OEM GXE Fog Light Wiring (who the heck has 56K these days?)
Old 03-04-2013, 03:58 PM
  #41
Call me Wookiee Goldberg
CapedCadaver's Avatar
Originally Posted by nismax1994
With the gxe fogs you will get lense+reflector. They are not like se at all. Even the Bosch seemed cheapo compared to the heavy se assembly. They have a metal spring/tab holding the lense on as well as very different mounts. I just ordered some no name ones from amazon. I will share pics when they arrive. I like the smaller size of the gxe fogs.
They remind me a lot of what's on my Pathfinder also... (not mine, but basically identical to mine)
CapedCadaver is offline
Old 03-04-2013, 10:49 PM
  #42
DMad8724's Avatar
Im curious whether the glass would be removable (so I can add yellow capsules) on the GXE fogs. Ive tried several different ways with the SE fogs and I cannot get the glass alone off. Too bad, too, since Ive got some capsules that would fit inside them perfectly
DMad8724 is offline
Old 03-05-2013, 06:21 AM
  #43
Ad·min·is·tra·tor
DanNY's Avatar
the stock SE ones?
there are 2 phillips screws behind the housing. undo those and the glass falls out revealing a H3 bulb.
DanNY is offline
Old 03-05-2013, 09:37 AM
  #44
DMad8724's Avatar
Originally Posted by DanNY
the stock SE ones?
LOLOL. Im talking about removing the glass from the reflector itself. I know the reflector + glass removes from the housing with those screws. Im saying id like to seperate the glass from the reflector and add yellow capsules.
Its possible to remove the H3 bulb holder and add capsules. But once you move that original bulb holder; there goes the beam pattern..
DMad8724 is offline
Old 03-09-2013, 09:03 PM
  #45
nismax1994's Avatar
Generic GXE fogs arrived today. They are glass, lens has "Luxpro" etched into it, sticker says "Eagle Eyes." They appear to be good quality.
Here's a comparison to the OEM SE fog:
To answer DMad8724's question the lens seems to be crimped onto the reflector, it doesn't seem practical to try and separate the two.
My question: does one of the lights need to be inverted? How to tell which one?
nismax1994 is offline
Old 03-10-2013, 01:42 PM
  #46
DMad8724's Avatar
foglight glass is always the same for both sides
ie you dont order foglight glass L and R, you order 2 of the same part number..
DMad8724 is offline
Old 03-10-2013, 01:55 PM
  #47
maximo018's Avatar
Man I haven't seen SE fogs in a while nor been able to find them.
maximo018 is offline
Old 03-11-2013, 05:36 AM
  #48
there is an "up" right? I think it matters which way they go in... since the light is intended to be aimed downward only.
Also does the SE fog have a plate inside it at the same height as the GXE fog's total height? Kinda looks like the actual light-output zone is the same size.
Old 03-11-2013, 06:32 AM
  #49
Ad·min·is·tra·tor
DanNY's Avatar
ohhhhhh....
beam pattern...what that even a thought when nissan made these housings?
DanNY is offline
Old 03-11-2013, 12:09 PM
  #50
DMad8724's Avatar
Caped: yeah the se fog has a cutoff shield in it
DanNY: all i know is without modification the SE fogs have a crisp, rectangular ~beam pattern~ lol
DMad8724 is offline
vingodine
45
05-21-2016 12:46 PM
EuroDriver
09-14-2015 06:08 PM
Viralkill
08-17-2015 10:54 AM
Viralkill
08-16-2015 05:09 PM
98nismomax
08-13-2015 12:44 PM
Quick Reply: OEM GXE Fog Light Wiring (who the heck has 56K these days?)
