Hose Questions: Radiator & PCV
a) Can these hoses be replaced with generic that I can bend myself? I notice they look almost custom made, unless those bends and elbows just form over time.
b) Is it safe to use generic Vacuum hose for the PCV hoses? The existing PCV hoses feel extremely hard - almost plastic like PVC material, with custom elbows in it.
c) Inside the front PCV hose, there is a strange brush type thing stuck in there. Wire with the bristles around it. Did a mechanic leave that (hose cleaner?) in there by accident, or is this designed to block stuff - therefore transfer it to the new hose?
Leave it or take it out, dunno.
All rubber under hood must stand oil, but why?. (Brk fluid is another matter)
I had this hose broken because it was so hard (aged dried out I think) and when I replaced PCV valve I broke that hose and all the local autoparts said that was a dealer item, so I guess he has the same problem trying to make a hose fit in there, however I went to Junkyard and bought this hose because I wasn't sure about generic hoses.
keeps oil soot from shooting into the air stream. or so i was told
The brush was in the hose from that front red rocker cover...I think called the LH Rocker Cover...is that the place for yours? But I don't know what you mean by 'both valve covers'....I only found 1.
I don't know! sorry I can't be more helpful, like I said I was at AutoZone and ask for the replacement of this hose and they show me a similar one just longer and they told me to cut it and bent it, but I was trying at the store to bend it like the original and I was having a hard time to make it reach the same position as the original, so I decide not to buy it, however maybe a straight hose could be easier. I'm also gonna need an IACV hose, mine is cracked but again that will be hard to find.
BTW, just to save yourself the trouble, don't try to substitue brake booster hose with heater hose (like how I tried). It comes to be that the booster hose is purposely stiffened to avoid collapsing of the hose-walls. good thing I didn't install.
The only hose I couldn't change was the hose running from the rear valve cover to the PCV. That one, you might need direct from the Dealer.
Did you replace the heater hoses on the firewall? Also, the PCV hoses, did you use standard WINDSHIELD WASHER/VACUUM hose?
When I replace my rad, I want to replace the old A/T Oil Cooler Hoses (2). Is tranny oil going to leak out...hence I better have some handy to compensate. Also, is ALL of it going to leak out?
Yes, you are talking about the BLOW BY TUBE--->RH ROCKER COVER. I only see 1 x 90 degree bend in it, but the existing hose is stiff as hell - i don't know if it's age though. Also, what if I just make the hose longer and do a gradual bend sticking out and not use the plastic hose clamps that hold them in place?
Well, it's not so much the 90deg bend. It was the fact that I couldn't find hose with large enough diameter to fit onto the rear rocker cover hose-lip (for lack of better terminology). The hose-lip on the rear rocker cover is larger diameter than that of the front rocker cover.
yup, i went to any Kragen/Shucks/Checker or any autostore and asked for small vacuum hose. i brought in the old vacuum hose to show them what I was looking for. You should be able to find it from Hardware stores too. Quick answer is, as long as it fits and won't kink (if it must bend) then it's fine.
sorry, this is on my To-Do list just like you. I'd assume some AT fluid will come out. How much? I'm not sure, but I guess have some sort of rubber stopper or something to plug it up if it does? I wouldn't think too much would leak out... but always be prepared is what I say.
quickly plugging either end will be a good solution to the leak problem. doesn't matter which side. the source will be from both of the hoses iirc. i did this a year ago for my aftermarket trans cooler, and when i removed my a/t for good, i didn't pay attention
The tranny oil dipstick tube has a small hose coming off it - is this vacuum or some air purge tube? Also, on top of the tranny (looking from above towards the Purge Tank with Air Flow assembly removed) there is this over flow looking hose shaped as a J at the end of it. Do you know what that is? Regular Vacuum hose is OK for that too?
Miss sing PCV thread?
Maybe I cant, but then I cant find - pls help me again - where is this thread , 19 May?
Hose Questions: Radiator & PCV 1993-VG30E-GXE
http://forums.maxima.org/showthread....&highlight=pcv
FYI: Here is related pic from oil fume breather hose. When replacing, dont forget.
Unclejunebug
04-02-2016 05:42 AM
HerpDerp1919
09-29-2015 02:02 PM
