Go Back   Maxima Forums > Maxima Discussions > 3rd Generation Maxima (1989-1994)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 04-30-2008, 11:18 PM   #41
Quote:
Originally Posted by internetautomar View Post
have you had both "spread out on a table" as you put it?...
No. I am asking you. About THE parts when compared.
The boxes have design limits for power delivery. Quest hp (if the tranny was first for it) means smtg in this game.
Yall ppl, slippery Question:
The tranny oil temperature: Oil has to be warm to work properly. Cold tranny will blow if abused:
1. What is the optimal, -DESIGNED- operation temperature, measured where?
2. Why is the gearlock limited to warmed oil +60C - +160F?
3. Why stock "tranny cooler "works as a heater?
Wiking is offline   Reply With Quote
Old 05-01-2008, 12:35 AM   #42
Call me Wookiee Goldberg
CapedCadaver's Avatar
when the VE and it's associated bits were being designed nissan had the money. when the car was launched they were having financial troubles.
The transmission was used in all V6 FWD application from 95-01ish. The VG got it when it was being used in the Quest.
o ok, so the Rblahblah4A/V was not specifically for the VE. gotcha.
__________________
PieceOut.FallToPeaces New to the forum? CLICK HERE!!!!
1985 Nissan 300zx 2-seater: VG30E | 5spd Swap | Bilstein | 5-lug conversion | Polyurethane everything | Resurrection-in-progress!
2004 Honda Civic EX Coupe: 1.7L VTEC | 5spd | CAI soon | LED tails and Projectors soon | ES Poly Motormounts soon | 'bad weather' car/backup for teh Z
1990 Nissan Maxima GXE: VG30E | VLSD-5 swap | Exedy | NWP | a33b(F)/z31(R) BBK | ES poly | SE susp swap | 2k2SE 17s | retired Aug 28th '09
2005 Nissan Maxima SE: VQ35DE | 6spd | Carolina Panthers front lisence plate | Brother's car, not mine | <-- Therefore still 100% stock
Quote:
Originally Posted by JasonOksa View Post
Horsepower, torque and speed are all known by The State of California to cause cancer, birth defects, and reproductive disorders.
Quote:
Originally Posted by bigleman View Post
how much would it cost to resleeve?
how does an aluminum motor form rust on the cylinder walls???
DO NOT PM ME ABOUT PROBLEMS WITH YOUR CAR UNLESS I TELL YOU TO. THAT'S WHAT THE FORUM IS FOR
CapedCadaver is offline   Reply With Quote
Old 05-01-2008, 06:05 AM   #43
Googling for the optimal tranny oil temp gives few results. But look at how Toyota has responded to its dysmally xploding lexus trannys: thermostat ctrl. Just as I said... stupid cooler is no good, extra dumb cooler is even worse.
Nobody gives optimal temp ranges (why?), but generally 170F seems to be the minimum A/T oil operating temp...
Heres my days surfing result:
FYI, Excerpts From Lexus Forum:
- JAB 09-14-06, 05:37 PM "I am original owner. Tranny failed at about 116K."
- Salimshah 09-14-06, 06:14 PM "Been on this forum for years and there has been a fair number of posts on transmission failure [some say on AWD some say FWD only].
I am glad we are talking about transmission and not a medicine or a medical procedure. There are too many horror stories out on the net, that an unbiased person would not follow through with any treatment."
- TunedRX300 09-14-06, 06:44 PM "First, Lexus will never release failure rate on RX300's transmission. Lexus will commit brand suicide if it does......"
Check out for more, "Transmission failure 1999 Rx300 AWD poll": http://www.clublexus.com/forums/arch.../t-238236.html
New Toyota Tundra --->thermostat tranny oil temp ctrl:
http://www.motor.com/magazine/pdfs/012007_08.pdf
Temperature control of the gear oil
http://www.btt-thermostate.de/englis...mper_getr.html
The gear oil in automatic transmissions has an optimal working temperature
range, within which a high level of comfort is achieved simultaneously with
a very long service life. Compared with the temperature development of the
coolant, the adaptation while driving is delayed and the gear oil thus only
attains the optimal temperature on longer rides. This delay results in
considerably increased fuel consumption as a result of the related friction
losses. Hot coolant causes an active heating of the gear oil which then
counteracts this delay and ensures that greater comfort and efficient energy
conversion are achieved more quickly. In addition to this, with the use of
a thermostat and the appropriate circuit, it is possible to not only actively
heat up, but also to cool or regulate the temperature of the gear oil.
Products,
Engine/Transmission Oil Thermostatic Control:
http://www.cpperformance.com/product...thermostat.htm
Xtreme Remote Engine & Transmission Oil Thermostat 180 Degree
Traditionally engine or transmission oil is continuously run through a cooler or heat exchanger to prevent the engine or transmission oil from overheating Obviously this system works well but it does not compensate for the variables involved such as the water temperature your boating in, the size and efficiency of your coolers or how long it takes you to warm up your engine to bring it to proper operating temperature.
