Go Back   Maxima Forums > Maxima Discussions > 3rd Generation Maxima (1989-1994)
Sign in using an external account
Register Forgot Password?
Register Photos Classifieds FAQ Timeslips Members Parts Guide Search Today's Posts Mark Forums Read ExperienceVendorsUsed CarsGarage TSB & Recalls
Search
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 03-22-2008, 12:14 PM   #1
NO PPM Emmission failed 3rd time
Here's what happen 2 weeks ago my HC ppm is high nothing else so I went to jiffylube and did an oil change with synthetic, fuel injector (in engine and in gas) and I drive the car for a week as its been a while not driving it but I always warm it up in the morning. A week later I went to take the test again and HC ppm PASS but the NO ppm failed the guy (emmission test guy in the gas station) told me that he is 100%sure its the cath converter so I called around and the nissan dealer want $1000 just for cat, called 2nd shop $460 inc. labor then my cousin knows a guy (co owner as well) that expertise is exhause like maidas shop since he's my cousins friend he just chage me $250 parts and labor I said ok then he ordered it. Today got it installed and went back for another test. The same guy did something in the hood and run it, to my surprise it failed again he said he still think its cat nothing else he told me go back monday and he will fix it for $200 and pass. I said i'll call him and went back home as soon as im home check the hood and the wires for the plug valve is loose I think its #4 plug. Do you guys think it as anything to do from my failed emmission, do you guys think he took it out just to make $200 bucks for me.
Please help me as I am desperate!
PS. I forgot to mention that I always give the guy tip whenever I go ther for the test.
-Brian
bgssamson is offline   Reply With Quote
Old 03-22-2008, 01:15 PM   #2
505max94se's Avatar
Points: 9,796, Level: 66
Points: 9,796, Level: 66 Points: 9,796, Level: 66 Points: 9,796, Level: 66
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
$1000 for a cat....
__________________
Nitrous PB 12.20@110mph 1.73 60'
N/A PB 14.12@93.7mph 1.93 60'
DD.. A/C, PS, full interior.... R.I.P
'90 300ZX TT 490whp-pump gas
PB 11.9@118mph spinning in 2nd on dr's
505max94se is offline   Reply With Quote
Old 03-22-2008, 01:18 PM   #3
Points: 9,721, Level: 66
Points: 9,721, Level: 66 Points: 9,721, Level: 66 Points: 9,721, Level: 66
Activity: 0.5%
Activity: 0.5% Activity: 0.5% Activity: 0.5%
Do you know which engine you have?
If not, whats the trim and year of your car?
__________________
mikekantor is offline   Reply With Quote
Old 03-22-2008, 01:36 PM   #4
Its 1993 GXE (VG30E SOHC if im not mistaken). Yeh i though the parts guy was iether kidding me, or comes the whole pipe, cat, censors and etc.. or I just heard him wrong but I ask him again he said that's right $1000 plus tax for just CAT. that's why I shop around and the 2nd shop told me $460 everything he even mention that if you go get the nissan part it will cost you $1000.
Old 03-22-2008, 02:37 PM   #5
Jesus was a Zombie.
BenStoked's Avatar
Points: 7,376, Level: 57
Points: 7,376, Level: 57 Points: 7,376, Level: 57 Points: 7,376, Level: 57
Activity: 0%
oem is always way more expensive. courtesy has the best oem prices, for a dealer, but look at this ...
if the plug wire was disconnected, it could have caused the failure. however, since im not familiar with emmissions testing, why was he doing anything under the hood?
__________________
Quote:
Originally Posted by my coworker
It's a button, man. It BEGS to be pushed.
BenStoked is offline   Reply With Quote
Old 03-22-2008, 05:24 PM   #6
No idea what he's doing, but I saw him touch those wires that's why when i got home I check it and it was loose (very loose). Does it has any connection with the NO ppm failure? that thing that tick me is he said that maybe they (the one that put my cat) did put a cheap and not good cat and he then said that he can fix it for $200 just "DOING THIS AND THAT" (his exact words). I think if its bad cat he can't do anything about it unless he install another one right? he keep insisting bad cav (think he mentioned it 7 -8 times).
