Injector Swap
Injector Swap
I need to replace one of my injectors with a new one. But I don't have $100 to spend on a new one so I want to replace one on my '94 GXE with one I took off of "91 SE. They are a bit different but I figure they should work the same. I realize I'll have to switch one of the harnesses but I'm just looking for confirmation that I won't run into any technical problems otherwise.
Top one is from my GXE, bottom from SE.
if your old rail is all good, I would swap all of them over along with their harnesses.
if you look at the rails you see they have different feed points, I doubt it would make any difference, but you never know.
Yeah, that's what I was thinking too. No reason why I can't do that. Thanks.
Alright, I found out that those are completely different. Injectors and rails, both are incompatible with one another, even if they look similar, so yeah, complete swap is the only way to go here.
jmlee44
10-02-2022 02:13 PM
TallTom
50
07-08-2022 09:54 AM
HerpDerp1919
09-29-2015 02:02 PM
