in search of a bad o-ring
I am going to be pulling my front 3 injectors to check the orings and see if any are cracked or what. they all should be new o-rings. Here is my question. I pulled 1 injector a year or so ago and put new o-rings on it. When I pulled that injector out, the bottom o-ring was cracked.
Now did I crack that o-ring when I pulled it out? Or did I not lub it right when I put it in the first time? Im curious because If I pull the front three and crack the orings pulling them out, Im going to think that they were bad. Im tryin to find a problem I have sometimes when I start the car, It'll be hard to start and sputter up as it spits black smoke out and i smell fuel, but then runs fine after that. thanks
What should I use to lube the o-rings? motor oil? petroleum jelly? I've heard both, and is that the jelly you buy in grocery stores?
i pulled 1 a year ago because i when put in 2 years ago the o-ring, or at least I thought, was bad. so when i pulled it a year ago and replaced orings, it was bad when i pulled it out. was just making sure it was acutaly bad before i pulled it. im having same problem i was having back then, so im thinking when i originally did it, they weren't lubed enough, i gave them a light coat of oil.
Also, use petroleum jelly on the o'rings, it works better then oil.
If you pinched the ring when you installed it, it would have shown signs immediately, not a year later.My guess is you have a bad injector. If you can access the injector in question, stick an ohm meter on it, it should read between 11-14 ohms.
Heh...the cel's on these cars rarely show injector codes, they are more of a novelty item.
I have no idea how you would check for a leaking o'rings other than removal and inspection.
You will have a drop in fuel pressure with a leaking o-ring. If the car sits it will take longer to crank and build pressure in the rails. Try letting it sit for different periods of time and see how long it takes to start. I know because I had a leaking o-ring and it would take 2-3 seconds longer after the car sat. With all good o-rings it will start the same after sitting for days or 10 minutes. (assuming the rest of the fuel system is tight) Good luck.
ok long story short, I pulled front 3 injectors, 2 bottom o-rings shredded, othe o-ring wasn't sealing right do to pintle cap. I fixed the cap. replaced all o-rings, lubed them up, twist and pushed as far as i could into fuel rail, then bolt on slowly and evenly.
couple questions:
I keep pinching the damn bottom o-ring . Its $13 after tax per o-ring kit per injector. #1 Now can I go to home depot and size match the o-rings and safely use those? #2 or are the fuel injector o-rings special?
Also, please any tips for me to get these damn injectors back in and seated right. #3 Should I remove the fuel rail completely? or maybe im just not strong enough, pretty hard to get these things back in, at least for me.
couple questions:
went to auto parts store got 3 more kits. I pull the injector harness from each front injector 1 by 1 and noticed the #6 didnt change unplugged or plugged in. I ohm'd all injectors, all 11.2. I pulled #6 injector and of course, the bottom o-ring was tore all around. I put new o-ring on. petroleum jelly. and damn near put all my weight into it pushing and twistin and i still cant get it to seat all the way like that. so i put the metal cap on and slowly slowly bolt on to finish seating the injector. and it keeps tearing it.
I had a similar problem with one of my injectors during reassembly. I had the injectors out of the rail 4 times, due to torn lower "O" rings. I smoothed the rail and lubed up the rings and they still tore. What I finally did was to go and get Nissan "O" rings from the dealer and lubed them with petroleum jelly to put them in, and they finally sealed. The dealer "O" rings seemed slightly harder than the kit ones I got from NAPA.
so i tried to start it. and I hear a metal like clunk and then nothing..... did fuel dump into the cylinder when i took out injector and put oring and, and now my motor is hydro locked?
tried to start again and i've never seen a seized motor but this looks like one. it gets 1 turn when i get key in, clunk type noise then nothing at all
I seiously doubt you dumped enough fuel to hydrolock your motor.
Pull ALL your plugs and see if the motor will turn over then.
if you have a VG check to see if the rotor turns or not.
all that being said , a clunk is a VERY bad sign in most cases.
my blazer did that when it was out of oil.
Pull the plugs FIRST before you change the oil. You want to see if you're still dumping gas before you ruin more oil. Make sure the rotor spins when you turn it over. If it doesn't, thats BAD!
Siphon hose - $5 at pepboys. Or $1 at a Dollar or 99cent store. But if its that flooded you got a real o ring problem.
hehe I just sihponed out what I could, wasn't as much as I thought...i cranked, and the motor seems to spin, sounds like its spinning just fine...now what? go get o-rings from dealer, and replace those, change oil, then try starting it again?
Don't skimp on the Vaseline, including inside the rail where the injectors will sit.
Now since I know my motor spins, should I hook it all back up and try to start it, or should I change the oil, I know has gas in first?
BTW, I HIGHLY reccomend going to the dealer for injector o-rings, I compared to the o-rings I got from auto parts store and they are 200% better quality. I should of went that route in the first place and saved me a 2 day headache.
took off injectors, all bottom o-rings were bad...put the o-rings I got from nissan dealership on-cheaper than parts store better quality- I was generous with the jelly and cleaned the rail where they sit and lubed that part up to...I was actually able to push them all, all the way in, it went smooth, could almost feel them seat nicely.
replaced oil, man, it smelled like fuel like crazy, was real thin too. The plugs I had in the front 3 got real fouled up, so Im going to just replace all 6 again.
I got it all back together, fresh oil, nissan o-rings. Started it up, was rough, I almost thought an injector was still leaking. I let it run for about 20minutes, it smoothed out nicely. Took for test spin, runs great, no smoke, good idle now.
THANK YOU EVERYONE. You guys are so hopefully, I greatly appreciate everyones input and advice given me. Thanks. The ve auto is purrin nicely again.
06-06-2017 02:01 PM
Unclejunebug
04-02-2016 05:42 AM
HerpDerp1919
09-29-2015 02:02 PM
Andy29
09-29-2015 05:32 AM