Old 03-22-2008, 05:32 PM   #7
Points: 6,161, Level: 51
Points: 6,161, Level: 51 Points: 6,161, Level: 51 Points: 6,161, Level: 51
Activity: 0%
$1000 for just the cat. Warpspeed sells performance cats for $100 IIRC. Not cool wasting all this money on passing emmissions. The plug wire could have made you fail. Im not sure if the mechanic even has to go under your hood for an emmissions test. Just stick a probe in the exhaust and run the car on the machine. Since I personally know someone in a shop I always pass inspection/emmissions and he has never opened the hood to do anything for it.
__________________
2009 370z (AT7): Gen3 | HKS Hi Power | Z120BT | Animated Foglight | 590.2x
1999 Maxima SE (MT5): Nada (so far)
Jmahad01 is offline   Reply With Quote
Old 03-22-2008, 05:32 PM   #8
Jesus was a Zombie.
BenStoked's Avatar
Activity: 0%
how much does it cost for inspection? you may consider finding another place to check emmissions.
did he get under the hood the first couple of times you went?
__________________
Old 03-22-2008, 05:37 PM   #9
I'm going to other emmission shop on monday just to try if its that the real cause even if I have to pay for another $28 for emmision test. If I pass I will go back to that place and ask for manager.
Old 03-22-2008, 05:39 PM   #10
Jesus was a Zombie.
BenStoked's Avatar
Activity: 0%
__________________
Old 03-22-2008, 05:55 PM   #11
I'm still eager to know if that plug wire will cause it to fail NO ppm. Does anyone knows?
Old 03-22-2008, 06:18 PM   #12
Baby's on the Half Tip!
hoyshnin's Avatar
Points: 7,375, Level: 57
Points: 7,375, Level: 57 Points: 7,375, Level: 57 Points: 7,375, Level: 57
Activity: 0%
Send a message via AIM to hoyshnin Send a message via MSN to hoyshnin Send a message via Yahoo to hoyshnin
what state are you in? here in california they have smog test places (emissions=same thing), and then smog test ONLY places. the smog test only places cannot work on cars, so they tend to be more honest. i'd recommned trying to find somewhere like that. oh, and watch them carefully, i always do
hoyshnin is offline   Reply With Quote
Old 03-22-2008, 06:40 PM   #13
mod or sell?
internetautomar's Avatar
Points: 29,227, Level: 99
Points: 29,227, Level: 99 Points: 29,227, Level: 99 Points: 29,227, Level: 99
Activity: 0%
internetauto
Send a message via AIM to internetautomar
if your NO is high check your EGR valve for functionality.
a high NO indicates high combustion chamber temperatures which can be caused by several different things.
__________________
96 Gold I30 here
2000 Gold GXE gone | 95 White GLE modded gone |95 GLE white A/T gone
96 Green A/T gone | 94 Pathfinder POS GONE! | 79 Camaro sold
98 I30t Silver on black A/T gone | 96 Granite Pearl (AKA Purple) A/T gone | 92 grey VE A/T gone
96 I30 Black gone | 92 maroon VE A/T gone | 92 white VE M/T gone
92 grey VE A/T gone | 6/84 L24E last of the RWD Maxima gone
internetautomar is offline   Reply With Quote
Old 03-22-2008, 08:45 PM   #14
Points: 3,929, Level: 39
Points: 3,929, Level: 39 Points: 3,929, Level: 39 Points: 3,929, Level: 39
Activity: 0.3%
Activity: 0.3% Activity: 0.3% Activity: 0.3%
They are not suppose to go under the hood for anything on emissions test... Sounds like he is scamming you for extra cash in his pocket. I'd check everything under the hood you can, yourself, and go, back. make sure they don't touch anything under the hood.
doesn't NO have to do with the egr valve? maybe a hose is lose if so. im guessin that lose wire on plug was the cause tho.
