Door locks quit!
Old 02-02-2008, 04:27 PM
watut's Avatar
Door locks quit!
hey guys my parents maximas power door locks just quit. My dad was changing the oil, then after the power door locks wouldn't work. you have to unlock/lock each one manually, when you push the pdl button nothing happens. I couldn't find any fuses for the system
watut is offline
Old 02-02-2008, 05:16 PM
mod or sell?
internetautomar's Avatar
then check all the fuses.
internetautomar is offline
Old 02-02-2008, 06:19 PM
MaximaMark123's Avatar
I used to have to twist the key in the door lock twice to unlock all the doors. Now I just twist once to do it. And I never got my remote to work at all.
MaximaMark123 is offline
Old 02-02-2008, 08:42 PM
Mysticcal's Avatar
I'd also like some info on this as I cannot seem to get my key to fully lock the driver door from the outside, seems to only lock fully from the inside, but i suppose thats a door panel issue maybe
Mysticcal is offline
Old 02-02-2008, 08:47 PM
watut's Avatar
I checked all the fuses and it worked. I gave the door panel (by the pdl switch) a whack and it worked again hmm. Maybe there;s a loose connection
watut is offline
Old 02-02-2008, 09:47 PM
Way out West
Cliff Clavin's Avatar
Do some searching. Your door lock timer probably is broken or has a bad solder in it.
Cliff Clavin is offline
Old 02-03-2008, 02:44 AM
elusivemax93's Avatar
it is the door lock timer. its under your steering wheel to the right and it is the most commen thing to go wrong and have failing door locks. its the soldering inside the unit and ill say this for those not able to do a good soldering job dont mess with it. i would recommend either A getting a new unit from Nissan or B risk it and buy a used unit from a salvage yard.
elusivemax93 is offline
Old 02-07-2008, 01:23 PM
mthomas002's Avatar
Anyone have pic of this door lock timer unit i cant seem to find it??? My passenger door will lock but will not unlock i want to replace this unit to see if it will help.
mthomas002 is offline
Old 02-07-2008, 10:27 PM
Mike90SE's Avatar
I just had this same problem....it is the actuator inside the passenger door. replace it and your troubles are gone.
Mike90SE is offline
Old 02-08-2008, 12:30 AM
ColombianMax's Avatar
Another way to tell if its bad will be a loud tick/click under your steering wheel immediately after attempting to lock or unlock your doors.
I'm currently acquiring one and fixin it for another member. If anyone else is interested I can probably pick some more up and resolder all the joints and let em slide for fair prices
ColombianMax is offline
Old 03-18-2008, 06:47 PM
0ldsch00ld0g's Avatar
Thanks same problem
I'm new to my car and that is one of the things wrong with mine. Pasenger side won't unlock. I love the keypad entry. Only had the car 3 days. Like it so far.
0ldsch00ld0g is offline
Old 03-18-2008, 06:54 PM
ale92se's Avatar
turn the key twice and all the doors should be unlocked.
ale92se is offline
Old 03-18-2008, 07:00 PM
Jesus was a Zombie.
BenStoked's Avatar
on my car all the doors except the front passenger unlock with one key turn
BenStoked is offline
Old 03-18-2008, 07:13 PM
augiedog964's Avatar
isn't it different for 89-91's and 92-94. my 89 unlocks and locks all doors with one turn. except the passenger side only unlocks all doors, doesn't lock them, but the manual says this is how it is supposed to work...
augiedog964 is offline
Old 03-18-2008, 07:18 PM
shoult's Avatar
My 92 unlocks the door the key is stuck in with the first turn, then the other three doors with a second turn. I haven't tried locking them since I always use the door button.
shoult is offline
Old 03-19-2008, 12:57 AM
maximaman1313's Avatar
I've never soldered anything in my life and i was able to fix mine np. 10bucks for soldering iron from radio shack and 30minutes of labor and it was fixed. works great now and continues to work great.
don't get a new unit. I'm sure if you are too worried about ruining it if you can't solder, im sure someone you know can do it.
maximaman1313 is offline
Old 03-19-2008, 03:58 AM
Wiking's Avatar
Originally Posted by maximaman1313
...you know can do it.
Heres one writeup for the timer http://www.thewardrops.com/maxima/
Problem may or may not sit t here - resolder wont hurt if done properly = ensures that all prospects for this problem will run out from t here.
Banging the door wont affect timer, possibly door actuator /contacts...
Door lock pwr comes via Batt fusible link (grn), under the hood. Then the wiring to door locks goes through the Super Multiple Junctions =SMJ's. There is a circ breaker in the left farthest corner under dash (a short makes it...clic clic).... There it goes to door lock timer, a box under dash.
If I get it right, door keyhole switch gets juice via 10A fuse, left, second from bottom.
Wiking is offline
magiconthetire
10-26-2015 09:03 PM
REDinLV
10-18-2015 05:31 AM
BobTX10
10-07-2015 08:43 AM
HerpDerp1919
09-29-2015 02:02 PM
Andy29
09-29-2015 05:32 AM
Quick Reply: Door locks quit!
