3rd Generation Maxima (1989-1994)Learn more about the 3rd Generation Maxima here.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
I bought a 3rd gen off a member here that needed more work than we initially thought but for a little under 2k it's now running nicely and inspected. However, last night I drove it for the first time at night and the headlamps are just horrible. Pretty much 2 hotspots on the road and that's it. They look to be some aftermarket ebay black housing headlamps. Anybody have some ideas for better headlights? Should I just buy some OEM's? I like the look of the ones I have, I just can't drive with them. HID retrofit is pretty much out of the question because I don't have the time or skill and patience.
Thanks!
__________________
99SE 5spd Black | OEM G35 Coupe 18's 235/40 | Stillen Lip Kit | DTM Red/Clears | DC Clears | S-Techs/AGX's | TopSpeed Y-Pipe | Debadged w/2001 SE Max Emblem and painted keyhole | Python 2-way Alarm | K&N Filter | 35% Tint | 6000k Bohmen HID | 5th Gen Clutch
please supply a pic of the "aftermarket ebay" lights. There is only the Euro style lights that I have seen. Otherwise, they are probably E36 BMW lights.
If you have stock housings, you can do a 9007 bulb swap. It helps out quite a bit for a cheap, easy upgrage. There is a how to in the stickies.
pretty sure they are the euro style then from ebay. The light output is pretty much unbearable. It's like driving with fog lights on. How hard are the e36's to install?
This is what they look like
__________________
96 Green A/T gone
94 Pathfinder POS GONE! | 79 Camaro sold
98 I30t Silver on black A/T gone | 96 Granite Pearl (AKA Purple) A/T gone
92 grey VE A/T gone | 96 I30 Black gone
92 maroon VE A/T gone | 92 white VE M/T gone
92 grey VE A/T gone | 6/84 L24E last of the RWD Maxima gone
There are some E36's being sold in the 1st-3rd gen classifieds right now with a Wade flush fit installed and UK corners. Output would be great, if you decide to just go OEM, definitely do the 9007 upgrade, it's simply switching two wires, buying the bulbs, and shaving a small ridge out of the headlight bulb housing.
retrofits aren't as hard as they look. you have a great starting point with those euro clear glass housings.
yeah the euros are the way to go for a stock-fitting retro. I'm stuffing some J30 projectors into euros sometime in the next year. but it's always a good idea to have some spare stock housings that you can afford to royally screw up just in case it doesn't go right. Then when you finally get it right, just try and replicate your success over to your nice Euros and you've got a nice set of flush-fitting headlights.
__________________ PieceOut.FallToPeacesNew to the forum? CLICK HERE!!!! 1985 Nissan 300zx 2-seater: VG30E | 5spd Swap | Bilstein | 5-lug conversion | Polyurethane everything | Resurrection-in-progress! 2004 Honda Civic EX Coupe: 1.7L VTEC | 5spd | CAI soon | LED tails and Projectors soon | ES Poly Motormounts soon | 'bad weather' car/backup for teh Z 1990 Nissan Maxima GXE: VG30E | VLSD-5 swap | Exedy | NWP | a33b(F)/z31(R) BBK | ES poly | SE susp swap | 2k2SE 17s | retired Aug 28th '09 2005 Nissan Maxima SE: VQ35DE | 6spd | Carolina Panthers front lisence plate | Brother's car, not mine | <-- Therefore still 100% stock
Quote:
Originally Posted by JasonOksa
Horsepower, torque and speed are all known by The State of California to cause cancer, birth defects, and reproductive disorders.
Quote:
Originally Posted by bigleman
how much would it cost to resleeve?
how does an aluminum motor form rust on the cylinder walls???
DO NOT PM ME ABOUT PROBLEMS WITH YOUR CAR UNLESS I TELL YOU TO. THAT'S WHAT THE FORUM IS FOR
I may buy some stockers off ebay and then some projectors and play around with the euros and projectors. What are the best projectors for these housings? The J30s?
__________________
Im thinking about gettin a 8000k H.I.D. kit question is where would i mount the Ballasts? and would it be a good idea to put them inside the stock housing and still get a good light output? and is it possible to get inside of my lights cleaned or is there a way of cleaing them? I thought about CLR not sure if that works and dont wanna waste my time i would just do the 9007 upgrade but dont really want to.
__________________
Numbers or strength doesn’t mean you will win the war but whichever army goes into battle stronger in soul their enemies can’t withstand them...think about it..GetIt?GotIt? Go....-Infam0usMAX-
stop. it's illegal. and dangerous to other drivers.
Quote:
question is where would i mount the Ballasts and would it be a goodidea to put them inside the stock housing and still get a good light output?
in another car, and not if you respect other drivers.
you could try taking the headlights out, and sloshing some warm, soapy water around in there