maximaman1313 is offline   Reply With Quote
Old 03-22-2008, 10:24 PM   #15
2nd Gen Boostinator
Big_E-Dog's Avatar
Points: 11,303, Level: 70
Points: 11,303, Level: 70 Points: 11,303, Level: 70 Points: 11,303, Level: 70
Activity: 0%
in cali they have to go under the hood to put the spark wire clamp on, make shure all the hoses are connected and that nothing is modified.
high no can be caused by a few things, egr not working(not hooked up, leaking), low feul pressure, vaccum hoses not connected, misfire, or dead cylinders. aftr he touched something did the car run with a lot of vibrations(kinda rough) if so then he prolly did pull a plug wire.
now cats cre kinda expensive but here in daygo ive seen none higher than 175 installed, if it is universal then itl be lower.
could he be scalmming you prolly, ive beeen looking for a smogshop for a long time now and i think i finally found one in lemon grove. if you feel like your gettin scammed go somewher else
__________________
CUSTOM HEADLAMPS/CARBON FIBER/FT&RTSB/OIL COOLER/LED'S/VG30ET/VILLAGER INTAKE MANIFIOLD/60MM TB/2.5" EXHAUST/NISMO MUFFLER/HKS TT, BOV/NISMO BOOST GUAGE, THERMOSTAT, OIL FILTER/Q45 BBK/WRD 15" MESH/RWD
Big_E-Dog is offline   Reply With Quote
Old 03-23-2008, 12:28 AM   #16
Quote:
Missing spark for a cylinder must cause a failure in emission tst, otherwise the test is a sham.
A wire may be loose, but sitting on the plug, still able to give [poor] spark...
Hood has to be open, tester rpm sensor is attached on to spark wire.
Wiking is offline   Reply With Quote
Old 03-23-2008, 09:36 AM   #17
Points: 8,537, Level: 62
Points: 8,537, Level: 62 Points: 8,537, Level: 62 Points: 8,537, Level: 62
Activity: 0.6%
Activity: 0.6% Activity: 0.6% Activity: 0.6%
Quote:
Here in NashVegas they do not need to open the for emissions testing. There is no need from the testing equipment to know the rpm. They test at idle and if they see a reading they don't like they ask you to go to a "high" idle. If you have a tach they ask you to keep it at about 2500 rpm.
Other states may have visual inspection where they will look under the hood, but I have not run into a testing facility that actually touches the engine.
__________________
2000 Mazda Miata 5 spd My DD
93 Aerostar (Tow vehicle and portable tent)
92 Miata
92 Maxima SE 5 spd (Gone Now - Info @ http://forums.maxima.org/maximas-sale-wanted/562830-92-ve-5-spd-sale-nashville.html)
88 Aerostar (portable tool chest)
shoult is offline   Reply With Quote
Old 03-23-2008, 10:18 AM   #18
2nd Gen Boostinator
Big_E-Dog's Avatar
Activity: 0%
well dont come here (CALIFORNIA) youll think youve been violated....
__________________
Old 03-23-2008, 12:54 PM   #19
mod or sell?
Activity: 0%
internetauto
Illinois got rid of emission testing OBDI vehicles entirely last year.
__________________
96 Gold I30 here
Old 03-24-2008, 01:47 AM   #20
Quote:
Originally Posted by shoult View Post
Here in NashVegas they do not need to open the for emissions testing. ...
I guess there are myriad testing equipment available. I just wanted to point out that on some cases opening hood is a must, not hoax. Our requirement is idle and 2500rpm test results on paper; these will be fed into gvmt database in the yearly inspection. Test equipments can only get exact rpm electronically, here these systems take it from spark pulse, printout will log that exact rpm etc. OBD connector would be another source to get the rpm...
Old 03-24-2008, 06:41 AM   #21
Thanks guys for all the inputs, I will try another testing facility and will let you guys know.
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
Search Engine Optimization by vBSEO 3.5.2
