Capedcadavers tranny swap blog..;-)
Call me Wookiee Goldberg
http://s164.photobucket.com/albums/u...y%20car/d-day/
today I picked up the "solution to all my problems". basically everything I need to work with on my car can be taken from that car.
this is where i found the car: http://forums.maxima.org/showthread.php?t=549815
89 Nissan Rustima SE 5spd with 240k miles but a good tranny and clutch. some stuff doesn't work (windows, a/c, etc) but it has a sunroof which if at all possible i want on my car. Blue interior, tweed seats, leather wheel, etc etc. I'm taking the suspension for my car and the tranny too. HUGE exhaust leak.. ie, broken ypipe. Whatever, I'll start swapping stuff this evening, but nothing huge. Mainly interior items and maybe tails/centerpiece.
Have you gotten any estimates on cutting up your car and installing the moonroof?
I would think that's a fairly expensive job. If you do, try to get some kind of leak guarantee. I doubt they would do it, but I would try.
Back in the old days, when people used to get pop-up sunroofs from the aftermarket, they have a tendency to leak after a few years.
this legacy has a regular power with no leaks so far.
Originally Posted by my friend Matt
i now pronounce you husband and car. you may start the engine
Hey you guys are forgetting that the car is in good running order. yes some luxuries dont work but he got it cheap and thats what matters. Brian is just simply talented at finding cheap stuff but then again.... I'm not gonna say anything. He takes his time and knows where to look.
Are you planning on using the same clutch and all that or gonna toss in something nice?
Taking my Maxima to the Max!
Nice find! I also recently got a nice parts car for the same amount, only mine is a '94 VE auto with 173K mi. I'm still not decided whether to fix it (mostly suspension and some body stuff) or part it out and use some parts for my '89 GXE.
Anyway, good luck with your swap/build/project!
Also, when I called around up in DC a few years ago, I think a moonroof/sunroof install with some sort of warranty was going for around $350. Maybe if you sell parts off the car you don't need you could make that amount of cash to finance the install.
Keep us posted
-Mrkanda
Keep us posted
-Mrkanda
- rust
- more rust
- even more rust
- driver window does not work due to switch malfunction
- driver side rear door opens but is a PITA to close
- key cylinder on passenger door does not accept the key that operates the rest of the car
- hood struts failed (but not as badly as my GXE's)
- one iffy rear caliper, and worn rear rotors
- the gearshift pattern has rubbed off the shift ****...
- a/c doesn't work properly
- ***** on the climate control for temperature and fan speed are absent
- some cracks in windshield
- spoiler mounting points somewhat... rotted
- no visors
- interior-color trim piece that fits under the sunroof glass is in the trunk, not in the cabin
- there are two quarters in the back seat which I have neglected to put in my pocket
- battery has a bit of corrosion
- BROKEN ypipe causing effectively 30% muffling capacity TOPS
- engine bay is a little dirty
- seats have a few stains on them
- one cluster bulb (fuel/temp) is burned out
- sunroof controls work when and ONLY when they feel like it
- fog lights are missing
- reverse lights are nonfunctional for some reason (multimeter tomorrow)
i'm nitpicking mostly. if i have that much to nitpick about and nothing to say "OH crap this is broken" about... I won't say i'm in horrible shape for $350. tranny shifts fine, clutch needs to be bled a little b/c i have never driven a stick where the pedal HAS to be welded to the floor in order to shift gears (usually just 80% to shift will do), but other than that, and it being an eyesore... it's not a bad car. i'd DD it if i felt like registering and insuring the thing.
your clutch problem is probably a bad slave or master cylinder. Those are common problems, not really that expensive.
I should have mentioned that it was a nice find for that price. It goes to show how durable those VG engines are. It sounds like the car was really neglected and it still runs and drives good.
neglected, i suppose. it spent most of its life in Minnesota, fwiw.
My VG donor had 2 bad injectors and it ran OK. It had 220K on it. Similar shape but I doubt it had that much rust.
Congrads on getting it home in one piece.
It makes a 5 speed swap so much easier with a whole car. Im sure you'll have plenty of fun prepping the suspension to put on your 90.
~Alex
~Alex
i could just go ahead and toss it in this week while i'm waiting to hear from somewhere i applied... but i want to make sure the clutch hydraulics are OK first. in which case i'd use the current clutch and everything.. and install a new clutch when the current one starts slipping.. but i can't afford a clutch kit right now.