By installing a remote oil thermostat the oil will bypass the cooler until it reaches a pre-determined temperature at which point it will internally open and begin flowing the oil thru the cooler to maintain a constant oil operating temperature The Hardin Marine Xtreme oil thermostat can either be remotely mounted with 2 stand-off bushings or it can be connected directly to the oil cooler or remote filter head with a custom Hardin Marine coupler fitting. ....226$
Old 05-01-2008, 07:07 AM   #44
buy a car from him?
internetautomar's Avatar
Send a message via AIM to internetautomar
I agree with you Walt, a thermostat control for all the fluids would be a good idea. the trans cooler in the radiator is used because both the trans and the engine work best in the same temperature range (approx 200*F). the trans will do a bit better if the temps stay lower, but 200 is still safe. Cold trans fluid is a bad thing as well, it doesn't flow well. I wonder how many people have changed their trans fluid only to have issues crop up because of it?
__________________
Maxima parts catalog< Website for sale
96 Green A/T gone
94 Pathfinder POS GONE! | 79 Camaro sold
98 I30t Silver on black A/T gone | 96 Granite Pearl (AKA Purple) A/T gone
92 grey VE A/T gone | 96 I30 Black gone
92 maroon VE A/T gone | 92 white VE M/T gone
92 grey VE A/T gone | 6/84 L24E last of the RWD Maxima gone
internetautomar is offline   Reply With Quote
Old 05-01-2008, 01:20 PM   #45
Send a message via AIM to Mysticcal
So, the new transmission is going in today, I wanted to go synthetic since some people advertised smoother shifts, but I couldn't justify the extra 50$ buy in price since the max capacity is 10 1/8 qrts, so I'm just going regular, I'm sure it won't hinder it in the long run since we've been using non-synthetic for decades.
Mysticcal is offline   Reply With Quote
Old 05-01-2008, 01:39 PM   #46
Quote:
well, for a brand-new transmission... the power is yours. you can change the fluid every 10k and put on some sort of thermostatic cooler set at 180 or whatever, and the sucker will last a long time. even if it lasts just 150k miles... do you honestly forsee yourself getting that many more miles out of the car? It's nice to think we could, but odds are against ANY of us getting even 50k more out of our cars. Just due to family/life circumstances, gas prices, possibility of catastrophic failure or crashes, etc. There's so many reasons that could cause us to not drive a certain car anymore, so I'd say that as long asyou take care of that new transmission, it'll effectively last you forever. Not literally, but effectively.
__________________
Old 05-01-2008, 04:16 PM   #47
buy a car from him?
the factory fill was/is a low ash version of Dexron III. the regular Dexron III has a higher than recommended level of ash in it. Synthetic should be a no ash formula.
you should be able to pick up synthetic for about double the price of regular trans fluid. so $5 vs $2.5 a quart.
__________________
96 Green A/T gone
Old 05-01-2008, 06:13 PM   #48
6.99 vrs 2.19 a qt... poor college student
Old 05-01-2008, 08:20 PM   #49
buy a car from him?
poor college student wants to shorten trans life.
Penny wise Pound Foolish
__________________
96 Green A/T gone
Old 05-01-2008, 10:54 PM   #50
by shorten you mean 20k miles... max, plus, 100k miles, least 10+yrs for me. at least.
Old 05-02-2008, 12:46 AM   #51
When one has to choose, any extra 50$ into a DD is 'wasted'. (There is also a 'collision waitin' -factor) ... But oh brand new tranny (?) ... maybe I would try to call my American Aunt.
Old 05-02-2008, 02:47 PM   #52
1993-VG30E-GXE's Avatar
Quote:
Originally Posted by Greeny View Post
Then enter the ve auto, which most can go over 200k without a fluid change and still be good to go, yeah, try to get 200k out of a vg automatic without slip-slip weeeee!!, neutral in all gears!!
My VG tranny has barely been serviced, and it works fine. Still the original going strong at 307,254KM....but I will keep what you said in mind in case it goes BOOM soon.
I just changed the fluid so only time will tell. (PS. Never Had Synthetic Refill)
1993-VG30E-GXE is offline   Reply With Quote
Old 05-02-2008, 03:51 PM   #53
mine died at about this kilometerage (translates to mid 160k miles) so still be on the lookout
__________________
Old 05-02-2008, 04:47 PM   #54
Send a message via Yahoo to jonmandude
I wish I only paid $2.50/quart. I use Amsoil synthetic @ $10/quart.
jonmandude is offline   Reply With Quote
Old 05-02-2008, 05:43 PM   #55
Quote:
What options do I have once it blows? Do I have to completely REPLACE the tranny, or can it be re-built for cheaper?
I like this model of Maxima more than the next generation, although the latest generation looks good and big like the 3rd Gen, but too expensive.
Old 05-02-2008, 06:44 PM   #56
:squint:
BenStoked's Avatar
Send a message via AIM to BenStoked
if you look on ebay, you will see a few autos for about $600. rebuild, about $800.
these are US prices, AND guess-timates, but you get the idea.
BenStoked is offline   Reply With Quote
Old 05-02-2008, 07:04 PM   #57
well the thing is that a jy a/t for a VG is not likely to work very well.... best thing you can do is to either find one that's under 120k miles or look for an already-remanufactured one somewhere. It's a tough call what to do with a dead VG auto. The decision was easy for me. Although my tranny gave NO indication of failure, i had just bought a 5spd parts car... 6 days before my a/t unexpectedly died. I was gonna do the swap anyways... the a/t failing just made me do it sooner. Which meant i was financially unprepared. Which means that I just got inside from prepping the car for clutch replacement tomorrow. And a few other things.
__________________
Old 05-03-2008, 08:37 PM   #58
buy a car from him?
Quote:
you bought the overpriced amsoil crapola.
it's just the low ash content that is needed for extended life.
__________________
96 Green A/T gone
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
