03-28-2008, 05:37 PM
Injectors, very strange problem
-okay, as some of you may or may not know, my #1 injector is 'dead'. anyway, two weeks ago, i did the pull nd clean technique with that injector terminal. yes, it was corroded. i had cleaned it, but when i went to start it up, NO CHANGE. but throughout this week, my maxima runs as it did when i bought it back in november.
Whats Up With That??
03-29-2008, 12:29 AM
Quote:
Originally Posted by ProphetVG30E
...as it did when i bought it back in november.
April is approaching?
Cleanup doesnt mean contacts are healthy. If your problem was bad contact, then now u have it ... until May ? ... (cut/solder the wires solid or get new pins (=injector), connectors)
03-29-2008, 07:29 AM
what do the months april and may have to do with anything??? and plus, its not EVERYDAY. its mainly 6 times out of 10 during the week. im changing the injectors on monday anyway, so i should be able to see a difference
03-29-2008, 08:48 AM
April is better than mentioned November - which may or may not have to do nothin with anything???
Focus on the intermittent contact issue - its dancing in tune with microsoft stocks and the calendar. Soldering the wires solid - or getting new contacts - will clear that vibration controlled contact problem.
03-29-2008, 09:05 AM
Jesus was a Zombie.
did you clean the connector, or just the pins on the injector?
__________________
Quote:
Originally Posted by my coworker
It's a button, man. It BEGS to be pushed.
03-29-2008, 09:17 AM
the whole connector, and the injector terminal itself, it was sea green when i pulled it
03-29-2008, 09:23 AM
Jesus was a Zombie.
I'm sorry, but i do not understand the question or topic of this tread...
__________________
03-29-2008, 06:14 PM
im asking why it does this.
at times, it rides rough, and other times, it runs as smooth as butter.
03-29-2008, 06:53 PM
mod or sell?
Points: 29,227, Level: 99 |
it's one of the more unusual symptoms of injector failure.
look at a light bulb. see the filament inside of it? when a bulb "dies" that filament will typically break at some point. on occasion that break will touch together again and weld/solder itself closed. that fix usually only lasts a little while, but it does happen. the same thing is happening to your injector.
__________________
96 Gold I30 here
2000 Gold GXE gone | 95 White GLE modded gone |95 GLE white A/T gone
96 Green A/T gone | 94 Pathfinder POS GONE! | 79 Camaro sold
98 I30t Silver on black A/T gone | 96 Granite Pearl (AKA Purple) A/T gone | 92 grey VE A/T gone
96 I30 Black gone | 92 maroon VE A/T gone | 92 white VE M/T gone
92 grey VE A/T gone | 6/84 L24E last of the RWD Maxima gone
03-29-2008, 07:38 PM
uhhhhh, let me try to put this in an easier term, and see if thats what you mean.......
the injector dies, and after a while, it slowly "regains life???????"
03-29-2008, 07:53 PM
Jesus was a Zombie.
sometimes the problem can be solved thermally?
when the engine gets hot , it heats up the injector and the broken coil regains use when it expands
__________________
03-29-2008, 10:16 PM
Yep had this problem with one of my injectors, when the engine was running rough, it measured about 100ohms, after it warmed up, sometimes it would smooth out and run fine, if I measured the injector in this state, it measured about 35ohms. The weird part is the injector was either working ok or not at all, almost like the resistance of the injector reached a threshold where the ECU recognised it as ok and started driving it again, even though it probably wasn't performing to spec. Both measurements are well out of correct range. I replaced the injector and haven't had a problem since.
03-30-2008, 02:14 AM
...it was sea green when i pulled it
This analysis is like reading tea leaves. If injector is "corroded sea green", then it really is green corro-dead sea. Take out, throw dead six magpies.
03-30-2008, 08:35 AM
Call me Wookiee Goldberg
Points: 16,291, Level: 81 |
the coil breaks. then as the car moves and everything vibrates a little bit, the two ends of the coil flap around inside the injector casing and will sometimes touch, spark, and resolder theirselves to a temporary fix.
__________________
PieceOut.FallToPeaces New to the forum? CLICK HERE!!!!
1986 Nissan 300zx: VG30E | NA2T + FMIC | 5spd swap w/ 30A | R200 CLSD | Bilstein | MSA 26mm sways | 88/89T susp/brakes + Poly | 17x9 Cobra-R's w/ 255(f)/275(r)-40-17
1987 Oldsmobile Cutlass Supreme Sedan: V6 3.8 2bbl | 3spd Auto | 85-87 IROC-Z 16x8 | LT1 + T56 and suspension mods coming soon...
1990 Nissan Maxima GXE: VG30E | VLSD 5spd Swap | A33b F BBK | Z31 R BBK | Eibach | Tokico | Addco RSB | ASP | Warpspeed | G35 Sedan 17x7
1997 Audi A4: V6 2.8 | 5spd | Quattro AWD | Santorin Blue Pearl
1998 Nissan Pathfinder SE: VG33E | 5spd | 4WD | Towing Package
2001 BMW 530i: M54B30 I6 | 5spd | Sport package
(I think I need more cars)
Quote:
Originally Posted by MinervaMaxxxima
I have the strangest boner right now.....
Quote:
Originally Posted by litch
I find it to be thick and delightful
03-30-2008, 10:35 AM
im gonna be changing the injectors/fuel rail tomorrow anyway, so it really doesnt matter anymore to me, i was just wondering why.
since im doin that, i was told i needed a plenum gasket and reccomended new o-rings. i remember seeing a write up about it somewhere, but i cant find it anywhere.
is there anything missing????
03-30-2008, 01:21 PM
To be safe, get the upper and lower plenum gaskets, and per Wayne's suggestion which should be quite helpful, before installing the new o rings, rub vasoline or petroleum jelly on them. And dont pinch or damage them.
__________________
03 SE 6-SPD
98 SE 5-SPD
97 SE 5-SPD
74 MG MGB 4-SPD-in progress
03-30-2008, 01:30 PM
Quote:
get injector o-rings from dealership, they are cheap and better quality than any autoparts store.
Like i said in someone elses post about the o-rings, I did my front 3 injectors, went through 9 autoparts store o-rings in an hour, then got 3 from dealership and they didn't get pinched....yes I lubed the **** out of the autoparts o-rings and they still tore every time
03-30-2008, 05:07 PM
just to make sure we are deffinitely clear, i have the VG30E, and i've heard of only ONE plenum gasket needed. a local mechanic i've known for a while has worked on problems like these on maxima's like mine, and he clearly stated i needed only 1 plenum gasket.
03-30-2008, 05:18 PM
¯\(°_o)/¯
Points: 37,034, Level: 100 |
Yeah dude, we all know which engine you have..you have 2 intake gaskets, an upper, and a lower. you must remove both to access the injectors.
03-30-2008, 05:50 PM
just double checkin before i mess up tomrrow. thanks greeny.
MaximaOrg
Nissan Maxima
Paid Advertisement
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