~Alex
~Alex
i'll keep part-swap pics in here:
http://s164.photobucket.com/albums/u...%20and%20mods/
heh yeah. I drove with my brother in my passenger seat in my 90GXE out to get it, and he drove my 90 back and I drove the 89. it was about an hour ride back home, plus he wanted a little "stick practice" so we drive it around the block for a half hour or so, and then went and got lunch, and drove back, then i took my friend out in it when he got off work and took it around the block again. it actually rides BETTER than my 90, and several things on this parts car are in BETTER condition. Tires, for one. Motor is smooth and strong, though it needs a tuneup and a new-to-it ypipe. the only REAL problems are:
- rust
- more rust
- even more rust
- no visors
one kinda big thing i forgot to tell you is: it has this issue that if you park in R with the engine running and then shut it off it sometimes will stay running all you have to do is tap the shifter so that its not all the way down and it will shut off. i have no idea what that is about its one of the strangest things i have ever seen
other then that; thats why the ad said parts car with good tranny
i hope it all works out for you
Slave cylinder-
it works well though
sorry forgot to tell you that the clutch needs to be bled, and the moon roof will stick if you close it where it should be but if you leave it up just a bit it works most of the time and if its not working just give it a hit right under the switch and that usually works. as for the reverse lights i'm not sure but check the switch on the tranny maybe.
also, the reverse shutoff issue never happened to me but it appears there must be a short to where the car's ignition signal actually runs THROUGH the reverse circuit... or something. Kinda like Kentucky Fried Wire that The ColombianMax formerly known as BlooToof had going on in his i'M aLL wIRED uP thread
yep made it, got here at 11:30p last night and no i can't get on the org with this phone, it just tells me the page is to big. the shutoff thing only does it if the shifter is all the way down to the point that if you tried to back it up with the key off the shifter moves enough for it to shut off.
when you go to do your swap you might want to rebuild the slave cylinder, the parts should be less the $20 and it easy. and maybe get a master cylinder (take the old one in for core) you should be able to find a reman. reasonable. i think i paid like $30 for one in my 87 but that was years ago or you might be able to find a rebuild kit for that too. just to be on the safe side, cuz new parts are nicer then parts that are old.
i only had that car for a little over 2 years and i was poor so it didn't get many new parts
and it was a good car to me.
also, thankfully this thing is in FAR better shape so it's gonna be good to go tomorrow i think.
i tested it today in reverse and SURE ENOUGH it kept running. slapped the shifter and it shut off. bled the clutch using a 1x4 to hold the pedal down while i broke the bleeder bolt loose. feels a little better? seems the catch point is a little higher now. i just drove it out to the culdsesac to swap the wheels over to my gxe without hauling wheels from one side of the yard to the other. also removed the rear trim panel so i can set that up to go on my GXE (the SE panel on there right now is about to fall off.. it's literally taped on.) w/ the chrome trim instead of black, and the chrome emblem off a 98 GLE. it's a DAMN good thing i got this parts car, if even just for the tires, because, well... this is what i was rolling on until today (inside of front drv side tire) and this is the tire that replaced it. see a difference? the end result.
My springs are definitely sagging. While I am rolling on 17s, they are the same diameter as stock and I do not have near the wheel gap as you. It is for certain, I got to get me some B&G's and Tok blues.
i know right? it's just stock springs with Monroe in front (came w/ car when i bought it 18k miles ago) and OEM (original probably) out back. it sits randomly. makes no sense. sometimes it sits low, sometimes it sits like a 4x4. buuuuut i got summore work to do on it today, if the weather is any good. spoiler install, rear fascia work. At which point my "SXE appearance package" will essentially be complete, minus foglights
Two weeks ago I got similar 'problem to all solutions', great gray rotten -BUT- with a real nonsticky tranny [with a RpRoblem]. Cant figure a solution to this: how can you get the snow off?
made my first profit parting the car out today. front driver-side window regulator cable section only. motor was toast. swapped motor over from the broken regulator on the recipient car. made $60 for parts and labor, PLUS her dad loaned me some tools to use for my spoiler installation tomorrow (technically later today as it's 3:30am EST), PLUS a tub of Permatex OrangeSomething hand cleaner. plus $150 worth of good rubber, a gauge and clock swap... the car has almost paid for itself already. and i haven't laid a finger on the tranny OR the suspension. word.
sounds like what i should do...just find the same model pretty much and get the parts off of it...like a crashed one or something that nobody will buy or drive...lmao...
aaaaaaand the time has come. for the swap. my a/t died tonight. i was ascending this ramp at about 35-40mph at the apex of the corner, and picked up the throttle to speed up to 50 to merge from I-440E to US1/401N ramp onto the main lanes, and she let go. engine shot to 4000RPM and was making the sound paper makes when you stick it in the blades of a running fan. TC shredded itself. no gears at all, in any position of the shifter. just a whirring sound, and a few loose nuts-n-bolts sound rattling around when i rev the engine "in gear".
so... the swap is going to happen a bit early. which sucks because i was going to refill the tranny mounts with poly... but they have to be used as they are now. so if someone has some VG 5spd tranny mounts that they would like to trade with me, so i can fill yours and send you back mine... that'd be splendid. i can do the motor mounts... that's not a problem b/c i have 2 vg engines and i can support the parts car's engine with a jack while i refill the mounts w/ poly.
well there you have it. this parts car is slowly becoming a godsend.
Last edited by CapedCadaver; 02-18-2008 at 11:50 PM. Reason: to back the arrow up to more clearly point at the right ramp
dunno about air... but it sucked the life out of itself. i was rounding the curve at 35-40mph and i picked the throttle up, the TC exploded or something. no fluid leaks. but it no worky no more. keep in mind the M/T swap was PLANNED anyways... just wanted to do it in march or april.. not february.
