PM
