Go Back   Maxima Forums > Maxima Discussions > 3rd Generation Maxima (1989-1994)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Timeslips Members Parts Guide Search Today's Posts Mark Forums Read ExperienceUsed CarsGarageVendor Directory
Search
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 01-27-2008, 03:50 AM   #1
Fuel injector resistance reading
When testing my injectors, I get one with NO resistance reading. ?? yes all other 5 show the ohms , but one shows nothing. Tried it different ways. Any one know what is going on. The injector still clicks when the engine starts and though the idle is rough, the engine smooths out over 1500 rpm.
redwood_usa is offline   Reply With Quote
Old 01-27-2008, 05:27 AM   #2
Points: 11,356, Level: 70
Points: 11,356, Level: 70 Points: 11,356, Level: 70 Points: 11,356, Level: 70
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
You just put the meter on both of the leads. Should read 11.8-12.
I've never had one read as high as 12. Maybe the battery in your meter is dead? Or all your injectors are bad.
__________________
goon9 is offline   Reply With Quote
Old 01-27-2008, 05:50 AM   #3
Points: 6,504, Level: 52
Points: 6,504, Level: 52 Points: 6,504, Level: 52 Points: 6,504, Level: 52
Activity: 0%
Quote:
Could just be a dead injector, If you have a VG, pull the spark plug lead on that cylinder with the engine running, if you don't notice a difference to the idle, then the injector is probably dead. If you have a VE, you could just pull the injector connector instead.
sonicii is offline   Reply With Quote
Old 01-27-2008, 06:47 AM   #4
mod or sell?
internetautomar's Avatar
Points: 29,227, Level: 99
Points: 29,227, Level: 99 Points: 29,227, Level: 99 Points: 29,227, Level: 99
Activity: 0%
internetauto
Send a message via AIM to internetautomar
no resistance is either a totally failed injector, or you didn't test it right.
resistance is supposed to be between 11 and 14 ohms.
__________________
96 Gold I30 here
2000 Gold GXE gone | 95 White GLE modded gone |95 GLE white A/T gone
96 Green A/T gone | 94 Pathfinder POS GONE! | 79 Camaro sold
98 I30t Silver on black A/T gone | 96 Granite Pearl (AKA Purple) A/T gone | 92 grey VE A/T gone
96 I30 Black gone | 92 maroon VE A/T gone | 92 white VE M/T gone
92 grey VE A/T gone | 6/84 L24E last of the RWD Maxima gone
internetautomar is offline   Reply With Quote
Old 01-27-2008, 08:13 AM   #5
Points: 8,692, Level: 62
Points: 8,692, Level: 62 Points: 8,692, Level: 62 Points: 8,692, Level: 62
Activity: 0%
"Shows nothing" as in 0 Ohms or "nothing" as in the meter doesn't do anything? If it's the latter, clean the pins on the injector... get out you precision scredriver set and scrape the corrosion away and try again. The harness connector might make contact since it's been there for a while, but it's hard to get a test from caked pins.
Depending on which engine and which injector, you could easily test from another point down the line at another connector to double check.
Hope that wasn't too obvious.
__________________
My two cents is just that. What it can buy is up to the seller.
JC93SE is offline   Reply With Quote
Old 01-27-2008, 06:53 PM   #6
Shows "nothing". The pins are absolutely clean. Also there is nothing wrong with the meter as I can just move over to the next injector and I get a proper reading. Its injector number 6. Someone told me the coil may be shorted ?? However the injector clicks when the engine is running. the engine runs rough at idle but smooth over 1500 rpm ?? any one with ideas ?
Old 01-27-2008, 07:02 PM   #7
\(_o)/
Greeny's Avatar
Points: 46,585, Level: 100
Points: 46,585, Level: 100 Points: 46,585, Level: 100 Points: 46,585, Level: 100
Activity: 93.7%
Activity: 93.7% Activity: 93.7% Activity: 93.7%
Replace the injector...It's toast.
Greeny is offline   Reply With Quote
Old 01-27-2008, 07:14 PM   #8
Quote:
The part I am curious about is how the engine runs smoothly (over 1500 rpm) with one injector being toast ?
Old 01-27-2008, 07:19 PM   #9
\(_o)/
Greeny's Avatar
Activity: 93.7%
who knows,injectors can act funny sometimes..
But if you are reading 0 ohms,chances are the injector is bad.
Old 01-27-2008, 07:38 PM   #10
Donating member? what the?!
super32's Avatar
Points: 8,970, Level: 63
Points: 8,970, Level: 63 Points: 8,970, Level: 63 Points: 8,970, Level: 63
Activity: 2.3%
Activity: 2.3% Activity: 2.3% Activity: 2.3%
Send a message via AIM to super32 Send a message via Yahoo to super32
The DVM i have will read nothing too when the resistance reading is out of range of the selected range the DVM is set on (i.e. if resistance is 200M-ohm+ and DVM is set on 20-100Ohm, display will be all 0's or blank... can't remember which)
__________________
... doing it 3Gen, and no other way
get it here
super32 is offline   Reply With Quote
Old 01-28-2008, 03:56 PM   #11
Activity: 0%
It may appear to run smooth, but it is more likely the rough feeling is less noticable at higher RPM. How are you checking the 'clicking' from the injector? If you unplug it does the clicking stop?
If the coil is shorted you will read zero ohms, not infinite. But it will have the same effect on the engine.
As mentioned earlier, with the engine running, pull the plug lead for that cylinder, if you don't notice any change in how the engine is running, and you don't get any meter reading on the injector, then I would say 99% chance you have a dead injector.
Old 01-28-2008, 04:42 PM   #12
98 SE
Points: 6,088, Level: 50
Points: 6,088, Level: 50 Points: 6,088, Level: 50 Points: 6,088, Level: 50
Activity: 0%
Another "trick" to check whether the injector is clicking when running. Start your engine and let it idle. Take a long flathead screwdriver (I use an 18inch Craftsman), hold the flathead against the plastic part of the injector. Then hold you ear against the top of the handle. You should hear the injector clicking at a regular interval. You should also be able to feel the vibration of the injector opening and closing. If you do not hear the clicking, your injector is not functioning.
93SCMax is offline   Reply With Quote
Old 01-28-2008, 05:44 PM   #13
Quote:
That is exactly how I check the injectors to see if they are clicking. it lets you get to all 6 , including the one under the intake.
Old 01-28-2008, 09:44 PM   #14
Activity: 0%
Yeah, but you better have a good ear. I had to go back and listen a couple of times to realize that enough noise comes back from the other injectors... or at least from one ajoining.
__________________
Old 07-25-2009, 11:00 PM   #15
If the meter leads were making bad contact with the injector pins he would have gotten a very high resistance or infinity. 0 Ohms means he had excellent contac...or his meter leads were touching each other. I just measured 3 of mine (front) and they all read 0 Ohms. Me thinks my injectors are bad.
Eric97 is offline   Reply With Quote
Old 07-26-2009, 02:18 AM   #16
Points: 2,359, Level: 29
Points: 2,359, Level: 29 Points: 2,359, Level: 29 Points: 2,359, Level: 29
Activity: 0%
its dead... i have 3 with no resistance
johnno890 is offline   Reply With Quote
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
Search Engine Optimization by vBSEO 3.5.2
