Go Back   Maxima Forums > Maxima Discussions > 3rd Generation Maxima (1989-1994)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 02-16-2008, 02:04 PM   #1
:squint:
BenStoked's Avatar
Send a message via AIM to BenStoked
corroded injector terminals.
With all the posts about injectors and such flying around, I thought id throw this out to let some people think.
My car was showing some of the typical symptoms of a dead injector: rough idle, low mpg, etc. I found the injector using the "pull the plug wire" method (if you pull the wire and idle does not change, bad injector found) turned out to be number "4" cylinder. the terminal on the injector is easy to get to on the vg engine, so I just pulled the terminal to ohm test, and it was full of corrosion! before cleaning the terminals off I went ahead and tested and got no reading (duh...). After cleaning, i got 12.2 ohms. Thats within spec, so i cleaned the inside of the harness, and plugged it in. Fired up the engine, smooth as butter.
to prevent this again, I was wondering what some of the experts have to offer on what to put in there. isn't there an "electrical grease" that i can place on the terminals? what are some other options?
(off topic, anybody wanna help me replace my exhaust studs? there is *only* 3 broken ones, right now.)
BenStoked is offline   Reply With Quote
Old 02-16-2008, 02:18 PM   #2
Send a message via Yahoo to jonmandude
There is an electrolytic grease. It is used in outdoor lighting. I believe you can get some at Radio Shack. I use it on my battery terminals.
jonmandude is offline   Reply With Quote
Old 02-16-2008, 04:30 PM   #3
Wanna Go Muddin?
Greeny's Avatar
Autozone carries CRC brand dielectric grease for about $8
__________________
3rd Gen parts--> http://forums.maxima.org/1st-3rd-gen...-part-out.html
Greeny is offline   Reply With Quote
Old 02-16-2008, 04:35 PM   #4
yep! Some electrical grease should solve that problem. Is you wire loom to the injectors broken if so wrap it with some elctrical tape or if you found a couple of connectors at local junkyard then cut and swap.
__________________
2Legal4Me is offline   Reply With Quote
Old 02-16-2008, 05:07 PM   #5
Send a message via AIM to subs1000w
ive also seen this but only on vgs all the ve injector problems have been bad injectors im not sure why though maybe somthing to do with the diferent styl conector i hate those conectors with the little metal clip
__________________
(automatic - latin word for uncoordinated & spastic)
"man who says it will not work should not interrupt man making it work"
your max is 15 YEARS OLD ofcourse its going to need "generall scheduled mantainace" if you cant perform any of it yourself its going to cost a small fortune to take care of so your best bet would be to buy a car with a LONG WARRANTY
subs1000w is offline   Reply With Quote
Old 02-16-2008, 05:13 PM   #6
:squint:
BenStoked's Avatar
Quote:
Quote:
yeah, i broke the clip during removal. Im sure it won't come undone too soon, but im gonna go to the junk yard tomorrow. im gonna do it right, and use shrink tubing. I was planning on the trip already. hopefully the weather wont be too bad, its been raining all day...
Old 02-16-2008, 07:21 PM   #7
buy a car from him?
internetautomar's Avatar
Send a message via AIM to internetautomar
I've also seen this but only on vgs all the ve injector problems have been bad injectors I'm not sure why though maybe something to do with the different style connector i hate those connectors with the little metal clip
93-94 VG injectors and 92 up DOHC injectors use the same connector
PS. I fixed your spelling
__________________
Maxima parts catalog< Website for sale
96 Green A/T gone
94 Pathfinder POS GONE! | 79 Camaro sold
98 I30t Silver on black A/T gone | 96 Granite Pearl (AKA Purple) A/T gone
92 grey VE A/T gone | 96 I30 Black gone
92 maroon VE A/T gone | 92 white VE M/T gone
92 grey VE A/T gone | 6/84 L24E last of the RWD Maxima gone
internetautomar is offline   Reply With Quote
Old 02-16-2008, 09:09 PM   #8
Send a message via MSN to akurtzer57
that is something to check on gfs 90 max just bought it back from brother and has a bad idle and runs ruff. don't know about mpg...so I changed the coil and happened to look at the fuel filter and it read NISSAN right on it well duh original filter after 136k prob clogged. But if that don't fix it the injectors are next thanks for posting and possibly saving me another headache.
akurtzer57 is offline   Reply With Quote
Old 02-17-2008, 01:46 AM   #9
Well, a fuel filter w/Nissan logo on it doesn't necessarily means it is original filter, a lot of people do buy parts from Nissan, you know?
Anyway it would be a good idea to change the fuel filter and a tune up and all the basic stuff before you move any deeper.
__________________
ebay CAI, DIY ground wires, Otto FTSB, Matt's type II LTB, RSTB, Rear Sway Bar link, Warspeed y-pipe, Full Exhaust W/Hight Flow Cat, ST FSB, Addco RSB, Jeff's Front 13" Z32 BBK, Jeff's Rear Z31 BBK, SS Brake and Clutch Lines, Driver and Passenger Corbeau TRS, E36 head light conversion, Murano 18x7.5 W/225/40/18 Falken 115, Tokico HP shocks and Struts, Eibach spring, Blehmco Parallel links
NismoChi is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
